Old 29th March 2009, 03:21   #701  |  Link
SamNZDat
Afterthought
Originally Posted by SamNZDat View Post
Have we looked into...
Another thought or two came to me in the last couple of hours -- just trying to think outside the box here -- how about two or more Daemon Tools mounts of Blu-Ray images, identically timed and of identical (at least as far as humanly readable) content but differently coded, running in parallel, perhaps a way to ferret out watermark? Or running rsynced Blu-Ray images by FTP -- again, to ferret out watermark, watch for decryption clues, or? Or comparing Blu-Ray behavior with the behavior of ray trace programs, for decryption clues or other objects?
SamNZDat is offline   Reply With Quote
Old 30th March 2009, 03:19   #702  |  Link
Rupan
This thread specifically relates to BD+ copy protection, so please keep the discussion on-topic.
There is no need to transmit all 50GB of video data over the internet. It would be trivial to write an application that produces a hash table of small video segments and only send the differing pieces.
Rupan is offline   Reply With Quote
Old 31st March 2009, 06:33   #703  |  Link
krosswindz
This might seem to be a stupid question, I just checked out the bdplus from Assembla. I went through the source tree seems like the configure script is missing for libbluray. Are there any instructions on building libbluray?
krosswindz is offline   Reply With Quote
Old 31st March 2009, 06:35   #704  |  Link
Accident
"autoreconf", or if needed "autoreconf --force --install". Traditionally you don't check in files that are generated when building (like .o files etc).
But perhaps I should put that in the README.txt
Accident is offline   Reply With Quote
Old 31st March 2009, 14:38   #705  |  Link
krosswindz
I did autoreconf but it failed due to missing files. where can I find these files? Tried going through all the 36 pages in this thread, not sure which post may point to it .
configure.ac:3: required file `build-aux/install-sh' not found
configure.ac:3:   `automake --add-missing' can install `install-sh'
configure.ac:3: required file `build-aux/missing' not found
configure.ac:3:   `automake --add-missing' can install `missing'
src/Makefile.am: required file `build-aux/depcomp' not found
src/Makefile.am:   `automake --add-missing' can install `depcomp'
autoreconf: automake failed with exit status: 1
Old 31st March 2009, 15:21   #706  |  Link
KenD00
Have you tried this?
KenD00 is offline   Reply With Quote
Old 31st March 2009, 16:01   #707  |  Link
krosswindz
Thanks, I guess I shouldnt try building things when I wake up first thing in the morning
Old 1st April 2009, 03:05   #708  |  Link
kkloster21
i don't want this to come off the wrong way, but if anybody needs a tester for the BD+ implementation in dumphd, with respect to the new MKBv9 and MKBv10 discs, i have several of these discs that i've already tried. The MKBv9 discs still produce a conv_tab.bin file that corrects some of the broken video (but not all of it) and the MKBv10 discs produce an error.
again, i have more info if anyone is interested.
kkloster21 is offline   Reply With Quote
Old 1st April 2009, 04:42   #709  |  Link
Accident
Really, you should try the latest tarball, unless you have reason to want to try the latest version in repository, which is this case would be valid since we are working on the new changes...
Old 1st April 2009, 18:04   #710  |  Link
loo3aem3ON
I'm regularly checking my private message if you have any questions. Probably i could do this last step (connecting BD-J platform to TRAP_ApplicationLayer) in 1 week so everyone else shouldn't need more than 2 months.
loo3aem3ON is offline   Reply With Quote
Old 16th April 2009, 12:52   #711  |  Link
dirio49
JuSt a PoWer uSEr
Any news? Just curious?
Progress?
Thanks
dirio49 is offline   Reply With Quote
Old 18th April 2009, 01:05   #712  |  Link
loo3aem3ON
Progress?
Thanks
According to Accident the latest revision (203) from April 3rd is supposed to have the connection between BD-J platform and BDVM platform. Accident can't test it though because all the computer he/she has access to are running osx and not linux (i386 compatible).
KenD00 has started working on this as well.
I'm busy at the moment and i doubt i will have much free time in the near future.
Old 23rd April 2009, 07:01   #713  |  Link
Rupan
java disassembly updates
Sorry for the long wait. I've had other things keeping me busy.
I've taken a look at the java BDJ jar that Accident sent me. Of specific interest are two classes:
org.bluray.system.RegisterAccess
com.philips.bluray.system.RegisterAccess
Although they do not reveal anything we do not already know about the player status registers, they do expose some of the binary API in the native libraries. They also confirm the functions of several PSRs.
103 = PSR_APPL_TO_BDPLUS_DATA
104 = PSR_BDPLUS_SHARED_DATA
Some subroutines to target may be:
private static native int nGetGPR(int i);
private static native void nSetGPR(int i, int j);
private static native void nSetPSR(int i, int j);
private static native int nGetPSR(int i);
private static native String nGetPreference(int i);
private static native void nSetPreference(int i, String s);
which are all defined in libbdj.so. I've done a small bit of MIPS assembly, but I'm by no means proficient with it. I'll give them a shot...
One more thing. There is just too much code in the BDJ archive for one person to recreate. Anything other than simple classes requires a significant amount of work to fully recover, and the native functions are going to be a real bear. I need some help from other developers to decide what I should target for reversing; let me reiterate that I simply cannot reverse everything.
Rather than reverse engineer the binary MIPS libraries I suggest that we use them directly. We can write a shim in C and cross-compile it for little-endian MIPS, then run it using qemu-mipsel. IPC can be performed using named pipes or sockets. I realize that this is a completely separate track from the BDJ implementation on Launchpad, but it might be simpler in the short term and it offers the advantage of automatically supporting new versions of the "official" binary-only libbdj copied from player firmware. Comments?
Old 27th April 2009, 01:34   #714  |  Link
Accident
Sorry for the delay, busy here too.
I can reverse engineer MIPS quite well, but small functions only, anything larger is not really realistic.. I'm not a fan of Java, as to me that cuts out too many platforms (I know, it is supposed to be more portable). I've even toyed with the idea of simply recording PSR interactions for each movie, but that's hardly a great idea. IPC is done with Unix sockets on this platform afaik, and they directly use /proc/mem for DiscoveryRAM.
Old 31st May 2009, 22:52   #715  |  Link
dirio49
JuSt a PoWer uSEr
Hello, Me again
Just curious as to how is it going?
any progress?
thanks
Birthdays are good. Statistics show that the people who have the most live the longest.
Old 1st June 2009, 08:30   #716  |  Link
Wombler
Affable Wanderer
Wombler's Avatar
Funny, I wondered that myself, as it's the first of June now and there hasn't been a post since April in what was previously a very active thread.
Hopefully things are still progressing.
Wombler
Wombler is offline   Reply With Quote
Old 28th August 2009, 06:29   #717  |  Link
kreet
im thinking about picking up this project to try and get support for the latest titles. are any of the original devs still around?
kreet is offline   Reply With Quote
Old 28th August 2009, 06:36   #718  |  Link
Accident
I am. Just very busy with many projects. The latest sources has both aacs and bd+ sources, which needs to be merged, or at least have a top level tool that links with both to demonstrate full functionality.
There were still some compatibility issues with latest keys, but not enough to put anyone off working on the project.
Old 28th August 2009, 09:09   #719  |  Link
kreet
Accident:
Ive grabbed the code and will start working on it. do you have the snapshot packages?
I think another big thing is that we dont have working processing keys for > v10 (in aacskeys). we need to get these keys in order to be able to work on newer titles.
arzenami: are you or anyone else working on this?
Old 28th August 2009, 19:04   #720  |  Link
KenD00
This has rather low priority, much more important is the fact that the latest BD+ versions interact with the BD-J layer, this should be implemented first before messing up with stuff that works. And there is still much work to do on the BD-J machine itself.
No, i don't think that this is necessary. AFAIK BD+ can use the Volume ID off the disc but nothing more AACS releated stuff (maybe this can change in the future?), for discs we don't have a Processing Key you can still check if the Conversion Table seems to be valid, without actually watching if the movie runs without errors.
