15th January 2013, 02:14 | #16901 | Link | |
15th January 2013, 02:45 | #16903 | Link | |
On your problem, try different driver versions, older ones. That's other problem with XP, Nvidia and AMD don't give a f*ck about XP anymore and the drivers are shit. |
15th January 2013, 02:48 | #16904 | Link |
Has anyone noticed a problem with deinterlacing using dxva?
I am running the latest catalyst drivers with my Radeon 6800, but for some reason the only way I can get deinterlacing to work is by forcing it using lav videos option. If i have ffdshow dxva or the windows decoder, deinterlacing just doesn't turn on despite the control panel settings. This only happens with h264. Not mpeg2. Seems like Madvr isnt passing the info on that the video needs to be deinterlaced. How can i troubleshoot? I already reset madvr settings and uninstalled/reinstalled. I have also changed the deinterlacing settings in madvr, even when assuming a file is interlaced, it does not work unless forced in lav. EDIT* With EVR as renderer, deinterlacing works fine with other decoders. |
15th January 2013, 02:48 | #16905 | Link | |
A few years ago now, the resampler in ReClock was changed from SSRC to Libresample, which uses a lot less CPU power, but does not sound as good in my opinion. For many (most?) people there is probably no difference though.
The file I linked to is the older SSRC resampler, compiled to work with the current version of ReClock. Back when dual core CPUs were common and you had to use CPU decoding with madVR, ReClock's CPU usage could be a problem. Now that both madVR and LAV Video support DXVA decoding, and much faster quad core CPUs are common, the CPU usage of SSRC resampling is less of an issue. If you change it away from "Auto (best)" and don't lock it, it will reset back to Auto when you play another file. So it probably doesn't make a difference whether you lock it or not, if you are using Auto anyway. Quote:
Is this with DXVA Native or Copy-Back in LAV? I seem to recall having issues with DXVA Native. Last edited by 6233638; 15th January 2013 at 02:55. |
15th January 2013, 06:15 | #16906 | Link |
Does anyone have trouble getting any version of MadVR to work on a monitor in portrait mode? Landscape works like a charm but when dragging MPC-HC over to the portrait screen or even starting the video in the portrait screen causes the video to freeze. Every other renderer works fine.
15th January 2013, 08:49 | #16907 | Link | |
15th January 2013, 09:21 | #16908 | Link | |
15th January 2013, 09:59 | #16909 | Link | |
15th January 2013, 10:32 | #16913 | Link |
Appologies glc650 - I misread what you asked. As Jong said, there is currently no way of decoding the full DTS-HD MA with feeware software. The Arcsoft dtsdecoderdll.dll file however will be called on my LAV if it exists to solve this issue.
15th January 2013, 11:21 | #16914 | Link | |
So my main operating system is still winxp. And I allso love old things the best By the way, I have tried all of the older drivers i can use with the 670gtx graphics card. But I cant go any lower than 300 series of drivers since my graphics card is to new. But the same drivers works good with the Geforce620. So I dont know... Its not a WinXp issue and not a drivers issue, it must be something else i think hmmmm. The screen is completely black and MPC-HC hangs for about 1 minute then laggy pictures with choppy sound, just like my pc was some old pentium or something. Thanks for the answers But I dont think I can find the solution by myself, think I have tried it all. |
15th January 2013, 12:52 | #16915 | Link |
I have 2 monitors which are connected to different GPU. My first screen is connected to a Nvidia card and the second one to an Intel card. Whenever I switch my MPC-HC window to my second screen with the Intel GPU the 1080i clip I'm watching is stuttering. Is it possible to make madVR use the Nvidia card even if it is on the second monitor with Intel GPU? Thanks! (This only seems to happen with 1080i content btw!) |
15th January 2013, 14:22 | #16917 | Link | |
15th January 2013, 16:40 | #16918 | Link | |||
Drive mode sets the refresh rate used with PAL (50Hz) signals. Drive Mode 1: 75Hz - only suitable with films. Drive Mode 2: 100Hz - suitable for film and video content Drive Mode 3: 60Hz - Stupid The reason for this is the Plasma image quality gets worse the higher the refresh rate goes, and running at 50Hz natively flickers too much. Realistically though, this should always be set at 2, unless you never watch anything other than film sources. To enable 72Hz with 24p playback, you need Film Mode set to Advance. I thought madVR was using Direct3D. Best to leave it on Auto. |
15th January 2013, 17:19 | #16919 | Link | |
Using the Microsoft or FFDSHOW dxva decoders, you can't "force" deinterlacing. Only in the control panel settings can you change the deinterlacing setting and this does not work with madvr Strange huh? Never had this issue before with madvr |
15th January 2013, 17:24 | #16920 | Link | |
