29th July 2015, 20:27 | #32241 | Link | |
They were also very incompetent when that GTX 970 issue came up. Well, even their reviews suck. But their forums are highly frequented by users and people were complaining there that NNEDI3 stopped working. My post which disappeared was information about the issue and asked users to complain to Nvidia about it. |
29th July 2015, 20:44 | #32242 | Link |
My render, upload and present queue doesn't get filled (1-3/16) when using 1080p60 no problem if i choose 1080p23 (FSE) in win 10 using AMD card no problem in windowed mode.
30th July 2015, 00:46 | #32245 | Link |
A new GeForce driver is out to accompany the release of Windows 10, only available on www.geforce.com at the moment:
32-bit GeForce Game Ready Driver 353.62 for Windows Vista, 7, 8 and 8.1 64-bit GeForce Game Ready Driver 353.62 for Windows Vista, 7, 8 and 8.1 32-bit GeForce Windows 10 Driver 353.62 64-bit GeForce Windows 10 Driver 353.62 Has anyone tried these yet to see if they have D3D9 OpenCL interop?
Test patterns: Grayscale yuv444p16le perceptually spaced gradient v2.1 (8-bit version), Multicolor yuv444p16le perceptually spaced gradient v2.1 (8-bit version) |
30th July 2015, 00:49 | #32246 | Link | ||
http://nvidia.custhelp.com/app/answe...-driver-353.49 Quote:
Miracles can happen, but better don't expect a fix anytime soon. |
30th July 2015, 01:51 | #32247 | Link | |
Posts: n/a
30th July 2015, 02:08 | #32248 | Link | ||
wasn't he clear enough? |
30th July 2015, 02:16 | #32249 | Link | |
Posts: n/a
In the past there was another similar issue that was NVidia's fault, but madshi found a way around it and NVidia never fixed it... |
30th July 2015, 04:21 | #32251 | Link |
I am unable to play any videos using MPC-HC nightly and MadVR latest in Windows 10 (Yeah I know it's only just come out as final etc). I get a Direct3D creation error. I have tried fresh installs of both and set MadVR to FSE off etc. AMD R9 290 BTW with latest Catalyst drivers for Win10.
If you need more info let me know but yeah it does it on all 3 monitors. |
30th July 2015, 09:12 | #32252 | Link | |
No problem in windowed mode. EDIT: Have to mention, no problem with win 7 on the same machine. Last edited by MSL_DK; 30th July 2015 at 11:50. |
30th July 2015, 13:00 | #32253 | Link | |
fwiw, in Windowed mode, it would drop a frame about every 3 minutes even though queue stats were "full" reported.
Win7Ult || RX560/4G || Ryzen 5 |
30th July 2015, 13:25 | #32254 | Link |
http://i.imgur.com/lGhI6YU.jpg
I tried installing DX9 and DX11 in Win10 and it made no difference. I also tried an in place upgrade of Win10 to see if it fixed anything. I also tried switching to the 4770K iGPU since it works on my laptops iGPU with Win10 installed just fine. No go on my main PC. Disabling FSE and changing to DX11 presentation makes no difference either. Ideas? EDIT: OK I tried MadVR with MPC-BE and it works! So I think there is an issue with MPC-HC's inbuilt LAV filters. I will test with some external filters like ffdshow or LAV external. I also noticed the other renderers mess up too like EVR custom preset and sync (I get a small video in the top left corner of MPC-HC and the rest is black space). I will check the LAV thread to see if anyone else has mentioned an issue since upgrading to Win10. EDIT2: ffdshow made no difference as a decoder so I am thinking the error is caused by LAV splitter. I will have to try Haali to test... EDIT3 Nope! It seems to be something intrinsyc to MPC-HC. I tried ffdshow as the video decoder and Haali as the splitter and still get the same problem. Filters currently loaded: - Default DirectSound Device - madVR - Audio Switcher - ffdshow Video Decoder - LAV Audio Decoder (internal) - Haali Media Splitter So I don't really know where to go from here. Madshi can you have a look into this for me? Last edited by oddball; 30th July 2015 at 14:27. |
30th July 2015, 14:37 | #32255 | Link |
Posts: n/a
So how many people actually contacted NVidia via their Feedback support bug submission? That is the BEST way, IMHO, to relay information directly to NVidia. GeForce or Guru3D or whichever other forums are NOT a good place to talk about things like D3D9 <-> OpenCL Interop support because those forums are for general public and problems (most of which are user errors), not HTPC madVR niche.
30th July 2015, 14:55 | #32256 | Link |
I'm having a similar problem as oddball with Windows 10 Pro. Only real difference is that i have an MSI AMD R7 265 OC using Catalyst 15.7.1 , Driver version 15.20.1062.1002(The latest driver specifically for Windows 10 directly from the AMD website not from Windows update.) and I'm getting a black screen, audio is fine. I tried switching to EVR custom with the same MPC-HC and the video shows perfectly fine. So I'm pretty sure it's madVR and not MPC-HC or the built-in LAV filters, for me anyway.
Intel i5 3470, EVGA GTX 1050Ti SC ACX 2.0, Windows 10 Pro 64 bit, 16 GB 1600 mhz DDR3 RAM Last edited by XRyche; 30th July 2015 at 18:02. |
30th July 2015, 15:04 | #32257 | Link |
I'm using amd dual graphic laptop
if I set mpc-hc to high performance in catalyst and set madvr to d3d11, it will crash "only" when entering windowed fullscreen mode. d3d9 doesn't have any problem also d3d11 in windowed and FSE run fine. edit: win 10
Aspire E1-451G - Catalyst 15.7.1 Last edited by balanyc; 30th July 2015 at 15:08. |
30th July 2015, 15:08 | #32258 | Link |
D3D9 interop has been removed deliberately:
https://forums.geforce.com/default/t...18371/#4618371 So, chances that it will come back are not best. |
30th July 2015, 16:00 | #32259 | Link | |
madshi should totally just switch everything to D3D11.
30th July 2015, 16:39 | #32260 | Link |
"not supported on Windows 10" sounds very much deliberately to me.
Well, it's a stupid statement anyway, since it works without any issues with WDDM 2.0 353.49 driver on Windows 10 (or 353.30, which even is WHQL). I'm somewhat afraid that if madshi fully switches to D3D11, unknown nasty driver issues will show up. Even with current D3D11 mode users have more trouble than with D3D9. With a SM5.0 NNEDI3 implementation this wouldn't be an issue. |
