Old 19th October 2009, 12:31   #8781  |  Link
htpc66
Originally Posted by albain View Post
Merci pour les encouragements, il reste du boulot :-)
@Xonar owners
Can someone confirm me that with Total Media Theatre + a Xonar, you can play a M2TS file with a TrueHD streamin bitstream mode ?
I need to know this answer in order to go further
Thanks
TMT version for Asus Xonar delivers unmolested Truehd OR Dts-hdma ("bitstream") from a M2TS2 file only and only if a Blu-ray disk structure exists.
htpc66 is offline   Reply With Quote
Old 19th October 2009, 13:51   #8782  |  Link
SamuriHL
SamuriHL's Avatar
Yea, the Xonar won't play nice uniless you're in a BD structure. No bitstreaming for files or HD DVD structures. I've uninstalled my Xonar. It's still in the machine but I uninstalled the driver and have been using only the 5870 for the past week or so.
Old 19th October 2009, 18:54   #8783  |  Link
albain
Media Control author
OK then how could we put a TrueHD sample in a bluray structure ?
I don't want to tell here what I'm gonna do but is there a way to get a TrueHD sample with a simple bluray structure that is playable in bitstream in both MPC and TMT ?
Is it the same issue with powerdvd ?
albain is offline   Reply With Quote
Old 19th October 2009, 18:56   #8784  |  Link
SamuriHL
SamuriHL's Avatar
Yes, all the commercial players are going to have the same problem. And sure, just take the m2ts file and use tsMuxer to create a BD folder structure. Then use ImgBurn to make an ISO. In fact, some of the testing I've done for you has been on movies exactly like this. With MPC-HC I just open the 0001.m2ts file directly from the stream folder.
Old 19th October 2009, 19:05   #8785  |  Link
mrcorbo
Run the .m2ts file through tsMuxeR selecting the option to output "Blu-ray disk".
mrcorbo is offline   Reply With Quote
Old 19th October 2009, 19:28   #8786  |  Link
Skinleech
A.K.A Mangoat
You don't even need to make an ISO - not for TMT anyway. I guess you will for PowerDVD though.
Skinleech is offline   Reply With Quote
Old 19th October 2009, 19:43   #8787  |  Link
albain
Ok thanks
I'll come back to you when I'll finished my "tool"
Old 19th October 2009, 21:45   #8788  |  Link
tal.aloni
@clsid,
All is well with rev. 3109, your efforts are much appreciated!
Tal
tal.aloni is offline   Reply With Quote
Old 20th October 2009, 00:47   #8789  |  Link
Blight
Software Developer
Blight's Avatar
There is some missing documentation for the COM interface (IID_IffDecoder).
How do you control asharpen and swscaler sharpening through code? The parameter values are missing from the docs.
Yaron Gur
Zoom Player . Lead Developer
Blight is offline   Reply With Quote
Old 20th October 2009, 19:22   #8790  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Originally Posted by LoRd_MuldeR View Post
Similar problem here with latest ffdshow build by clsid. DVBViewer will crash at application exit:
http://pastie.org/659774
Program received signal SIGSEGV, Segmentation fault.
[Switching to thread 3684.0x12b0]
0x6fd844ff in thread_func@4 () from D:\ffdshow\libavcodec.dll
Resolved with ffdshow r3109.
Old 21st October 2009, 01:56   #8791  |  Link
leeperry
Kid for Today
Originally Posted by Dark Shikari View Post
Why not? Float decoding support was recently added to the API and for various other codecs--and in most cases it's faster, too.
well, I've tried to signup to the ffmpeg user list from 2 different email adresses(gmail/live.com)...I never got any confirmation...
and what is it about 24bit FLAC in ffdshow? I was told that it would trim to 16bit, not too sure actually: http://lists.mplayerhq.hu/pipermail/...ne/007816.html
Old 21st October 2009, 12:47   #8792  |  Link
cc979
Curious BetaTester
@leeperry for mailing lists i use nabble.com, it works fine for me
Asrock N68-S AMD Athlon(tm) II X4 620 Processor (2.6GHz) - Crucial 2GB PC6400 800MHz DDR2 - Nvidia 9600GT
Tools: ProcessExplorer & ProcessMonitor - BatchCompressor
Guide: MinGW Compiling GCC
cc979 is offline   Reply With Quote
Old 21st October 2009, 13:33   #8793  |  Link
THX-UltraII
hmmmm, two days since Albain was here with his last post. He must be coocking on something very exciting!
THX-UltraII is offline   Reply With Quote
Old 21st October 2009, 13:46   #8794  |  Link
SamuriHL
SamuriHL's Avatar
He's working on a tool to return what your driver supports for bitstreaming.
Old 21st October 2009, 20:03   #8795  |  Link
albain
Hi, not only that (this is tool #1) : the other stuff and goal is to grab a bitstream stream for TrueHD/DTS-HD/EAC3/... to get to know its format and for now it sounds promissing !
Old 21st October 2009, 20:09   #8796  |  Link
SamuriHL
SamuriHL's Avatar
Nice!! Does this mean I have to reinstall my Xonar so I can bitstream some stuff with your new toy?
Old 21st October 2009, 20:41   #8797  |  Link
Skinleech
A.K.A Mangoat
Great stuff albain - just let us know when you need us for testing.
Old 21st October 2009, 21:06   #8798  |  Link
Jeremy Duncan
Didée Fan
Jeremy Duncan's Avatar
Originally Posted by Jeremy Duncan View Post
To the two fellows who said this patch doesn't work for them. They are using SEt's avisynth and mt dll's.
I suggest they try the patch with the ffdshow version SEt made the patch for, and using my July 23rd avisynth and mt dlls.
Then if it still doesn't work for them then we wait for leak to post his patch, but his two week vacation ends on friday.
I will say the SEt patch works fine for me if I use the ffdshow version SEt made the patch for.
Please add SEt's patch to the ffdshow svn. This is very rough to wait for Leak and how do we know he will add a patch?
Nothing is certain in this life and we have a working patch ready to go. Add the SEt patch and when leak adds his patch remove SEt's version.
dlls
Still nothing from Leak. May I ask clsid to make, and post here, a current ffdshow with the patch I need (see quote)?
Nothing official for the svn, but more of a favor.
link
When I get tired during work with dvd stuff i think of River Tamm (Summer Glau's character). And the beauty that is Serenity.
Jeremy Duncan is offline   Reply With Quote
Old 21st October 2009, 21:44   #8799  |  Link
XhmikosR
Here is a generic patched build using that patch (use at your own risk), although I don't even know what that patch does, just to save some time from clsid.
link
My Specs
XhmikosR is offline   Reply With Quote
Old 21st October 2009, 21:58   #8800  |  Link
blackEyEz
Awesome, good work I am having my Ati 5750 in my shopping basket and untill bitstreaming is possible then its a instant buy
blackEyEz is offline   Reply With Quote
