Old 13th October 2010, 14:41   #10621  |  Link
krosswindz
Please read the new #8 DTS FAQ
Thanks for the detailed explanation.
krosswindz is offline   Reply With Quote
Old 14th October 2010, 09:00   #10622  |  Link
_hawk_
BluRip author
I have a problem to grab the eac3to error output with C# - normal output works fine. Does any1 have an idea how to do this? Might it be possible to add a switch to eac3to to print errors on standard output?
Btw thanks for your great tool!
BluRip : 1-Click BluRay/m2ts to h264 mkv converter
http://code.google.com/p/blurip/
_hawk_ is offline   Reply With Quote
Old 14th October 2010, 10:12   #10623  |  Link
iSeries
When downmixing 5.1 FLAC soundtracks to AC3 2.0, what is the optimal bitrate to go for? 192kbps? Or maybe higher?
iSeries is offline   Reply With Quote
Old 14th October 2010, 11:13   #10624  |  Link
tebasuna51
tebasuna51's Avatar
Is your choice, at least 192 like DVD tracks 2.0, but you can use 224 or 256 also.
tebasuna51 is online now   Reply With Quote
Old 14th October 2010, 11:16   #10625  |  Link
iSeries
Is it ok to use the -normalize switch when converting to AC3, or is that not recommended?
Old 14th October 2010, 12:00   #10626  |  Link
tebasuna51
tebasuna51's Avatar
Is recommended when downmix.
Old 14th October 2010, 12:42   #10627  |  Link
iSeries
Thank you!
Is 256kbps the maximum for 2 channel AC3?
Old 14th October 2010, 13:57   #10628  |  Link
TinTime
No, it's 640 (!).
TinTime is offline   Reply With Quote
Old 14th October 2010, 14:29   #10629  |  Link
iSeries
I realised that 640 is the max for 5.1 AC3, but did not know that was also the max for 2.0 AC3.
Old 14th October 2010, 14:42   #10630  |  Link
TinTime
It's probably complete overkill. I think eac3to defaults to 448 for two channel AC3.
I've seen 640 2.0 AC3 occasionally on Blu-rays though.
Old 14th October 2010, 14:56   #10631  |  Link
iSeries
As 640kbps equals 106.66kbps per channel for 5.1 AC3 and is considered transparent enough for most people, then for 2.0 I guess 224kbps should offer similar quality?
Old 14th October 2010, 15:13   #10632  |  Link
TinTime
Only if each channel is treated equally. I don't know how the bits are distributed so I'm not sure what the 2.0 equivalent would be. I suspect the front centre gets a good chunk of the allocation in a 5.1 stream, and the LFE gets very little.
Old 14th October 2010, 16:49   #10633  |  Link
Midzuki
Unavailable
Midzuki's Avatar
OverSimplification:
640kbps / 5 = 128kbps per channel
Midzuki is offline   Reply With Quote
Old 14th October 2010, 18:30   #10634  |  Link
iSeries
So do not include lfe when working out? So with your method 2.0 AC3 256kbps is equivalent to 5.1 AC3 640kbps in terms of quality?
Old 14th October 2010, 18:53   #10635  |  Link
Midzuki
Unavailable
Midzuki's Avatar
YES ( or at least the theory says so ).
As TinTime said, the LFE channel consumes a very-very-low bitrate, and this is the reason why we say 5.1 and not simply 6-channel audio.
Old 14th October 2010, 21:40   #10636  |  Link
flyingernst
Hi guys...I tink i am not the first how asks, but i didnīt find the answer: is it possible to demux only the forced captures of the PGS Subtitles of "Avatar"?! forced and normal are in the same pgs stream in this movie
Thanks, greetings, Michael
Popcorn Hour B-110
Onkyo TX-SR 805
flyingernst is offline   Reply With Quote
Old 14th October 2010, 21:59   #10637  |  Link
TinTime
eac3to tells you about forced subs but no more. You can then use BDSup2Sub to extract the forced subs.
Old 16th October 2010, 02:54   #10638  |  Link
dansrfe
eac3to does not fix the delay when I extract wavs from 2 joined m2ts's. It says realizing raw/pcm gaps but that doesn't fix it. Any way to have it auto-fix the delay?
Old 17th October 2010, 08:37   #10639  |  Link
dansrfe
Can someone please help me?^
Old 17th October 2010, 15:09   #10640  |  Link
Thunderbolt8
in dts master audio suite you can tick the option to display all 7.1 channel layouts. doing so, theres another setup similar to that of "strange setup" 7.1 tracks which has the 2 additional speakers at the front and not at the back (Lw, Rw instead of Lsr and Rsr). how can we actually be sure that these layouts named as "strange setup" by eac3to are that one with the additional 2 channels at the back and not at the front?
eac3to
