4th June 2009, 04:03 | #1043 | Link |
FYI. The more I use HDC, the more I learn. I finally was able to get an encode accomplished that I've been trying to do for about a week now. The movie is 100 Million BC. This movie is one of the few that AutoMKV could not do. It would try, but could not do the video encode. The following is what I have discovered.
AutoMKV - Failed, could not encode the video HDC (Deint none) Would do the encode, but unsatisfactory results. Jaggies on moving objects and choppy panning. HDC (Deint FilmNTSC) Would not encode the video HDC (Deint Interlaced) Full encode, no jaggies, but very choppy panning Testing the Deint showed the movie to be Telecine (This is also what AutoMKV was trying to choose) HDC (Deint Telecine) Would not encode the video... I finally got a perfect encode of this movie by choosing Interlaced/Telecine for Deint, which makes sense now that I understand what is happening. Hey I'm learning.. Thanks Buzz |
4th June 2009, 07:10 | #1044 | Link |
HDConvertToX author
@ricktoo
what mean "would not encode the video" ? do you got errors in avs ? what's happen when you open the avs script in virtualdub ? another one try could be the "double ivtc" but you should do it only if your movie would be 23.976 fps also.. post a report and a 50mb of sample file BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
4th June 2009, 10:22 | #1045 | Link |
gday buzz
am having a problem with a dvd im trying to convert to 264 in mkv. it crashes when trying to convert the subs. also, i have 3 other questions. 1) when i checked this video with hdc's test interlace it said "Report: Progressive, order=1" yet you can see in the second dump below (from eac3to) that it reports the video as mpeg2, 576i50. (doesnt that mean its interlaced?) 2) i would have expected that this video would have been pal (original was bought in oz) yet there is a reference in the BDSup2Sub command line to ntsc (/res:ntsc). is this correct? 3) how do i know if hdc is picking up and then re-using the existing chapters (before i encode and find that they're missing) here is the info from the make report Code:
HDConvertToX v.1.7.329.2916 report Input File: d:\video_ts\vts_01_1.vob ( D:\VIDEO_TS\VTS_01_1.VOB ) Codec Video: mpeg Width / Heigh : 720 / 576 Framerate / Framecount: 25.000 / 128164 Duration(hh:mm:ss): 1:25:27 Aspect Ratio: 1.7778 Resized resolution: 704 / 288 Crop Values : 2:84:2:76 Start Video Configuration -> Encoding Settings: X264 in MKV NMT Compatibility: On Encoding Preset: 7 Final Size: 20 Priority: idle Denoise Level: Super Light Video Handling: Use Best Decoder -> End Video Configuration Start Audio Configuration -> Audio Codec: Copy Audio Audio Bitrate/Quality: 128 Audio Channels: 2 MP3 Mode: abr Normalize: On Audio handling: Use Eac3to as demuxer Keep only core: On -> End Audio Configuration Full Audio List-> (*** mean selected) NONE *** 2: ac3, 5.1 channels, 448kbps, 48khz, dialnorm: -27db 3: ac3 surround, 2.0 channels, 192kbps, 48khz, dialnorm: -27db 4: ac3 surround, 2.0 channels, 192kbps, 48khz, dialnorm: -27db -> End Full Audio List Full Subtitle List-> (*** mean selected) *** NONE *** 5: subtitle (dvd) -> End Full Subtitle List Mux Subtitle in MP4/MKV file: On Start Advanced AviSynth -> ColorMatrix: On -> End Advanced AviSynth Start Queue -> prompt $d $t $_$P$G "C:\Downloads\2009_06_04\HDConvertToX_1.7.323.2869\applications\dgindex.exe" -FO=0 -OM=0 -YR=2 -AIF=[d:\video_ts\vts_01_1.vob] -OF=[C:\Downloads\2009_06_04\HDConvertToX_1.7.323.2869\temp\movie] -exit -minimize "C:\Downloads\2009_06_04\HDConvertToX_1.7.323.2869\applications\eac3to.exe" "d:\video_ts\vts_01_1.vob" 5:"C:\Downloads\2009_06_04\HDConvertToX_1.7.323.2869\temp\hdencodertox__subs_5.sup" "C:\Downloads\2009_06_04\HDConvertToX_1.7.323.2869\applications\eac3to.exe" "d:\video_ts\vts_01_1.vob" 2: "C:\Downloads\2009_06_04\HDConvertToX_1.7.323.2869\temp\hdencodertox-pid2.ac3" java -jar "C:\Downloads\2009_06_04\HDConvertToX_1.7.323.2869\applications\BDSup2Sub.jar" "C:\Downloads\2009_06_04\HDConvertToX_1.7.323.2869\temp\hdencodertox__subs_5.sup" "C:\Downloads\2009_06_04\HDConvertToX_1.7.323.2869\temp\hdencodertox__subs_5.idx" /res:ntsc "C:\Downloads\2009_06_04\HDConvertToX_1.7.323.2869\applications\x264.exe" --crf 20 --threads auto --thread-input --no-psnr --progress --keyint 250 --bframes 3 --mixed-refs --trellis 0 --ref 3 --deblock -1,-1 --subme 9 --direct auto --vbv-bufsize 14000 --vbv-maxrate 25000 --me umh --no-ssim --weightb --b-adapt 1 --no-chroma-me --8x8dct --aud --nal-hrd --aq-strength 1 --psy-rd 1.0:0.3 --sar 1:1 --output "C:\Downloads\2009_06_04\HDConvertToX_1.7.323.2869\temp\hdconverttox_vts_01_1.h264" "C:\Downloads\2009_06_04\HDConvertToX_1.7.323.2869\temp\hdconverttox_vts_01_1.avs" --level 4.0 "C:\Downloads\2009_06_04\HDConvertToX_1.7.323.2869\applications\mkvmerge.exe" -o "C:\Users\Public\Documents\Zoolander.MKV" --default-duration 0:25.000fps "C:\Downloads\2009_06_04\HDConvertToX_1.7.323.2869\temp\hdconverttox_vts_01_1.h264" "C:\Downloads\2009_06_04\HDConvertToX_1.7.323.2869\temp\hdencodertox-pid2.ac3" --default-track -1:no "C:\Downloads\2009_06_04\HDConvertToX_1.7.323.2869\temp\hdencodertox__subs_5.idx" --title "Done with HDConvertToX v.1.7.329.2916" -> End Queue AviSynth Script -> Working with files: C:\Downloads\2009_06_04\HDConvertToX_1.7.323.2869\temp\hdconverttox_vts_01_1.avs try { mpeg2source("C:\Downloads\2009_06_04\HDConvertToX_1.7.323.2869\temp\movie.d2v") LanczosResize(704,288,2,84,-2,-76) ColorMatrix(d2v="C:\Downloads\2009_06_04\HDConvertToX_1.7.323.2869\temp\movie.d2v") hqdn3d(1) } catch (err) { last=BlankClip() converttoyv12() subtitle(err) trim(0,1500) } -> End AviSynth Script Code:
C:\Downloads\2009_06_04\HDConvertToX_1.7.323.2869>"C:\Downloads\2009_06_04\HDCon vertToX_1.7.323.2869\applications\eac3to.exe" "d:\video_ts\vts_01_1.vob" 5:"C:\D ownloads\2009_06_04\HDConvertToX_1.7.323.2869\temp\hdencodertox__subs_5.sup" VOB, 1 video track, 3 audio tracks, 1 subtitle track, 0:17:16 1: MPEG2, 576i50 (16:9) 2: AC3, 5.1 channels, 448kbps, 48khz, dialnorm: -27dB 3: AC3 Surround, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB 4: AC3 Surround, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB 5: Subtitle (DVD) s05 Extracting subtitle track number 5... s05 Creating file "C:\Downloads\2009_06_04\HDConvertToX_1.7.323.2869\temp\hdenco dertox__subs_5.sup"... Video track 1 contains 25893 frames. Subtitle track 5 contains 291 captions. eac3to processing took 1 minute, 26 seconds. Done. C:\Downloads\2009_06_04\HDConvertToX_1.7.323.2869>java -jar "C:\Downloads\2009_0 6_04\HDConvertToX_1.7.323.2869\applications\BDSup2Sub.jar" "C:\Downloads\2009_06 _04\HDConvertToX_1.7.323.2869\temp\hdencodertox__subs_5.sup" "C:\Downloads\2009_ 06_04\HDConvertToX_1.7.323.2869\temp\hdencodertox__subs_5.idx" /res:ntsc Command line: C:\Downloads\2009_06_04\HDConvertToX_1.7.323.2869\applications\BDSup2Sub.jar C:\ Downloads\2009_06_04\HDConvertToX_1.7.323.2869\temp\hdencodertox__subs_5.sup C:\ Downloads\2009_06_04\HDConvertToX_1.7.323.2869\temp\hdencodertox__subs_5.idx /re s:ntsc OPTION: set resolution to NTSC (720x480) Target frame rate set to 29.97fps Converting SUB/IDX Loading C:\Downloads\2009_06_04\HDConvertToX_1.7.323.2869\temp\hdencodertox__sub s_5.sup #1 DCSQ start ofs: 0x0000000a (00:01:07.659) ERROR: Unexpected command 0 at index 0x00000012There was 1 error Conversion of 1 file(s) finished |
4th June 2009, 10:46 | #1046 | Link | |
HDConvertToX author
2) fixed in next update 3) sorry pal, but in your case no chapter are extracted. Why ? you feed as input the first vob. If you use as input the vts_01_1.ifo HDC will extract and use chapters too BHH
4th June 2009, 12:17 | #1047 | Link |
#HDConvertToX Avisynth Script # #Input File = d:\test.mkv #Original Resolution = 1280x720 #Aspect Ratio = 1.7778 #Frame rate =23.976 #Number of Frames = 149969 #Lenght (hour:minutes:seconds) = 1:44:15 #Display Aspect Ratio = 1.7778 #Aspect Error = 1.0114 # #Resized resolution = 704 / 400 #Crop Left = 0 #Crop Top = 0 #Crop Right = 0 #Crop Bottom = 0 # LoadPlugin("D:\HDConvertToX_1.7.323.2869\filters\AddGrain.dll") LoadPlugin("D:\HDConvertToX_1.7.323.2869\filters\AddGrainC.dll") LoadPlugin("D:\HDConvertToX_1.7.323.2869\filters\autocrop.dll") LoadPlugin("D:\HDConvertToX_1.7.323.2869\filters\Average.dll") LoadPlugin("D:\HDConvertToX_1.7.323.2869\filters\avss.dll") LoadPlugin("D:\HDConvertToX_1.7.323.2869\filters\ColorMatrix.dll") LoadPlugin("D:\HDConvertToX_1.7.323.2869\filters\deblock.dll") LoadPlugin("D:\HDConvertToX_1.7.323.2869\filters\Decomb.dll") LoadPlugin("D:\HDConvertToX_1.7.323.2869\filters\deen.dll") LoadPlugin("D:\HDConvertToX_1.7.323.2869\filters\degrainmedian.dll") LoadPlugin("D:\HDConvertToX_1.7.323.2869\filters\dfttest.dll") LoadPlugin("D:\HDConvertToX_1.7.323.2869\filters\DGAVCDecode.dll") LoadPlugin("D:\HDConvertToX_1.7.323.2869\filters\DGDecode.dll") LoadPlugin("D:\HDConvertToX_1.7.323.2869\filters\DirectShowSource.dll") LoadPlugin("D:\HDConvertToX_1.7.323.2869\filters\EEDI2.dll") LoadPlugin("D:\HDConvertToX_1.7.323.2869\filters\FFMS2.dll") LoadPlugin("D:\HDConvertToX_1.7.323.2869\filters\FFT3DFilter.dll") LoadPlugin("D:\HDConvertToX_1.7.323.2869\filters\FluxSmooth.dll") LoadPlugin("D:\HDConvertToX_1.7.323.2869\filters\frfun7.dll") LoadPlugin("D:\HDConvertToX_1.7.323.2869\filters\gradfun2db.dll") LoadPlugin("D:\HDConvertToX_1.7.323.2869\filters\hqdn3d.dll") LoadPlugin("D:\HDConvertToX_1.7.323.2869\filters\MSharpen.dll") LoadPlugin("D:\HDConvertToX_1.7.323.2869\filters\mt_masktools-26.dll") LoadPlugin("D:\HDConvertToX_1.7.323.2869\filters\mvtools.dll") LoadPlugin("D:\HDConvertToX_1.7.323.2869\filters\mvtools2.dll") LoadPlugin("D:\HDConvertToX_1.7.323.2869\filters\NicAudio.dll") LoadPlugin("D:\HDConvertToX_1.7.323.2869\filters\nnedi.dll") LoadPlugin("D:\HDConvertToX_1.7.323.2869\filters\RemoveDirtS.dll") LoadPlugin("D:\HDConvertToX_1.7.323.2869\filters\RemoveGrainS.dll") LoadPlugin("D:\HDConvertToX_1.7.323.2869\filters\RepairS.dll") LoadPlugin("D:\HDConvertToX_1.7.323.2869\filters\SangNom.dll") LoadPlugin("D:\HDConvertToX_1.7.323.2869\filters\SoundOut.dll") LoadPlugin("D:\HDConvertToX_1.7.323.2869\filters\TBilateral.dll") LoadPlugin("D:\HDConvertToX_1.7.323.2869\filters\TDeint.dll") LoadPlugin("D:\HDConvertToX_1.7.323.2869\filters\TIVTC.dll") LoadPlugin("D:\HDConvertToX_1.7.323.2869\filters\TTempSmooth.dll") LoadPlugin("D:\HDConvertToX_1.7.323.2869\filters\UnDot.dll") LoadPlugin("D:\HDConvertToX_1.7.323.2869\filters\UnFilter.dll") LoadPlugin("D:\HDConvertToX_1.7.323.2869\filters\VSFilter.dll") LoadPlugin("D:\HDConvertToX_1.7.323.2869\filters\yadifmod.dll") Import("D:\HDConvertToX_1.7.323.2869\filters\BlindDeHalo3_mt2.avsi") Import("D:\HDConvertToX_1.7.323.2869\filters\Deblock_QED_MT2.avsi") Import("D:\HDConvertToX_1.7.323.2869\filters\GradFun2DBmod.v1.3.avsi") Import("D:\HDConvertToX_1.7.323.2869\filters\Lem.avsi") Import("D:\HDConvertToX_1.7.323.2869\filters\LSFmod.v1.7.avsi") Import("D:\HDConvertToX_1.7.323.2869\filters\MCTemporalDenoise.v1.2.02.avsi") Import("D:\HDConvertToX_1.7.323.2869\filters\QMLF_3_motions.avsi") Import("D:\HDConvertToX_1.7.323.2869\filters\QMLF_5_motions.avsi") Import("D:\HDConvertToX_1.7.323.2869\filters\QMLF_7_motions.avsi") Import("D:\HDConvertToX_1.7.323.2869\filters\QMLF_9_motions.avsi") Import("D:\HDConvertToX_1.7.323.2869\filters\seesaw.avsi") Import("D:\HDConvertToX_1.7.323.2869\filters\spresso.avsi") Import("D:\HDConvertToX_1.7.323.2869\filters\Srestore.avsi") try { #Enabling MT Setmemorymax(512) SetMTMode(2,0) #Source File DSS2("d:\test.mkv",fps=23.976) last = isRGB(last) ? ConvertToYV12(last) : last last = isYUY2(last) ? ConvertToYV12(last) : last #Applying Resizing Lanczos4Resize (704,400,0,0,-0,-0) #Insert Filters As Requested backward_vec3 = last.MVAnalyse(isb = true, delta = 3, pel = 2, overlap=2, sharp=1, idx = 1) backward_vec2 = last.MVAnalyse(isb = true, delta = 2, pel = 2, overlap=2, sharp=1, idx = 1) backward_vec1 = last.MVAnalyse(isb = true, delta = 1, pel = 2, overlap=2, sharp=1, idx = 1) forward_vec1 = last.MVAnalyse(isb = false, delta = 1, pel = 2, overlap=2, sharp=1, idx = 1) forward_vec2 = last.MVAnalyse(isb = false, delta = 2, pel = 2, overlap=2, sharp=1, idx = 1) forward_vec3 = last.MVAnalyse(isb = false, delta = 3, pel = 2, overlap=2, sharp=1, idx = 1) last.MVDegrain3(backward_vec1,forward_vec1,backward_vec2,forward_vec2,backward_vec3,forward_vec3,thSAD=300,idx=1) TextSub("D:\HDConvertToX_1.7.323.2869\temp\hdencodertox__subs_3.ass") } catch (err) { last=BlankClip() converttoyv12() subtitle(err) trim(0,1500) } Last edited by Chengbin; 4th June 2009 at 21:16. |
4th June 2009, 12:26 | #1048 | Link |
thanks for the quick response buzz
i will try this again later but with the ifo selected rather than the vob. is there some way now (or could it be added) to see the chapter information? even if its not editable at least we would know for sure that hdc has recognised their existance and will incorperate them in the mkv (i have had a couple of encodes now without them) cheers |
4th June 2009, 12:33 | #1049 | Link | |
HDConvertToX author
if yes, you will see in mkvmerge command the chapter muxing too ... the file name.. change the file name... BHH
4th June 2009, 13:39 | #1051 | Link |
HDConvertToX author
Lanczos4Resize is used for preset 8
in pseudo code Code:
Select speedquality Case 0,1 BilinearResize Case 2 BicubicResize Case 3 GaussResize,p=30 Case 4 GaussResize,p=45 Case 5 GaussResize,p=60 Case 6 GaussResize,p=75 Case 7 LanczosResize Case 8 Lanczos4Resize Case 9 Spline36Resize Case 10 LanczosResize.Repair(Gaussresize(p=100)) else Spline36Resize
4th June 2009, 14:23 | #1052 | Link |
Okay, but I trust CLSID, that codec pack never caused troubles for me. I just use it so I don't have to set splitters etc. The only audio/video decoder I use is ffdshow. Can haali work for mpeg 2, h264 and divx?
4th June 2009, 15:44 | #1053 | Link |
HDConvertToX author
New full Package HDConvertToX 1.8.332.2935
changelog >added support for mkv input file with mpeg2 codec video >fixed reboot, shutdown, multitemp not correctly loaded from settings >fixed keep only core when dealing with TrueHD audio track >fixed now overhead for M2TS is 8.5% >fixed Keep only HD audio on Save Setting >fixed now save queue will ask for file name >added support for HDC Utilities MKVExtract GUI >fixed compression test now will not run dgindex two time when compression test is done again >fixed usage of colormatrix in preview >fixed renamed libfftw3f-3.dll to fftw3.dll >fixed Visual Crop. Now it will show only the bottom left corner and the top right corner >added more profiles to x264, xvid, and wmv >fixed optimization for audio handling >fixed disabled MT encoding for WMV encoding >fixed audio source decoding for WMV encoding >other minor corrections and cosmetic fixes BHH
4th June 2009, 16:40 | #1054 | Link |
thanks for another update! MKVExtract GUI does not extract subtitles from MKV (MKV is OK, I can work with it using MKVtoolnix). I cannot tell you any other details, because command line window closed automatically and therefore I do not see any error. EDIT: maybe you could use this: http://coreforge.org/projects/mkvextractgui/ . It works fine. Another issue for me is, that even if this GUI would work and I could extract subtitles, I cannot mux them to output, because it is not possible to specify external subtitles for MKV to MKV conversion. Thanks. |
4th June 2009, 16:51 | #1055 | Link |
HDConvertToX author
i have included my own version of mkvextract gui
and my own version extract subs BHH
4th June 2009, 18:36 | #1059 | Link |
HDConvertToX author
@Adub
make sure you have installed MKVToolnix it add to path the folder where is this dll BHH
4th June 2009, 21:42 | #1060 | Link |
Sorry, perhaps I made a mistake. Over on the codecgude forums (they make K lite) clsid is the admin and post changelogs, helps people etc. So I assumed he is the author, I apologize if I made a mistake.
So you think if I install ffdshow + Haali that HDC will start working on Windows 7? I have used clsids tool to switch everything to ffdshow and have verified that Media Player Classic uses ffdshow to decode the vob file. EDIT: Installed ffdshow + Haali only and I still get the 'Please check media properties' error. Last edited by toology; 4th June 2009 at 22:07. |
bluray, hdc, hdconverttox, m2ts, network media tank, playstation, x264 gui |
