Old 20th May 2008, 23:27   #2021  |  Link
engene
Originally Posted by Kado View Post
@engene
Cyberlink's decoder can open that video stream using DXVA in mpc hc.
I play it with Cyberlink's pd8 decoder,but "20fps bug" happens.
My display card is HD3200.
Originally Posted by MatMaul View Post
wrong, this file is compliant with the level 4.1 (perhaps not DXVA but that was the purpose of this test file)...
recent x264 builds don't behave like that...
again, please read carefully this thread before making assumption
http://www.avsforum.com/avs-vb/showthread.php?t=972503
Thank for remind me about new x264 builds.
I re-encoded sd41.mp4 with x264 rev.859.
mpc-hc dxva decoder works fine with below setting
max ref frames:
without bframes=15
with bframes=11
Resolution: (x264 rev. 859+ encoder settings)
320x240,720x480,720x576,1024x544: (--level 4.1 --ref 11 --mixed-refs --bframes 3 --b-pyramid --b-rdo --bime --weightb --direct auto --filter -2,-1 --subme 6 --trellis 1 --partitions p8x8,b8x8,i4x4,i8x8 --8x8dct --me umh)
or (--level 4.1 --ref 15 --mixed-refs --filter -2,-1 --subme 6 --trellis 1 --partitions p8x8,b8x8,i4x4,i8x8 --8x8dct --me umh)
Sample:
SD41_720x576_ref11_bf3.mp4
SD41_720x576_ref15_bf0.mp4
SD41_1024x544_ref11_bf3.mp4
SD41_1024x544_ref15_bf0.mp4
engene is offline
Old 21st May 2008, 00:11   #2022  |  Link
MarcioAB
MarcioAB's Avatar
max ref frames:
15 (without bframes)
11 (with bframes)
Hum ... over here (GeForce 8600 GTS) it does not work with more than 4 Ref frames, so I have a question:
Could this difference be related to the graphics card ?
MarcioAB is offline
Old 21st May 2008, 00:35   #2023  |  Link
Aleksoid1978
Aleksoid1978's Avatar
On my 8800GT to not work fine woth more than 4 Ref frames.
Possible it is on all Nvidia Card, because on Radeon all 4 my sample, where Ref frames>4, play fine with DXVA, people on russian forum test:
http://forum.ixbt.com/topic.cgi?id=10:51719-61
Aleksoid1978 is offline
Old 21st May 2008, 01:43   #2024  |  Link
MarcioAB
MarcioAB's Avatar
Ok. So that could be the reason of the "bad" reputation of nVidia cards regard DXVA ...
On the other side, MAYBE the link below "x264 Encoding Options for Hardware Compatibility & DXVA", pointed by @MatMaul should be reviewed considering Hardware by Hardware.
Over here (with 8600 GTS) I can not have sucessfull DXVA with more than 4 Ref frames, even for very low resolution like 704x396.
MarcioAB is offline
Old 21st May 2008, 02:07   #2025  |  Link
Shinigami-Sama
Solaris: burnt by the Sun
Shinigami-Sama's Avatar
theres two types of 8800s
one with the OLD GPU
and one with the NEW GPU
the old ones have troubles with lots of stuff
Originally Posted by benjust View Post
interlacing and telecining should have been but a memory long ago.. unfortunately still just another bizarre weapon in the industries war on image quality.
Shinigami-Sama is offline
Old 21st May 2008, 02:24   #2026  |  Link
Kado
Otaku
Kado's Avatar
G80 nVidia GPU's like 8800gtx only support motion compensation (DXVA1/XP) wile G92 GPU's like 8600gts or 9800gtx support bitstream (DXVA2/vista (or xp+evr)), i.e. full video decoding. MPC internal decoder only supports bitstream.
In the school, the three guys met. Their relation had been changed in the season, and turned into three love stories.
Kado is offline
Old 21st May 2008, 05:14   #2027  |  Link
Aleksoid1978
I have 8800GT 512Mb on G92 GPU with support bitstream, but error on DXVA, when ref num>4.
test on XP+WVR9, XP+Evr, Vista+Evr .
Old 21st May 2008, 05:36   #2028  |  Link
Shinigami-Sama
try changing your driver then
Old 21st May 2008, 06:18   #2029  |  Link
Aleksoid1978
Changing, and many time, many version - NO WORK.
Sample that i Uploading on my not work with DXVA
On MPC-HC Internal Decoder - Black Screen
On Creative h264 External - "20fps bug".
Old 21st May 2008, 07:49   #2030  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
I have same problem on nvidia 9600GT. Previously i had HD 3200 integrated on 780G chipset motherboard, and before than i haved HD2600XT AGP on older machine. Both radeons decode fine with DXVA support, on every video render (VMR7/9), with both MPC-HC or Cyberlink H264 decoder's, never have problems with drivers and similar. But with nvidia 9600GT, first time when i installed driver, playing video in MPC show corrupted frames, than i update to lastest drivers found on nvidia site, now cyberlink decoder work fine, but MPC-HC return me gray screen, and there is no playback. I want just to say nvidia's prue video is suck comparing to radeon's UVD. I don't know why ppls love nvidia.
shon3i is offline
Old 21st May 2008, 08:00   #2031  |  Link
Aleksoid1978
why love nvidia - because I by 8800GT first for gaming -> is it number 1 in this price+speed segment.
I wait that Nvidia fix driver, and DXVA be work fine - now i decode software, my C2D@3200Mhz work fine with it ...
Old 21st May 2008, 08:13   #2032  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
well HD3870 is more payablle than oldish 8800GT. Prices in my county is almost same for that card's. And 9600GT also have near price. But 3870 gives more, stuff like DX 10.1, Assassin's Creed have support for shader 4.1 and DX 10.1. I realy don't care about less 5fps less in games with radeon cards.
shon3i is offline
Old 21st May 2008, 08:29   #2033  |  Link
Shinigami-Sama
nvidia the way it was ment to be played
thats why I love nvidia
watching videos is second to gaming
its true for a lot of people
but both ATI and Nvidia need to man up in the drivers field...
Old 21st May 2008, 10:23   #2034  |  Link
Leak
ffdshow/AviSynth wrangler
Leak's Avatar
ITYM "nVidia - the way it's meant to be played*"
* void if it includes video, audio, 3D or anything that moves
now playing: [artist] - [track] ([album])
Leak is offline
Old 21st May 2008, 10:42   #2035  |  Link
tetsuo55
MPC-HC Project Manager
The bugs with the nvidia purevideo decoder will have to be reported to NVIDIA, this is the only way a driver update will fix the drivers
tetsuo55 is offline
Old 21st May 2008, 12:55   #2036  |  Link
clsid
This topic is a bit messy. May I suggest the following to the regular posters here:
Someone (with a DXVA capable graphics card) should open a new topic for discussing these "DXVA compatibility" issues. The opening post of that topic should be updated on a regular basis to contain a summary of the content that is discussed in the topic.
Contents of this opening post could be:
* Links to sample files. For each file technical details (levels, max ref frames, etc) should be included.
* A list of graphics card models that are (somewhat) compatible. If a card has some limitations with regard to the type of files that it supports, then that info should also be included.
* For each sample file, maybe list which cards are able to play it and which are not.
* The rules for getting DXVA playback: compatible card, H.264 bitstream requirements, no intermediate filters, etc.
* A FAQ that answers frequently asked questions and gives solutions for common problems.
clsid is offline
Old 21st May 2008, 13:04   #2037  |  Link
tetsuo55
Done,
But its still a work in progress
http://forum.doom9.org/showthread.php?p=1140181
tetsuo55 is offline
Old 21st May 2008, 19:08   #2038  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
I am realy sorry for offtopic and my statament about nvidia cards
shon3i is offline
Old 21st May 2008, 22:59   #2039  |  Link
Jong
Originally Posted by DrNein View Post
Is it possible to use the Shaders function to make 1088 video appear as 1080 to avoid showing lines at the bottom of some sources or with some decoders?
Is there another way this could be implemented in the player?
Hi everyone.
It does not seem there were any comments on this. Is it possible that this could please be fixed?
I have just remuxed Elizabeth - The Golden Age on HD-DVD (VC-1) and it actually has noise (flashing white blocks) in the extra 8 lines. In PowerDVD the original disc does not show these. Even TheaterTek does not show them playing the remuxed mkv. However, MPC-HC (still using the official release, not any beta, don't know if this makes a difference) shows these last 8 lines, which are never meant to be shown on any hi-def disc.
I know I can manually move the picture down "one notch" and get rid of the extra lines, but this is messy to do with every hi-def disc.
Like CoreAVC, could there be an option to crop 1920x1088 to 1920x1080, for AVC and VC-1?
Thanks
Jong is offline
Old 22nd May 2008, 09:58   #2040  |  Link
_xxl
ffdshow user
_xxl's Avatar
Please use latest r518.
_xxl is offline
dxva, h264, home cinema, media player classic, mpc-hc
