Old 2nd October 2010, 14:53   #10581  |  Link
hubblec4
Matroska Dev-Helper
i have testet the same file with eac3to 3.22 and it works fine.
the same problem happened with ac3 files but with 3.22 all fine.
i have winxp32bit sp3. arcsoftdecoder 1.1.0.0
hubblec4 is online now   Reply With Quote
Old 2nd October 2010, 20:53   #10582  |  Link
SoleBastard
Hi Madshi,
Thanks again for your great program!
As eac3to doesn't support merging FLAC files (yet) I tried doing it using Foobar2000 and flac.exe 1.2.1. However, when the merged file reaches 2.00GB the encoding stops with an error. I asked about this in the Foobar2000 forum (see this thread) and it seems to be a specific limitation of the Windows FLAC build. However you manage to create FLAC files with eac3to in Windows that are >2GB just fine. How is that possible?
SoleBastard is offline   Reply With Quote
Old 2nd October 2010, 21:47   #10583  |  Link
TinTime
You could always convert to a .w64 file with foobar and then convert that to FLAC with eac3to. Not completely ideal but it's a workaround.
TinTime is offline   Reply With Quote
Old 2nd October 2010, 22:06   #10584  |  Link
SoleBastard
Yep, I figured that out and doing the conversion at the moment
So yeah, this work-around is okay for me because I don't need to do these kind of merges that often. I was just curious how Madshi was able to implement encoding >2GB flac files
Old 2nd October 2010, 22:57   #10585  |  Link
TinTime
Sorry, I see now that I replied to something you didn't ask and ignored what you did ask
Anyway, from your link it looks like an i/o limitation in flac.exe, so that's why eac3to is ok - it handles i/o itself and uses libflac to encode.
Old 3rd October 2010, 20:40   #10586  |  Link
deathlord
Often there's a "play all" playlist. It usually lists the episodes in the right order.
This is a very helpful hint, thanks a lot!
I have found it to work on Terminator: The Sarah Connor Chronicles and Dexter.
deathlord is offline   Reply With Quote
Old 4th October 2010, 17:37   #10587  |  Link
Groucho2004
Groucho2004's Avatar
Would it be possible to add an option to normalize to a certain level?
As far as I know, eac3to only normalizes to 0 dB. I always like to leave a little headroom for further conversions so that would be nice.
Possibly something like "-normalize -2dB".
Old 4th October 2010, 19:24   #10588  |  Link
SoleBastard
Ah right, that makes sense.
A kind HA.org user modified the flac.exe to work with large input files and I find it to work perfectly with my FLACs! See the thread I linked to earlier.
Old 4th October 2010, 19:59   #10589  |  Link
deathlord
You can certainly do "-2dB" (see first post). I don't know what happens if eac3to has to normalize, too. You can try it out or you can simply do two passes.
Old 4th October 2010, 20:26   #10590  |  Link
b66pak
b66pak's Avatar
"-normalize -2dB"
this don't work (the -2dB part)
you must do:
eac3to audio.xxx normalized_audio.wav -normalize
eac3to normalized_audio.wav final-2dB_audio.wav -2dB
_
if you ask a question and somebody give you the correct answer don't forget to leave a "thank you" note...
Visit The Land Of Dracula (Romania - EU)!
Old 4th October 2010, 21:22   #10591  |  Link
shh
Fragmentation!
Is there any way to prevent the massive file fragmentation in conjunction with eac3to?
I understand, that this is an issue of the (sometimes) unknown size of handled streams, but the count of segments of some of eac3to's files is just insane.
Suggestions:
- reserving file space for separate streams what can safely cover the size of a (sub)stream, later crop filesize to the real size of the stream.
- command line option: "just reserve +100MB per stream"
shh
shh is offline   Reply With Quote
Old 4th October 2010, 21:28   #10592  |  Link
Groucho2004
you must do:
_
Sigh.
Yes, that's what I've been doing so far. However, I was asking if this feature could added so I don't have to do 2 passes (actually 3 passes, because the "normalize" function already needs 2 passes).
Old 5th October 2010, 16:19   #10593  |  Link
LeXXuz
15 years and counting...
LeXXuz's Avatar
I'm getting this error message when encoding an audio stream:
eac3to v3.24
command line: eac3to  eng.ac3 eng_new.ac3 -384 -normalize
AC3, 5.0 channels, 1:33:59, 384kbps, 48kHz
The Nero decoder doesn't seem to work, will use libav instead.
Decoding with libav/ffmpeg...
Remapping channels...
Writing WAV...
Creating file "eng_25p.ac3.pass1.wav"...
Caution: The WAV file is bigger than 4GB.  <WARNING>
Some WAV readers might not be able to handle this file correctly.  <WARNING>
Starting 2nd pass...
Reading WAV...
The AC3 encoder received a non-supported data format (float, 5, 64, -).  <ERROR>
Aborted at file position 262144.  <ERROR>
Creating the wav file works, but as soon as I start the ac3 encoder it aborts with a similar error message:
eac3to v3.24
command line: eac3to  eng_new.wav eng_new.ac3 -384
WAV, 5.0 channels, 1:33:59, 24 bits, 5760kbps, 48kHz
Reading WAV...
The AC3 encoder received a non-supported data format (pcm, 5, 24, -).  <ERROR>
Source is from an HDTV recording.
LeXXuz is offline   Reply With Quote
Old 5th October 2010, 20:59   #10594  |  Link
Snowknight26
Search the thread for the 2nd to last line's error. It's been answered many times.
Think Aften.
Snowknight26 is offline   Reply With Quote
Old 6th October 2010, 16:36   #10595  |  Link
icon
dts to ac3 script
Does anyone have a .bat/.reg file that would allow me to right click on a .mkv file and have it call a .bat file to automatically convert dts to ac3? I don't want to use a gui.
If not can anyone help me with creating a bat file that I run to convert dts to ac3?
icon is offline   Reply With Quote
Old 6th October 2010, 16:43   #10596  |  Link
rack04
Why not just use the cmd? At bat file wouldn't work for all instances since the track number of the dts is a variable. Well you could use mediainfo cmd to determine the track number for the dts and use that in the bat file but that would be more work than using eac3to cmd.
eac3to input.mkv track: output.ac3
If you must use a bat file here is a quick and dirty. It only works with mkv, single audio track, and doesn't allow for additional options. Hence the reason why using the cmd is a better approach.
@SET MediaInfo_PATH=C:\Program Files\MediaInfo\CLI\MediaInfo.exe
@SET eac3to_PATH=C:\Program Files\eac3to\eac3to.exe
@SET Working_Directory=C:\Personal\Videos
@Echo off
Echo.
Echo.
Echo\***************   Input   ****************
Echo.
Echo.
set /p    INPUT_VIDEO="Path to Source: "
Echo.
Echo.
Echo\******************************************
Echo.
Echo General;%%FileName%%>"%Working_Directory%\temporary-generalfilename.txt"
"%MediaInfo_PATH%" --Inform=file://"%Working_Directory%\temporary-generalfilename.txt" "%INPUT_VIDEO%">"%Working_Directory%\temporary-analyzegeneralfilename.txt"
Echo General;%%FolderName%%>"%Working_Directory%\temporary-generalfoldername.txt"
"%MediaInfo_PATH%" --Inform=file://"%Working_Directory%\temporary-generalfoldername.txt" "%INPUT_VIDEO%">"%Working_Directory%\temporary-analyzegeneralfoldername.txt"
Echo General;%%FileExtension%%>"%Working_Directory%\temporary-generalfileextension.txt"
"%MediaInfo_PATH%" --Inform=file://"%Working_Directory%\temporary-generalfileextension.txt" "%INPUT_VIDEO%">"%Working_Directory%\temporary-analyzegeneralfileextension.txt"
type "%Working_Directory%\temporary-analyzegeneralfilename.txt">"%Working_Directory%\temporary-analyzegeneralfilename.tmp"
type "%Working_Directory%\temporary-analyzegeneralfoldername.txt">"%Working_Directory%\temporary-analyzegeneralfoldername.tmp"
type "%Working_Directory%\temporary-analyzegeneralfileextension.txt">"%Working_Directory%\temporary-analyzegeneralfileextension.tmp"
set /p    SOURCE_FILENAME=<"%Working_Directory%\temporary-analyzegeneralfilename.tmp"
set /p    SOURCE_FOLDER=<"%Working_Directory%\temporary-analyzegeneralfoldername.tmp"
set /p    SOURCE_EXTENSION=<"%Working_Directory%\temporary-analyzegeneralfileextension.tmp"
DEL "%Working_Directory%\temporary-generalfilename.txt"
DEL "%Working_Directory%\temporary-analyzegeneralfilename.txt"
DEL "%Working_Directory%\temporary-analyzegeneralfilename.tmp"
DEL "%Working_Directory%\temporary-generalfoldername.txt"
DEL "%Working_Directory%\temporary-analyzegeneralfoldername.txt"
DEL "%Working_Directory%\temporary-analyzegeneralfoldername.tmp"
DEL "%Working_Directory%\temporary-generalfileextension.txt"
DEL "%Working_Directory%\temporary-analyzegeneralfileextension.txt"
DEL "%Working_Directory%\temporary-analyzegeneralfileextension.tmp"
if "%SOURCE_EXTENSION%" EQU "mkv" goto process
Echo.
Echo.Source file is not MKV !
Echo.
Echo.
goto end
:process
Echo Audio;%%ID%%>"%SOURCE_FOLDER%\%SOURCE_FILENAME%-audid.txt"
"%MediaInfo_PATH%" --Inform=file://"%SOURCE_FOLDER%\%SOURCE_FILENAME%-audid.txt" "%INPUT_VIDEO%">"%SOURCE_FOLDER%\%SOURCE_FILENAME%-analyzeaudid.txt"
type "%SOURCE_FOLDER%\%SOURCE_FILENAME%-analyzeaudid.txt">"%SOURCE_FOLDER%\%SOURCE_FILENAME%-analyzeaudid.tmp"
set /p    ID=<"%SOURCE_FOLDER%\%SOURCE_FILENAME%-analyzeaudid.tmp"
DEL "%SOURCE_FOLDER%\%SOURCE_FILENAME%-audid.txt"
DEL "%SOURCE_FOLDER%\%SOURCE_FILENAME%-analyzeaudid.txt"
DEL "%SOURCE_FOLDER%\%SOURCE_FILENAME%-analyzeaudid.tmp"
@Echo on
"%eac3to_PATH%" "%INPUT_VIDEO%" %ID%: "%SOURCE_FOLDER%\%SOURCE_FILENAME%.ac3" >"%SOURCE_FOLDER%\%SOURCE_FILENAME%-eac3to.txt"
@Echo off
DEL "%SOURCE_FOLDER%\%SOURCE_FILENAME%-eac3to.txt"
DEL "%SOURCE_FOLDER%\%SOURCE_FILENAME% - Log.txt"
Echo.
Echo.
Echo.Finished !
Echo.
Echo.
:end
Pause
rack04 is offline   Reply With Quote
Old 6th October 2010, 18:01   #10597  |  Link
icon
Thanks for the reply. I should have mentioned that my mkv files only have (1) dts track and I don't use any options. I use cmd: eac3to input.mkv input.ac3
I'll take a look at the script you posted to see if I can make sense of it. Thanks again.
Ideally, I wanted to right click on a mkv file from the context menu, pass that file to a bat script to automagically create the ac3 output. I do a lot of ripping and converting. This cmd part is getting a little old. Just must be getting lazy.
Edit: I agree, that if I have to type the source input in everytime, then it doesn't make much since to use a bat file. I was hoping I could run it and it would locate all the 'mkv files I have and spit out ac3 files with the same input name and the mkv. Maybe I am asking for too much. I can't believe no one else has a need for this though.
If only I could use wildcards: eac3to *.mkv *.ac3
something like that
Old 6th October 2010, 18:25   #10598  |  Link
rack04
something like that
I think the reason most people don't need something like that is because if they needed ac3 then they would have converted the audio to ac3 before muxing to mkv. Not after the fact.
Old 6th October 2010, 18:53   #10599  |  Link
icon
I see. I use handbrake to do a lot of my encodings. It keeps the dts but does not convert to ac3. It seems that I need to run my encodes through mkmerge anyhow for proper playback on my video boxes. I did find an old script in this thread from Snowkight26, that I was able to modify for my needs. Thanks again for the help.
Old 7th October 2010, 00:23   #10600  |  Link
icon
Originally Posted by Snowknight26 View Post
Assuming there is only 1 video and 1 DTS track:
for /f "delims=;" %%a in ('dir *.mkv /b /s') do {
	eac3to %%a 1: %%a.video.mkv 2: %%a.ac3
	mkvmerge -o %%a.DTS.mkv  --language 1:eng --default-track 1:yes -d 1 -A -S %%a.video.mkv -a 0 -D -S %%a.ac3 --track-order 0:1,1:0
	del %%a.video.mkv
	del %%a.ac3
pause
Something like that at least.
I modified this script to just convert dts from a mkv to ac3. I had to use quotes and change { } to ( ). Now I am trying to figure out how the mkvmerge portion of the script works. I seem to be having a problem with it. Can anyone help me out. It's a very powerful script at least for my needs.
eac3to
