19th January 2013, 11:10 | #17041 | Link | |
Raven RVZ01 * i7-4790k * 16GB RAM * Zotac GTX 970 4G * SSD 850Evo 500GB * Blu-Ray Burner Slot-In * PSU SFX 80+ Gold 450Watt * Windows 10 64bit * MPCHC+MadVR+SVP * Panasonic 50" VT30 ^^ |
19th January 2013, 11:28 | #17042 | Link |
Too much demands energy.
Win7x64 Core i7 920 3.5GHz Noctua NH-D14/ArcticCooling MX-3 6(3x2)GB Transcend 1426MHz RoyalHD (64MB)[Solo6c][JPLAY]/HD7850DC22GD5V2[EIZOT965] Seasonic X-750 VelociRaptor WD4500HLHX/16TB_STORE |
19th January 2013, 13:01 | #17043 | Link |
Folks,
regarding upscaling 2k to 4k, please check this review of Sony VW1000ES 4k projector. In the middle of the page, reviewer David Mackenzie shows 2k to 4k upscaling results and compares 3 situations: Upscaling OFF, Sony Reality Creation ON and Oppo BDP-103 upscaling ON. http://www.hdtvtest.co.uk/news/sony-...ture%20Quality The ultimate question is: Can madVR using JINC (3/4/8) beat these techniques in terms of upscaling artifacts and clarity? ( supposing we have sufficient hardware in the HTPC ). Thanks
__________________ System: Intel Core i5-6500, 16GB RAM, GTX1060, 75" Sony ZD9, Focal speakers, OS Win10 Pro, Playback: madvr/JRiver |
19th January 2013, 13:39 | #17044 | Link |
I'm also curious about the comparison regarding SD to 4K scaling, the pixel gap is sooo huge that it should be easy to tell the difference between a good and a less good scaler. That said, in Jinc I trust
Raven RVZ01 * i7-4790k * 16GB RAM * Zotac GTX 970 4G * SSD 850Evo 500GB * Blu-Ray Burner Slot-In * PSU SFX 80+ Gold 450Watt * Windows 10 64bit * MPCHC+MadVR+SVP * Panasonic 50" VT30 ^^ Last edited by AndreaMG; 19th January 2013 at 13:42. |
19th January 2013, 15:22 | #17045 | Link | |
The problem is that those are photographs, and LCoS is rather soft, which helps smooth things out, so you can't really compare those images with screenshots. I would definitely be interested in seeing a comparison on a 4K native display though. I did try creating a similar pattern though, and this is the result with Jinc 3 AR: What I also noticed when doing this though, is that if the source image is not a multiple of 8, madVR does not seem to resize it correctly. "Double Size" in MPC-HC with a 112x128 source: "Double Size" in MPC-HC with my original 113x131 image: |
19th January 2013, 19:20 | #17048 | Link |
do you have any suggestions which setting better to disable or enable in CCC, starting from default values?
19th January 2013, 19:54 | #17049 | Link | ||
Jinc can look a little soft with very fine details, but is preferable to aliasing or sharpening artifacts in my opinion. Sony's DRC maybe avoids ringing a little better (hard to tell from photos) but Jinc seems to look a lot more natural with real picture content. Quote:
madVR does not currently support greater than 8-bit output, so there's no point in buying a pro card for it. (at least not yet) Last edited by 6233638; 19th January 2013 at 20:05. |
19th January 2013, 20:52 | #17050 | Link |
David, next time you review a 4k tv/projector do not forget to test MadVR jinc upscaling and report back pronto
19th January 2013, 22:11 | #17051 | Link |
FFDshow Subtitle delay not working with MadVR+LAV Decoder
For some reason when setting FFDshow OR VobSub subtitles to delay + or -, it doesn't work for me using ZoomPlayer with madVR and LAV decoder. Is this a known issue or any suggestions as to what might be going wrong
ZoomPlayer + MadVR + LAV + FFDshow Subtitles
--Pei Last edited by pei; 19th January 2013 at 22:17. |
19th January 2013, 23:16 | #17052 | Link | |
20th January 2013, 01:13 | #17053 | Link |
So, I'm going to buy a new GTX 670 but before I do I just want to make sure that it's worth it compared to getting a half price GTX 660 if all I'm going to use it for is playing bluray material. Possibly 2 blurays at the same time on a 2560 x 1440 resolution with the highest image upscaling algorithms. I don't plan to game with it at all.
The major difference I see between the 660 and 670 is that the 660 has a 192-bit vs 670's 256-bit Memory Interface Width. Last edited by dansrfe; 20th January 2013 at 01:15. |
20th January 2013, 02:00 | #17054 | Link | |
Of course the Sony projection photos are at a big disadvantage because all the limitions of the projector and digicam add up in making those photos look worse. Also my screenshot has an advantage because I had to upscale more than 2x to make the image size match your photos, so my screenshot simulates a projector with a higher than 4K resolution. I do wonder though why those claws look so much thinner (which is probably more true to life) in my screenshots compared to those projection photos. That's kinda weird... |
20th January 2013, 02:28 | #17055 | Link |
Broadband Junkie
madVR in its current state uses only a very minimal amount of memory bandwidth, so that should be the least of your concerns.
The GTX 660 Ti should be the clear price/performance winner for madVR between the GTX 660 (~$220), GTX 660 Ti (~$290), and GTX 670 (~$360), especially if you decide to overclock. |
20th January 2013, 05:29 | #17057 | Link |
Broadband Junkie
If quietness is important, you should probably only look at the dual-fan non-reference models. I think nevcairiel and a couple others here own the ASUS DirectCU II model, and they have been satisfied with the noise level. As luck would have it, that model seems to be on sale at the moment as the cheapest non-reference option from NewEgg, even without the rebate.
20th January 2013, 07:45 | #17059 | Link |
I (and I think nevcairiel) have the ASUS DIrectCU II 660 (not the 660Ti). The noise level is OK not great in my Shuttle.... eg when pushed there is fan noise at the seating distance when the Audio is muted when working hard (eg 1080/60i material on Jinc3 AR).
