19th November 2009, 14:34 | #6021 | Link | |
Call Microsoft -- they're the ones who implemented a DirectShow standard and programming API that everyone followed (including FFDSHOW) and then decided to reinvent it in Windows 7 for their own amusement. I'm trying to help you here. As I said in my previous response -- point me to a problematic Region A disc and I will see if I can repeat it and fix it. But honestly, after processing several hundred discs -- I've never seen undersizing like you've reported. Last edited by jdobbs; 19th November 2009 at 14:52. |
19th November 2009, 14:47 | #6024 | Link | |
If you got the message and accidentally decided not to let it execute, the following was added to your INI file: SUPPRESS_FF_WARNING=1 If you delete that flag or set it to "0", BD-RB will show the message again. Last edited by jdobbs; 19th November 2009 at 14:57. |
19th November 2009, 16:35 | #6025 | Link |
@jdobbs
Has there been any more progress on remuxing the troublesome secondary audio files for PiP, as that's about the only thing missing now but it does seem that there are more and more discs using this now and also placing the 'extras' as PiP content rather than standalone? |
19th November 2009, 18:03 | #6026 | Link | |
One other quick thing... before I made this last attempt using 0.31.02, I uninstalled and then reinstalled FDDSHOW x32 & FDDSHOW x64. I did this to reverse any of the changes that the VC-1 FIX posted on this forum might have made to the FDDSHOW settings. I did not uninstall and reinstall AVISYNTH, thinking it was not necessary. Do you think reinstalling FDDSHOW was enough or should I reinstall all the required programs that work with BD-Rebuilder? This small output file problem has cropped up on all my recent attempts to backup various BD's. The latest one I am having this problem with(as you can see in the log) is Region A of SILVERADO. PS:Your idea to incorporate a Registry checker in your next version of BD-Rebuilder is an excellent one. That might be the answer to my problem. Thanks. |
19th November 2009, 20:05 | #6028 | Link |
jodbbs,
I ran GI Joe through again, and the same thing keeps happening. As far as I can tell the only thing BD RB did was resize 6 videos (main movie and 5 trailers). I can't understand why this won't work when the original does. Is BD-Live possibly screwing things up somehow? I'll post the files again so you can see if you can spot anything. I can't imagine there's a problem with the encryption since it works fine on PowerDVD and I wouldn't think it would even let me save it to my computer if it wasn't Decrypted properly. I used DVD Fab to decrypt it. I might try turning AnyDVDHD back on to see if it mentions any problems. But the PS3 doesn't give me any error messages, so I don't think that would be it either. Code:
[Status] LABEL=GIJOE_AC VERSION=v0.31.01 (beta) SOURCE_SIZE=43304787675 SOURCE_VIDEO_SIZE=42750695424 TARGET_SIZE=24117248000 REDUCTION=.551175963696061 RESIZE_1080=0 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=eng; BACKUP_MODE=0 QUICK=1 ENCODE_STEP=0 COMPLETED=6 REBUILD_COMPLETE=1 [01015] AUDIO=1 PGS= M2TS_TARGET=82076786 NSIZE=57931776 FLINK=0 MLINK=0 [01011] AUDIO=1 PGS= M2TS_TARGET=125517847 NSIZE=109418496 FLINK=0 MLINK=0 [01013] AUDIO=1 PGS= M2TS_TARGET=173384966 NSIZE=130062336 FLINK=0 MLINK=0 [01014] AUDIO=1 PGS= M2TS_TARGET=187353970 NSIZE=137238528 FLINK=0 MLINK=0 [01012] AUDIO=1 PGS= M2TS_TARGET=200957240 NSIZE=190291968 FLINK=0 MLINK=0 [01002] AUDIO=1000 PGS=100000 M2TS_TARGET=22938212645 RATE=18718 NSIZE=22094008320 FLINK=0 MLINK=0 [Options] MODE=0 TARGET_SIZE=23000 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=eng; SD_CONVERT=0 COLOR_BOOST=0 RESIZE_1080=0 DTS_REENCODE=1 AC3_REENCODE=1 AC3_640=1 KEEP_HD_AUDIO=1 AVCHD=0 REMOVE_WORKFILES=0 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=1 CUSTOM_TARGET_SIZE=19000 ENCODE_QUALITY=2 [Paths] SOURCE_PATH=D:\GIJOE\FULLDISC\GIJOE_AC\ WORKING_PATH=C:\GIJOESHRINK\ ----------------------- [15:17:28] BD Rebuilder v0.31.01 (beta) - Source: GIJOE_AC - Input BD size: 40.33 GB - Approximate total content: [02:07:57.419] - Target BD size: 22.46 GB - Windows Version: 6.0 [6001] - Audio Settings: AC3=1 DTS=1 HD=1 Kbs=640 [15:17:28] PHASE ONE, Encoding - [15:17:28] Extracting A/V streams [VID_01015] - [15:17:33] Reencoding: VID_01015 (1 of 6) - [15:18:12] Extracting A/V streams [VID_01011] - [15:18:20] Reencoding: VID_01011 (2 of 6) - [15:19:20] Extracting A/V streams [VID_01013] - [15:19:30] Reencoding: VID_01013 (3 of 6) - [15:20:52] Extracting A/V streams [VID_01014] - [15:21:01] Reencoding: VID_01014 (4 of 6) - [15:22:23] Extracting A/V streams [VID_01012] - [15:22:33] Reencoding: VID_01012 (5 of 6) - [15:24:08] Extracting A/V streams [VID_01002] - [15:50:38] Reencoding: VID_01002 (6 of 6) [00:10:50]PHASE ONE complete [00:10:50]PHASE TWO - Rebuild Started - [00:10:50] Rebuilding BD file Structure [00:11:12] - Encode and Rebuild complete [00:11:12]JOB: GIJOE_AC finished. Last edited by jdobbs; 20th November 2009 at 01:49. |
19th November 2009, 20:20 | #6029 | Link |
Ok, I think it has something to do with BD-Live. I put the disc in my PC and turned AnyDVD on and it plays fine in PowerDVD, but if I go into AnyDVD and check "Disable BD-Live" and run PowerDVD it does the same thing as the PS3 does.
Edit: Maybe not exactly the same. The PS3 goes through from title 2 to title 57 then title 4 and locks up on title 1. Power DVD stops at title 57 when it doesn't work. Also, I noticed the video file (paramount logo) that is listed as title 1 on DVDFab doesn't play correctly in Nero Showtime, but the others do. The video plays fine in Windows Media Player and PowerDVD though so I think that is just an issue with Nero. This doesn't really make much sense. Last edited by ChldsPlay; 19th November 2009 at 22:30. |
19th November 2009, 23:01 | #6030 | Link | |
EDIT: I purposely screwed with some settings and got the prompt to come up so that BD-RB would prompt me to change settings - the prompt came up and then confirmed that my settings are now correct so we'll see what happens now. Last edited by Bullet1979; 19th November 2009 at 23:22. |
19th November 2009, 23:56 | #6031 | Link |
Banned
Failed to retrieve audio, aborted???
----------------------- [03:14:07] BD Rebuilder v0.31.02 (beta) - Source: EARTH - Input BD size: 42.95 GB - Approximate total content: [02:45:53.985] - Target BD size: 22.46 GB - Windows Version: 6.0 [6001] - Audio Settings: AC3=1 DTS=1 HD=1 Kbs=640 [03:14:07] PHASE ONE, Encoding - [03:14:07] Extracting A/V streams [VID_00045] - [03:14:08] Reencoding: VID_00045 (1 of 42) - [03:14:10] Extracting A/V streams [VID_00061] - [03:14:13] Reencoding: VID_00061 (2 of 42) - [03:14:27] Extracting A/V streams [VID_00060] - [03:14:30] Reencoding: VID_00060 (3 of 42) - [03:14:42] Extracting A/V streams [VID_00053] - [03:14:52] Reencoding: VID_00053 (4 of 42) - [03:15:24] Extracting A/V streams [VID_00034] - [03:15:36] Reencoding: VID_00034 (5 of 42) - [03:15:36] Reencoding secondary video [TRK_02] - [03:16:22] Extracting A/V streams [VID_00042] - [03:16:37] Reencoding: VID_00042 (6 of 42) - [03:16:37] Reencoding secondary video [TRK_02] - [03:17:33] Extracting A/V streams [VID_00043] - [03:17:49] Reencoding: VID_00043 (7 of 42) - [03:17:49] Reencoding secondary video [TRK_02] - [03:18:46] Extracting A/V streams [VID_00025] - [03:19:03] Reencoding: VID_00025 (8 of 42) - [03:19:03] Reencoding secondary video [TRK_02] - [03:20:00] Extracting A/V streams [VID_00023] - [03:20:15] Reencoding: VID_00023 (9 of 42) - [03:20:15] Reencoding secondary video [TRK_02] - [03:21:11] Extracting A/V streams [VID_00033] - [03:21:28] Reencoding: VID_00033 (10 of 42) - [03:21:28] Reencoding secondary video [TRK_02] - [03:22:27] Extracting A/V streams [VID_00026] - [03:22:44] Reencoding: VID_00026 (11 of 42) - [03:22:44] Reencoding secondary video [TRK_02] - [03:23:45] Extracting A/V streams [VID_00037] - [03:24:03] Reencoding: VID_00037 (12 of 42) - [03:24:03] Reencoding secondary video [TRK_02] - [03:25:04] Extracting A/V streams [VID_00030] - [03:25:23] Reencoding: VID_00030 (13 of 42) - [03:25:23] Reencoding secondary video [TRK_02] - [03:26:26] Extracting A/V streams [VID_00024] - [03:26:46] Reencoding: VID_00024 (14 of 42) - [03:26:46] Reencoding secondary video [TRK_02] - [03:27:53] Extracting A/V streams [VID_00028] - [03:28:12] Reencoding: VID_00028 (15 of 42) - [03:28:12] Reencoding secondary video [TRK_02] - [03:29:19] Extracting A/V streams [VID_00041] - [03:29:39] Reencoding: VID_00041 (16 of 42) - [03:29:39] Reencoding secondary video [TRK_02] - [03:30:44] Extracting A/V streams [VID_00039] - [03:31:04] Reencoding: VID_00039 (17 of 42) - [03:31:04] Reencoding secondary video [TRK_02] - [03:32:19] Extracting A/V streams [VID_00031] - [03:32:40] Reencoding: VID_00031 (18 of 42) - [03:32:40] Reencoding secondary video [TRK_02] - [03:33:51] Extracting A/V streams [VID_00029] - [03:34:15] Reencoding: VID_00029 (19 of 42) - [03:34:15] Reencoding secondary video [TRK_02] - [03:35:34] Extracting A/V streams [VID_00032] - [03:35:57] Reencoding: VID_00032 (20 of 42) - [03:35:57] Reencoding secondary video [TRK_02] - [03:37:20] Extracting A/V streams [VID_00020] - [03:37:43] Reencoding: VID_00020 (21 of 42) - [03:37:43] Reencoding secondary video [TRK_02] - [03:39:08] Extracting A/V streams [VID_00036] - [03:39:34] Reencoding: VID_00036 (22 of 42) - [03:39:34] Reencoding secondary video [TRK_02] - [03:40:57] Extracting A/V streams [VID_00035] - [03:41:27] Reencoding: VID_00035 (23 of 42) - [03:41:27] Reencoding secondary video [TRK_02] - [03:43:03] Extracting A/V streams [VID_00027] - [03:43:31] Reencoding: VID_00027 (24 of 42) - [03:43:31] Reencoding secondary video [TRK_02] - [03:45:08] Extracting A/V streams [VID_00038] - [03:45:36] Reencoding: VID_00038 (25 of 42) - [03:45:36] Reencoding secondary video [TRK_02] - [03:47:14] Extracting A/V streams [VID_00047] - [03:47:38] Reencoding: VID_00047 (26 of 42) - [03:49:07] Extracting A/V streams [VID_00048] - [03:49:32] Reencoding: VID_00048 (27 of 42) - [03:51:10] Extracting A/V streams [VID_00021] - [03:51:42] Reencoding: VID_00021 (28 of 42) - [03:51:42] Reencoding secondary video [TRK_02] - [03:53:28] Extracting A/V streams [VID_00040] - [03:53:58] Reencoding: VID_00040 (29 of 42) - [03:53:58] Reencoding secondary video [TRK_02] - [03:55:50] Extracting A/V streams [VID_00022] - [03:56:25] Reencoding: VID_00022 (30 of 42) - [03:56:25] Reencoding secondary video [TRK_02] - [03:58:27] Extracting A/V streams [VID_00052] - [03:59:07] Reencoding: VID_00052 (31 of 42) - [04:01:17] Extracting A/V streams [VID_00056] - [04:02:02] Reencoding: VID_00056 (32 of 42) - [04:05:22] Extracting A/V streams [VID_00058] - [04:06:04] Reencoding: VID_00058 (33 of 42) - [04:09:26] Extracting A/V streams [VID_00057] - [04:10:11] Reencoding: VID_00057 (34 of 42) - [04:13:39] Extracting A/V streams [VID_00055] - [04:14:25] Reencoding: VID_00055 (35 of 42) - [04:18:03] Extracting A/V streams [VID_00054] - [04:18:50] Reencoding: VID_00054 (36 of 42) - [04:22:07] Extracting A/V streams [VID_00051] - [04:22:56] Reencoding: VID_00051 (37 of 42) - [04:25:52] Extracting A/V streams [VID_00049] - [04:26:43] Reencoding: VID_00049 (38 of 42) - [04:29:48] Extracting A/V streams [VID_00050] - [04:30:46] Reencoding: VID_00050 (39 of 42) - [04:34:03] Extracting A/V streams [VID_00046] - [04:35:17] Reencoding: VID_00046 (40 of 42) - [04:39:30] Extracting A/V streams [VID_00044] - [05:03:47] Reencoding: VID_00044 (41 of 42) - [17:10:13] Extracting A/V streams [VID_00001] - Error in attempt to extract audio/subs. - Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name: G:\BLURAY 50GB\FULLDISC\EARTH\BDMV\STREAM\00001.m2ts - Error in attempt to extract audio/subs. - Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name: G:\BLURAY 50GB\FULLDISC\EARTH\BDMV\STREAM\00001.m2ts [17:11:33] - Failed to retrieve audio, aborted Earth Options: [Status] LABEL=EARTH VERSION=v0.31.02 (beta) SOURCE_SIZE=46112790768 SOURCE_VIDEO_SIZE=45091596288 TARGET_SIZE=24117248000 REDUCTION=.51220305824805 RESIZE_1080=0 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=eng; BACKUP_MODE=0 QUICK=1 ENCODE_STEP=0 COMPLETED=41 [00045] AUDIO= PGS= M2TS_TARGET=18882 NSIZE=12288 FLINK=0 MLINK=0 [00061] AUDIO=1 PGS= M2TS_TARGET=8421307 NSIZE=8251392 FLINK=0 MLINK=0 [00060] AUDIO=1 PGS= M2TS_TARGET=8430748 NSIZE=9007104 FLINK=0 MLINK=0 [00053] AUDIO=1 PGS= M2TS_TARGET=35475856 NSIZE=22892544 FLINK=0 MLINK=0 [00034] AUDIO=1 PGS=1000000000 M2TS_TARGET=36866819 NSIZE=19550208 FLINK=0 MLINK=0 [00042] AUDIO=1 PGS=1000000000 M2TS_TARGET=45467503 NSIZE=22480896 FLINK=0 MLINK=0 [00043] AUDIO=1 PGS=1000000000 M2TS_TARGET=45841993 NSIZE=25559040 FLINK=0 MLINK=0 [00025] AUDIO=1 PGS=1000000000 M2TS_TARGET=46062282 NSIZE=26185728 FLINK=0 MLINK=0 [00023] AUDIO=1 PGS=1000000000 M2TS_TARGET=46112633 NSIZE=25251840 FLINK=0 MLINK=0 [00033] AUDIO=1 PGS=1000000000 M2TS_TARGET=49829211 NSIZE=25141248 FLINK=0 MLINK=0 [00026] AUDIO=1 PGS=1000000000 M2TS_TARGET=51245351 NSIZE=26572800 FLINK=0 MLINK=0 [00037] AUDIO=1 PGS=1000000000 M2TS_TARGET=52456936 NSIZE=26597376 FLINK=0 MLINK=0 [00030] AUDIO=1 PGS=1000000000 M2TS_TARGET=54417502 NSIZE=27709440 FLINK=0 MLINK=0 [00024] AUDIO=1 PGS=1000000000 M2TS_TARGET=56409537 NSIZE=30339072 FLINK=0 MLINK=0 [00028] AUDIO=1 PGS=1000000000 M2TS_TARGET=56761999 NSIZE=32028672 FLINK=0 MLINK=0 [00041] AUDIO=1 PGS=1000000000 M2TS_TARGET=57498391 NSIZE=28729344 FLINK=0 MLINK=0 [00039] AUDIO=1 PGS=1000000000 M2TS_TARGET=61243292 NSIZE=38086656 FLINK=0 MLINK=0 [00031] AUDIO=1 PGS=1000000000 M2TS_TARGET=62804192 NSIZE=31494144 FLINK=0 MLINK=0 [00029] AUDIO=1 PGS=1000000000 M2TS_TARGET=68965970 NSIZE=36052992 FLINK=0 MLINK=0 [00032] AUDIO=1 PGS=1000000000 M2TS_TARGET=71275850 NSIZE=40046592 FLINK=0 MLINK=0 [00020] AUDIO=1 PGS=1000000000 M2TS_TARGET=71634605 NSIZE=39954432 FLINK=0 MLINK=0 [00036] AUDIO=1 PGS=1000000000 M2TS_TARGET=74001131 NSIZE=39192576 FLINK=0 MLINK=0 [00035] AUDIO=1 PGS=1000000000 M2TS_TARGET=84861344 NSIZE=41951232 FLINK=0 MLINK=0 [00027] AUDIO=1 PGS=1000000000 M2TS_TARGET=84955753 NSIZE=50196480 FLINK=0 MLINK=0 [00038] AUDIO=1 PGS=1000000000 M2TS_TARGET=85906140 NSIZE=46891008 FLINK=0 MLINK=0 [00047] AUDIO=1 PGS= M2TS_TARGET=86494624 NSIZE=90034176 FLINK=0 MLINK=0 [00048] AUDIO=1 PGS= M2TS_TARGET=90371698 NSIZE=140931072 FLINK=0 MLINK=0 [00021] AUDIO=1 PGS=1000000000 M2TS_TARGET=93103273 NSIZE=48513024 FLINK=0 MLINK=0 [00040] AUDIO=1 PGS=1000000000 M2TS_TARGET=94126040 NSIZE=49889280 FLINK=0 MLINK=0 [00022] AUDIO=1 PGS=1000000000 M2TS_TARGET=108067142 NSIZE=60610560 FLINK=0 MLINK=0 [00052] AUDIO=1 PGS= M2TS_TARGET=141859366 NSIZE=121165824 FLINK=0 MLINK=0 [00056] AUDIO=1 PGS= M2TS_TARGET=157295281 NSIZE=163209216 FLINK=0 MLINK=0 [00058] AUDIO=1 PGS= M2TS_TARGET=158220492 NSIZE=192116736 FLINK=0 MLINK=0 [00057] AUDIO=1 PGS= M2TS_TARGET=158229933 NSIZE=192012288 FLINK=0 MLINK=0 [00055] AUDIO=1 PGS= M2TS_TARGET=158280284 NSIZE=192221184 FLINK=0 MLINK=0 [00054] AUDIO=1 PGS= M2TS_TARGET=164410593 NSIZE=125190144 FLINK=0 MLINK=0 [00051] AUDIO=1 PGS= M2TS_TARGET=168026468 NSIZE=132986880 FLINK=0 MLINK=0 [00049] AUDIO=10 PGS=0 M2TS_TARGET=187027906 NSIZE=139321344 FLINK=0 MLINK=0 [00050] AUDIO=1 PGS= M2TS_TARGET=207083582 NSIZE=190642176 FLINK=0 MLINK=0 [00046] AUDIO=1 PGS= M2TS_TARGET=272786138 NSIZE=193585152 FLINK=0 MLINK=0 [00044] AUDIO=1 PGS=10000 M2TS_TARGET=5477318495 RATE=15704 NSIZE=5315862528 FLINK=0 MLINK=0 [00001] AUDIO=00000000 PGS= Last edited by jdobbs; 20th November 2009 at 01:48. |
20th November 2009, 00:10 | #6032 | Link | |
I use AnyDVDHD, and BD live works on my backups, so I doubt BD Live is the culprit. |
20th November 2009, 04:10 | #6034 | Link | |
20th November 2009, 04:40 | #6035 | Link | |
I know the burn isn't bad since I've made about 5 discs. All other movies I've burnt have worked fine, and all on the PS3. I didn't use AnyDvdHD originally, I used DVDFab, but changing the settings of BD-Live on AnyDvdHD while the BD-R was in the PC caused a similar issue on PowerDVD. Another poster said his worked fine on his PS3, so there has to be some setting somewhere that I'm missing. Last edited by ChldsPlay; 20th November 2009 at 04:47. |
20th November 2009, 05:26 | #6036 | Link |
Not luck with Windows 7 64 Bit
New to Blu Ray backup not flaming but no luck with this program on Windows 7 64 bit. Had the audio sync problem with 301 and crashes with 302. Tried to cleanup codecs and reinstall them but now no go at all. Runtime error 53 could not find valid path for required tools x264.exe, tsmuxer.exe, wavi.exe, aften.exe, decomb.dll, mkvmerge.exe, recommend reinstall all included files. This is over my head. Not ready yet.
20th November 2009, 06:58 | #6038 | Link |
@rippn
Hi! Please carefully read the following post: http://forum.doom9.org/showpost.php?...postcount=6001 |
20th November 2009, 14:59 | #6039 | Link | ||
20th November 2009, 15:25 | #6040 | Link |
Speaking of the new version of x264, jdobbs. I just did 3 different flix (all full backup some MPEG 4 some VC-1, some BD-9 some BD-25) on 2 different 'puters (one XP & one Vista) using 31.02 and ALL of them show SEVERE "pixelation" on the main title when played back on my Oppo!
I think you know what I mean, when the scene is not moving, it looks OK, but as soon as something moves, the moving element "breaks up". The menus on the discs look good, prolly 'cause they haven't been recoded. Everything has been perfect in the "quality department" until this release, so logically, it's the new version of x264. I went back to 31.01 & am re-running 2 of the backups which complete later today. I'll let you know what happens. |
