30th January 2013, 14:51 | #12081 | Link |
I want to confirm something. Does eac3to still need to decode TrueHD/DTSMA (-> wav,flac) in order to fix audio gaps?
3rd February 2013, 01:23 | #12083 | Link |
French Love
Hi all and madshi,
I wanted to know if others have had the same problem as me for demuxing 3D Bluray PGS subtitles tracks (.sup) and if an update will fix this problem ? Thanks
2013-11-29 MVC Player Free v0.0.2.6 BD & 3D BD's Player, Demuxer v0.0.0.8b, Recoder. Tutorial Demo for MVC Player Free: Trailer 3D 3DBD's Free - v0.0.0.0005.exe Old Programing free for all. Last edited by frencher; 6th February 2013 at 00:02. |
4th February 2013, 15:19 | #12084 | Link |
I have a strange problem. I am trying to demux a playlist file.
With BDinfo there is show the correct lenght of the movie. But eac3to shows a wrong value and does a wrong demux. eac3to adds the same stream multiple times to the demuxed file. mpc-hc is playing the playlist fine. Last edited by XadoX; 4th February 2013 at 15:22. |
6th February 2013, 07:25 | #12089 | Link |
eac3to.exe g:\BDMV\PLAYLIST\00000.mpls 1) 00000.mpls, 0:21:26 [0+0+0+0+8].m2ts - VC-1, 1080i60 /1.001 (16:9) - DTS, German, stereo, 48kHz - DTS, English, stereo, 48kHz Code:
eac3to.exe g:\BDMV\PLAYLIST\00000.mpls 1) M2TS, 1 video track, 2 audio tracks, 1 subtitle track, 1:30:00, 60i /1.001 1: VC-1, 1080i60 /1.001 (16:9) 2: DTS, German, 2.0 channels, 384kbps, 48kHz 3: DTS, English, 2.0 channels, 384kbps, 48kHz 4: Subtitle (PGS), German |
6th February 2013, 13:18 | #12092 | Link | |
There are also a strange FILES info (same file used 4 times) in your bdinfo.txt: Code:
FILES: Name Time In Length ---- ------- ------ 00000.M2TS 0:00:00.000 0:01:31.991 00000.M2TS 0:01:31.991 0:08:43.856 00000.M2TS 0:10:15.848 0:10:26.092 00000.M2TS 0:20:41.940 0:00:43.243 00008.M2TS 0:21:25.183 0:00:00.333
6th February 2013, 13:26 | #12093 | Link |
Such playlists (using defined sub-sections of m2ts files) are perfectly legal, according to the Blu-Ray spec, but they're only very very rarely used in real life. As a result eac3to always uses the full m2ts files, ignoring the "Time In" and "Length" information in the playlist.
6th February 2013, 13:27 | #12095 | Link |
Looks like having an M2TS file in a playlist does not necessarily mean to play the whole M2TS file, but possibly only several ranges in them (e.g. skipping some "Director's Cut" scenes)?
6th February 2013, 13:28 | #12096 | Link | |
Any chance of a workaround? Last edited by XadoX; 6th February 2013 at 13:31. |
6th February 2013, 13:59 | #12097 | Link |
Support for playlists with sub-sections of m2ts files is not planned for eac3to anytime soon. Implementing that would not be as easy as it might sound. An m2ts file consists of many different streams, all with their own timestamps. So figuring out which streams to cut when and where is not straightforward, especially because after a cut you want to start with a key frame and there's no guarantee that the "Time In" position in the playlist points to a key frame.
6th February 2013, 14:00 | #12098 | Link | ||
eac3to.exe g:\BDMV\STREAM\00000.m2ts + g:\BDMV\STREAM\00008.m2ts
6th February 2013, 14:06 | #12099 | Link |
The playlist references the 00000.m2ts file 4 times, so it's correct that eac3to shows [0+0+0+0+8]. The key problem is that the playlist doesn't want the whole 00000.m2ts file 4 times, instead it wants 4 different subsections of 00000.m2ts, and that's not supported by eac3to at the moment. I don't know how long 00000.m2ts and 00008.m2ts are exactly, but I suppose that the playlist doesn't cover the whole 00000.m2ts and 00008.m2ts files, but just a part of them. That's why using "eac3to 00000.m2ts+00008.m2ts" produces a wrong length, too.
eac3to |
