24th April 2008, 15:58 | #1201 | Link | |
Caped Crusader
24th April 2008, 16:33 | #1202 | Link | |
I use this settings for 720p videos: When I can, I try the 1.8.3 Version.. without supread step. B4tm4n, you and me have the same TV ;-) |
24th April 2008, 17:11 | #1204 | Link |
Roman, i dont understant the SPlit'n Cut, i've done this to cut 30 secons in the start and 60 secons in the end:
Tjis is the Meta file: Code:
MUXOPT --no-pcr-on-video-pid --new-audio-pes --blu-ray --vbr --auto-chapters=5 --cut-start=30s --cut-end=60s --vbv-len=500 V_MPEG4/ISO/AVC, "F:\Filmes\Battlestar.Galactica.Miniseries.2003.Part.1.720p.HDDVD.x264-SiNNERS.mkv", level=4.1, insertSEI, contSPS, track=2, lang=eng S_TEXT/UTF8, "F:\Filmes\Battlestar.Galactica.Miniseries.2003.Part.1.720p.HDDVD.x264-SiNNERS.mkv",font-name="Times New Roman",font-size=60,font-color=0x00FFFFFF,font-charset=1,bottom-offset=48,font-border=1,text-align=center,video-width=1280,video-height=720,fps=23.976, track=1, lang=por A_AC3, "F:\Filmes\Battlestar.Galactica.Miniseries.2003.Part.1.720p.HDDVD.x264-SiNNERS.mkv", track=3, lang=eng |
24th April 2008, 17:18 | #1206 | Link |
Caped Crusader
I might have been premature in saying the subs where working on the PS3. I think the file with subs working was run through tsMuxer twice, first time as srt subs ( not working ) then the second time as the m2ts file with pgs graphics ( which worked ).
http://www.divshare.com/download/4338811-c14 |
24th April 2008, 17:53 | #1208 | Link | |
Caped Crusader
@Roman I just started from scratch with 1.8.3. First srt with video and no subs, then I put the m2ts from that folder through tsMuxer again and I've got perfect subs. No black lines going off in any direction, just need to find the optimal offset from the bottom of my screen. Thanks alot, again, for your hard work. Heres the working sup: http://www.divshare.com/download/4339459-2df Last edited by B4tm4n; 24th April 2008 at 19:01. |
24th April 2008, 19:06 | #1209 | Link |
Solutions For Joining and Streaming Multiple .m2ts Blu Rays
I have been working on this for quite some time now, and the process has been hit and miss. The title that I am currently stumped on is Walk Hard. My goal is to join the multiple .m2ts files together so they will stream to my PS3 or Tvix 6500. At this point the audio goes out of sync around 20 minutes in. I joined the files with tssplitter first and then ran them through tsmuxer (didn't work), and then ran the joined file through tsmuxer again and it didn't work. I have also tried a combination with tsmuxer and tsremux and nothing seems to work. I have seen that some have gotten this title to work on the PC, but has anyone been able to stream it successfully to the PS3 or other media extender such as the Tvix 6500. Thanks in advance.
24th April 2008, 19:16 | #1210 | Link |
sidekick
@ maya: load the first m2ts into tsmuxer and append the rest. should work (at least for popcorn hour).
Titles I've tried succesfully: pirates 3, kingdom of heaven, departed, starhsip troopers, resident evil and some more which I can't remember right now some are h264, some are vc1. no problems so far...
greets, kurt. Pioneer PDP-427 XA | Popcorn Hour NMT C-200 | Sony STR-DB 840 QS | Canton Ergo 91 DC |
24th April 2008, 19:58 | #1213 | Link | |
I have made a working backup on a BD-R disc that plays in my Panasonic BD30. You will have to downconvert True-HD to AC3, which sucks, but apparently subtitles are more important than having the audio working first. |
24th April 2008, 20:15 | #1215 | Link | |
24th April 2008, 20:21 | #1216 | Link | |
Caped Crusader
http://forum.doom9.org/showthread.php?t=125966 |
24th April 2008, 20:46 | #1217 | Link |
@Maya...
Please see my post on page 41. Try this: Demux streams you want with tsmuxer/evodemux Use VC1CONV/H264INFO on the video stream Remux video & audio with tsmuxer Try it. It worked for me on Cars (28 files) Mike |
24th April 2008, 21:27 | #1218 | Link | |
This will automatically open all related .m2ts files and treat them as one file. |
24th April 2008, 23:16 | #1220 | Link |
I posted this in another thread, but it seems maybe I should of posted it it and can get more help (I hope).
Ok. here is the issue I'm having. First I demuxed the MKV to get the .264 and the .DTS file. Then I loaded up my MKV into MeGUI using the the following avs script; DirectShowSource("e:\video.mkv",fps=23.9760431376968,audio=false) addborders(0,16,0,16) Got the new .264 file, and used TSMuxer to load the DTS file and the new 264 file. Tried to make a Blu-Ray disc and a .m2ts file, both times I get video but no audio. Tried playing with PowerDVD, GOMPlayer and VLC. I do have a 1-2sec grey flicker at the beginning of the video, but its fine the rest of the way. Something I'm doing wrong? I haven't tried it in my PS3 yet. --- In the other thread, it mentioned to try to have both files in the same directory. However, I did have them in the same dir. |
tsmuxer |
