Old 13th July 2014, 01:59   #21  |  Link
filler56789
SuperVirus
filler56789's Avatar
Originally Posted by Frozen Fractals View Post
How would I use DSS2Mod with MEGUI (AviSynth 2.6 MT Alpha 5)? Do I just stick it in the 'plugins' directory under AviSynth's program files and register the dll?
There is no need to register anything in this case. Besides,
I recommend renaming the file to "avssmod.dll" or something
(in order to avoid confusion) and
preferring the manual "LoadPlugin('Path-To\avssmod.dll')" to the common practice of storing a ton of files in the default Avisynth plugins folder.
filler56789 is offline   Reply With Quote
Old 13th July 2014, 05:51   #22  |  Link
Frozen Fractals
Audiophile
Frozen Fractals's Avatar
Hmm, I could do that, but it doesn't load properly in MEGUI. If I try and create an avs script using MEGUI the radio to tick "Prefer DSS2 over DSS" is greyed out. How would I get DSS2mod to work properly with MEGUI? Thanks!
Frozen Fractals is offline   Reply With Quote
Old 13th July 2014, 06:07   #23  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
I don't use GUI's, but you could try moving the original avss.dll to a "_backup" folder and then rename the mod to "avss.dll" (the exact same name as the original) so as to replace the original.
MeGUI should be able to detect that, without fancy registering.
If it's still greyed out, then it probably does a hashcheck against the original or something to verify that the original is there.
When I used to use GUI's, I found that (sometimes) that would do the trick. If not, you'd have to ask the devs for support for non-official builds of avss.dll (provided the licencing agreements allow them to; again, GUI's and Haali is not my forte~)
You could probably get a better answer in a MeGUI thread.
The title for this thread is misleading as it's clear now that your sole problem is with MeGUI and not avisynth in general.
Win10 (x64) build 18362| GPU Caps Viewer 1.42.4.0
NTSC | DVD: R1 | BD: A
Intel Xeon X5660 @2.80GHz
Old 13th July 2014, 06:19   #24  |  Link
Frozen Fractals
Audiophile
Sounds good. I will create a new one in the encoder GUIs subforum. Thanks for all the help guys!
Old 13th July 2014, 19:39   #25  |  Link
Overdrive80
Anime addict
Overdrive80's Avatar
Fancy or not fancy but work with reg keys:
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Nvidia GTX750 2GB DDR5 + SSD Vertex 4 256 GB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite
Overdrive80 is offline   Reply With Quote
Old 13th July 2014, 22:00   #26  |  Link
Frozen Fractals
Audiophile
Question: so what exactly are those registry keys doing (and how do I use them)?
I.e. If I want to have Haali installed but ONLY used for the sole purpose for MeGUI's DSS2 option, what do I do with them? (Note: I am using KCP as my codec pack and I manually installed Haali.)
Thanks!
Old 13th July 2014, 22:59   #27  |  Link
carmels
posting here to remember this thread, please let me know if i am doing something wrong.
wolverine
carmels is offline   Reply With Quote
Old 29th September 2015, 18:34   #28  |  Link
Motenai Yoda
Motenai Yoda's Avatar
I see this dss2 mod has been recently updated.
There is a way to contact the dev to ask if he can add 10/16bit output too?
powered by Google Translator
Motenai Yoda is offline   Reply With Quote
Old 1st October 2015, 23:48   #29  |  Link
manolito
manolito's Avatar
AFAIK the latest official build is still the one from this post:
http://forum.doom9.org/showthread.ph...01#post1699301
There also is a newer test build:
http://forum.doom9.org/showthread.ph...27#post1723627
And of course you can PM forclip for any questions you have...
Cheers
manolito
