23rd October 2013, 16:33 | #12701 | Link |
Most likely Placebo + CQ mode with insanely low CRF value. I think it would be faster if you just copied entire movie without re-encoding. 33Mbps !?!? Similar bitrate can be found on original BD movies.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 23rd October 2013 at 16:40. |
23rd October 2013, 17:22 | #12702 | Link |
I'm encoding using the Hi10P, Slower profile with a CRF of 18
For TV shows (Like whats being encoded in that screenshot) I will sometimes not see much of a space savings. Using the same preset with typical movies I'll get a movie that takes up half as much space or better than the original. Some might think these settings overkill, and they may well be. What I can say is that using these settings, I have yet to find a source that isnt faithful to the original, and yet still often nets a substantial savings in space. Most of the titles I've encoded with this profile (Now at about 300) are in the 8-15Gb range from their original 20-35GB sources. When building a reference library, I'll err to the side of caution and conservatism in regards to impacts on image quality over the increase in speed. Last edited by Metaphor; 23rd October 2013 at 17:28. |
23rd October 2013, 17:26 | #12703 | Link |
Hello,
I've been using ripbot for years now and have never had any problems that I couldn't figure out myself, but I'm completely stomped on my current issue. I can't get distributed encoding to work with my DVD (.vob) files. It works with everything else I have mkv, m2ts, etc. I have two computers and it works on the host computer but not the remote. The remote server just keeps starting and stopping getting this error. error: MPEG2Source: Could not open on of the input files. (\\SIFU-PC\RipBot264temp\job1\Chunks\91.avs, line 6) x264 [error]: could not open input file`-' Again distributed encoding works great with my mkv and m2ts files. Can anyone help? SiFu |
23rd October 2013, 19:45 | #12707 | Link |
I had removed the job . I started a new one and getting same error. Here is script...
#MT #VideoSource LoadPlugin("\\SIFU-PC\Ripbot264temp\Tools\dgindex\DGDecode.dll") video=MPEG2Source("\\SIFU-PC\RipBot264temp\job2\Chunks\job2.d2v") #Deinterlace #Decimate #Crop #Resize #Colors #Denoise #Subtitles #AudioSource audio=BlankClip(video, audio_rate=48000, channels=8) audio=ResampleAudio(audio,48000) #DownMix Import("\\SIFU-PC\Ripbot264temp\Tools\AviSynth plugins\Scripts\DownMixAudio.avs") audio=DownMix2Stereo(audio) #Delay audio=DelayAudio(audio,0) #Tempo #Normalize #AudioDub audio=ConvertAudioTo16bit(audio) AudioDub(video,audio) #Triming #AVSameLength Trim(8640,10079) #ColorSpace Last edited by sifulee; 23rd October 2013 at 19:49. |
23rd October 2013, 20:40 | #12708 | Link |
max. number of cores
Hi Atak,
recently I upgraded to a dual-socket system with two Xeon E5-2470; hence 32 logical cores. While using Ripbot the taskmanager shows that the average cpu usage is round about 25%; regardless the mode (1- or 2-pass). So maybe you can tell me if there is a limit according the # of cores of if the mistake had to found elsewhere? Best regards |
23rd October 2013, 20:44 | #12709 | Link |
show us your script
23rd October 2013, 20:54 | #12710 | Link | ||
Here is what I found
job1.ini Quote:
23rd October 2013, 21:58 | #12711 | Link |
resizer is single threaded hence you most likely have bottle neck.
workaround? use distributed encoding mode with 4 servers.
25th October 2013, 12:03 | #12714 | Link |
I would like to see this file \\SIFU-PC\RipBot264temp\job2\Chunks\job2.d2v as well
26th October 2013, 19:51 | #12716 | Link |
I was wondering if there is a setting so that ripbot only encodes the file selected from a dvd file and doesn't combine all of the VOB's? I'm trying to get separate episodes encoded as separate files instead of having all of the episodes joined together into 1 continuous mp4.
I'm also having problems selecting language audio. When I preview the video it's using the French voice overs and can't seem to find a way to select which language audio to use. Thanks! Last edited by MK1234Tfan; 26th October 2013 at 21:51. |
26th October 2013, 22:28 | #12717 | Link |
just rename .vobs and files won't be joined.
26th October 2013, 22:32 | #12718 | Link |
try windows 7 codec tweaker by clsid
27th October 2013, 14:45 | #12720 | Link |
have you tried switching audio stream in combobox ?
