12th June 2014, 16:24 | #82 | Link |
Small thing, your YCbCr to RGB shader is bugged for SD, its only outputting 16:235 (example being a fully black 1st frame is grey). On HD, Blacks is fully functional.
For this SD content, the primaries are apparently SMPTE C (not BT.709, as usual). The shader isn't handling this type. Last edited by FireFreak111; 12th June 2014 at 16:26. |
12th June 2014, 16:54 | #83 | Link |
I added a different RGBtoYCbCr shader to the first post that should also work for SD content, but again likely not all. You could also use the RGBtoYCbCr shader I added instead of using the YCbCr hack, this should at least keep the colours the same.
13th June 2014, 19:28 | #85 | Link |
Minor update: the shaders chromaNEDI-I and II have been improved a bit by using a slightly larger (more disk shaped) window, the difference is most noticeable when not using chromaNEDI-III (which seems to remove some detail, including aliasing).
14th June 2014, 14:22 | #87 | Link |
You can just modify the YCbCrtoRGB shader slightly so it will remove the luma channel:
sampler s0; float2 c0; float4 main(float2 tex : TEXCOORD0) : COLOR { float3 s1 = tex2D(s0, tex).rgb;// original pixel s1.yz -= 0.5; s1.r = 0.3; // erase luma if(c0.x < 1120 && c0.y < 630) return float3(s1.x+1.402*s1.z, dot(s1, float3(1, -.202008/.587, -.419198/.587)), s1.x+1.772*s1.y).rgbb;// SD Y'CbCr to RGB output return float3(s1.x+1.5748*s1.z, dot(s1, float3(1, -.1674679/.894, -.4185031/.894)), s1.x+1.8556*s1.y).rgbb;// HD Y'CbCr to RGB output } |
14th June 2014, 14:42 | #88 | Link |
This works perfectly except when the Chroma-NEDI shader is in the middle, then everything shows as normal, so I cant compare your shader to others. (Luma is included when using your shader, with just RGB-YCbCr-RGB I see chroma.
Also, alot of grey in this chroma, no blacks, is that normal? First frame of a movie for example is grey, it's black when the new value you added is at 0.0 Last edited by FireFreak111; 14th June 2014 at 14:54. |
14th June 2014, 14:59 | #89 | Link |
What I usually do when I want to compare is to add a RGBtoYCbCr shader followed by the chroma only shader post-resize, then I can toggle chromaNEDI on/off by enabling disabling the pre-resize shaders. You could also use it instead of the YCbCrtoRGB shader but that makes it harder to compare.
You see a lot of grey because it fixes the luma to 0.25, if you set it to 0 then it's usually too dark to see anything. |
14th June 2014, 16:01 | #90 | Link |
Using Frozen for chroma investigation, due to the movie's good chroma compression and heavy use of it, especially in the pink cloak constantly used.
NEDI seems to fare well against NNEDI3, except for some blur on distinct edges (pillars, characters lower cloak, reflection, shoes). Jinc3 (not shown) has the same definition here as NNEDI3, so its distinctly NEDI's problem, not an advantage of NNEDI3. NEDI NNEDI3-16 To be fair, NEDI is 2-3x faster then NNEDI3, entire chain taking only 11.7ms on 1080p24 content (at 1080p48 with no SM). Last edited by FireFreak111; 14th June 2014 at 16:04. |
14th June 2014, 17:50 | #91 | Link |
One key difference between NEDI and other chroma upscaling algorithms is that NEDI only makes edges sharp if the luma channel is sharp. Without the luma channel it's hard to tell if NEDI is blurring an edge that it shouldn't or NNEDI3 is sharpening an edge that it shouldn't. Both are very well possible. I also found it interesting that NEDI seems to be better at bringing out detail on the pillars itself.
14th June 2014, 23:45 | #92 | Link | |
Kid for Today
15th June 2014, 01:45 | #93 | Link |
Chroma.rar
Here is some screenshots with Luma shots for NEDI and NNEDI3, Chroma for NEDI, NNEDI3, Jinc3 and Bicubic, compressed into a RAR. This is after disabling the no DXVA copyback option in madVR, which was bluring the Chroma channel (still a blur difference between NEDI and NNEDI3, causing some minor artifacts like the bottom of the character's cloak in the Luma shot) On another note, is it possible to combine the first two shaders, considering there's only a one line difference between them? Functions possibly? Last edited by FireFreak111; 15th June 2014 at 06:30. |
15th June 2014, 16:03 | #94 | Link |
The second shader needs the results of the first one so it's not really easy to do it in just one shader. It would be possible to split them in a slightly different way but I think it will obfuscate the code and it will only be faster because I haven't found a way to make the shader skip processing for a particular pixel.
21st June 2014, 16:23 | #96 | Link | |
Broadband Junkie
__________ Nearest Neighbor Chroma (400% zoom) __________ NEDI Chroma (400% zoom) __________ Catmull-Rom Chroma (400% zoom) __________ NNEDI3 64 Chroma (400% zoom) __________ madVR's YCbCr hack also seems to result in an elevated purplish black level on SD video with the provided YCbCrtoRGB shader as the last step pre-resize. [Edit: This was caused by using a 3DLUT with the YCbCr hack, which I guess must not be supported]. The above images used madVR in normal mode with both RGBtoYCbCr (first step) and YCbCrtoRGB (last step) shaders to workaround this. Last edited by cyberbeing; 21st June 2014 at 16:34. |
21st June 2014, 17:22 | #99 | Link |
There seems to be a mismatch between what the shader thinks the chroma channels are and what they actually are. As a result some part of the chroma channel isn't scaled. Using the RGBtoYCbCr shader will ensure that the colours remain accurate even if it guesses the colour space incorrectly, but instead it will use the shaders on the wrong chroma channels. If you use the YCbCr hack you should get a smooth(er) result but the colours might be inaccurate.
If you use the chroma only shader I posted a few posts back, you'll see that the "chroma" part looks perfectly smooth. Unfortunately it is the wrong chroma channel. Edit: Using the shaders with the YCbCr hack seems to remove all chroma aliasing, and changes the colour. I'm guessing that the BT.601 part of the RGB <-> YCbCr shaders doesn't work correctly. Last edited by Shiandow; 21st June 2014 at 18:07. |
21st June 2014, 19:47 | #100 | Link | |
Broadband Junkie
NVIDIA RGBA to YUVA sample | NVIDIA YUVA to RGBA sample The actual pixel shader portion of these samples seems to be the following, but would need to be made MPC-HC compatible: Code:
#define QUAD_REAL float #define QUAD_REAL2 float2 #define QUAD_REAL3 float3 #define QUAD_REAL4 float4 QUAD_REAL4 ToYUV(QuadVertexOutput IN, uniform sampler2D SceneSampler) : COLOR { QUAD_REAL4 rgba = tex2D(SceneSampler, IN.UV); QUAD_REAL3 ctr = QUAD_REAL3(0,.5,.5); return QUAD_REAL4(rgb_to_yuv(rgba.xyz)+ctr,rgba.w); // don't lose alpha } QUAD_REAL3 rgb_to_yuv(QUAD_REAL3 RGB) { QUAD_REAL y = dot(RGB,QUAD_REAL3(0.299,0.587,0.114)); QUAD_REAL u = (RGB.z - y) * 0.565; QUAD_REAL v = (RGB.x - y) * 0.713; return QUAD_REAL3(y,u,v); } QUAD_REAL4 FromYUV(QuadVertexOutput IN, uniform sampler2D SceneSampler) : COLOR { QUAD_REAL4 yuva = tex2D(SceneSampler, IN.UV) - QUAD_REAL4(0,.5,.5,0); return QUAD_REAL4(yuv_to_rgb(yuva.xyz),yuva.w); // don't lose alpha } QUAD_REAL3 yuv_to_rgb(QUAD_REAL3 YUV) { QUAD_REAL u = YUV.y; QUAD_REAL v = YUV.z; QUAD_REAL r = YUV.x + 1.403*v; QUAD_REAL g = YUV.x - 0.344*u - 1.403*v; QUAD_REAL b = YUV.x + 1.770*u; return QUAD_REAL3(r,g,b); } Last edited by cyberbeing; 21st June 2014 at 19:53. |
chromanedi, nedi, shader, superres, upscaling |
