22nd October 2007, 10:33 | #2281 | Link |
Slightly OT...
Is SF's shell service down? I can't connect to shell.sourceforge.net anymore...
Edit: Thx for confirmation, Haruhiko! Edit2: It's working as of now! Last edited by fastplayer; 22nd October 2007 at 16:20. |
22nd October 2007, 20:58 | #2283 | Link |
sidekick
Is there a way to decode *.jpg files with ffdshow? Cause I would like to watch my vacation pics on TV with some sharpenfilter (or something similar).
At present it looks like that on my system:
greets, kurt. Pioneer PDP-427 XA | Popcorn Hour NMT C-200 | Sony STR-DB 840 QS | Canton Ergo 91 DC |
22nd October 2007, 22:15 | #2284 | Link | |
Software Developer
Maybe the "Color Space Converter" won't even be needed then ...
22nd October 2007, 22:46 | #2285 | Link |
You could use Irfanview. That has a sharpen filter.
MPC-HC 2.2.1 |
23rd October 2007, 08:08 | #2286 | Link | |
sidekick
thx for the tip, but I don't see an option for sharpening on the fly (e.g. slideshow) with Irfanview. @ mods: if this is way too OT, feel free to place it somewhere else
23rd October 2007, 08:28 | #2287 | Link | |
ffdshow/AviSynth wrangler
(Or you could run DbgView from Sysinternals and look if any messages turn up in it...)
now playing: [artist] - [track] ([album]) |
23rd October 2007, 09:14 | #2288 | Link | |
sidekick
(I can't remember what I changed exactly) - thank you all. unfortunately seesaw scipt in avisynth dialog doesn't seem to work... but sharpen should be enough for the moment
greets, kurt. Pioneer PDP-427 XA | Popcorn Hour NMT C-200 | Sony STR-DB 840 QS | Canton Ergo 91 DC Last edited by kurt; 23rd October 2007 at 09:19. |
23rd October 2007, 12:13 | #2289 | Link |
I haven't ever used SeeSaw, but given that all kinds of other filters and scripts work I can't think of a reason why SeeSaw wouldn't...
23rd October 2007, 12:27 | #2290 | Link | |
sidekick
SeeSaw does work in avisynth dialog for videos. But not for jpgs (at least here)
23rd October 2007, 13:24 | #2291 | Link |
Since a jpg can be considered as a movie with a length of just 1 frame, any filter that need multiple frames to work on, won't work. I dunno if that applies to SeeSaw.
MPC-HC 2.2.1 |
23rd October 2007, 14:50 | #2292 | Link |
SeeSaw requires YV12 as input, because of MaskTools. The decoder probably delivers the JPGs as YUY2 or RGB, so you've to use ConvertToYV12() before SeeSaw. While you're at it, set 'sootheT=0', because temporal soothing makes no sense for single image sequences.
23rd October 2007, 15:57 | #2293 | Link | |
sidekick
A ConvertToYV12() is not needed, if one is limiting colorspaces to yv12 in avisynth dialog for the hint, Didée!
23rd October 2007, 18:40 | #2294 | Link | |
Software Developer
2. Add all the files you want to view 3. Choose "Work as: Batch conversion" 4. Choose the output directory as you like it 5. Check "Use Advanced Options" and click "Advanced" button 6. Under "Other Options" (right side) check "Sharpen" 7. Click "Okay" and "Start Batch" 8. Use "File" -> "Slideshow" as usual (from output directory)
23rd October 2007, 18:59 | #2295 | Link |
sidekick
@ Lord_Mulder: yup, I'm aware of batch-processing. I have Paintshop Pro installed and could do this also with it. But I don't want to convert my pics (they are sharpen enough) - the TV is the problem. For my taste the pics on TV could be a bit sharper, this is why I asked for ffdshow.
Regarding Irfanview: I thought maybe it has an option to enable some sharpen filters during slideshows, but this seems not the case. Now I will try, wich filter in ffdshow (sharpen, seesaw..) is satisfying - if I find some time (reminder: this is all about JPGs - with videos I don't have any sharpening problems on my TV because of SeeSaw) Edit: hmmm, maybe batch processing is really easier (and faster in the end) to handle since mpc/ffdshow/seesaw is not specially made for playing back images (and it takes a lot of cpu time switching between the pics). Convert the pics you want to use for a slideshow and just delete them later .... I have to reconsider
greets, kurt. Pioneer PDP-427 XA | Popcorn Hour NMT C-200 | Sony STR-DB 840 QS | Canton Ergo 91 DC Last edited by kurt; 23rd October 2007 at 19:23. Reason: second thoughts |
23rd October 2007, 23:08 | #2296 | Link |
Angel of Night
Well, you should really use SeeSaw after resizing, so high-res shouldn't be a problem done properly. But yeah, it's best to batch convert everything into a folder, sized directly to the screen's dimensions, to get the best quality at a good speed.
24th October 2007, 06:05 | #2297 | Link |
sidekick
jup, I tried lanczosresize(1024,768) yesterday and it suited well on my CRT TV - but it is still very slow (P4, 2 ghz, 512 MB RAM)...
greets, kurt. Pioneer PDP-427 XA | Popcorn Hour NMT C-200 | Sony STR-DB 840 QS | Canton Ergo 91 DC Last edited by kurt; 24th October 2007 at 06:08. |
24th October 2007, 10:45 | #2298 | Link | ||
'on movie file name match with preset name' is checked by default and unless users uncheck it, the preset doesn't load. Too late but isn't it better to add an option to select OR/AND and make OR the default? The dialog would require a radio button *On all conditions match (AND) *On one of the conditoins match (OR) |
24th October 2007, 11:01 | #2299 | Link |
Or maybe uncheck 'on movie file name match with preset name' by default. I don't think many people are actually using that condition.
MPC-HC 2.2.1 |
