Old 7th August 2018, 19:48   #181  |  Link
Anima123
Originally Posted by Orf View Post
The project is now have home page and forum.
Just registered to your forum but no activation e-mail received yet.
Edit: Never mind, it arrived later.
Anima123 is offline   Reply With Quote
Old 8th August 2018, 06:59   #182  |  Link
Orf
YAP author
@Anima123
Congrats, you're the first! Able to write something?
Orf is offline   Reply With Quote
Old 10th August 2018, 02:10   #183  |  Link
Anima123
@Anima123
I am not be able to write a post in your forum. Tried it yesterday, but it didn't showed yet.
Old 10th August 2018, 09:17   #184  |  Link
Orf
YAP author
My bad, you've got it answered now
Old 11th August 2018, 07:29   #185  |  Link
Anima123
Orf, is this a known issue that I cannot successfully import video file when using YAP under windows 10 64-bit?
If it is, how can I solve it?
Old 11th August 2018, 09:32   #186  |  Link
Orf
YAP author
Anima123, no it is not. Import should run just fine in Win10 and any other supported OS. And even if it is not, it should give the error message, you can locate it in Navigator message panel (M key). What do you see there? And also did this happens with all of your videos or only with some specific video format maybe?
Old 11th August 2018, 19:40   #187  |  Link
Anima123
There's no specific messages. Importing of video just failed silently.
BTW, I am under restricted windows account as I used to be.
Old 12th August 2018, 07:47   #188  |  Link
Orf
YAP author
Anima123, I still have not enough info, so I can tell you what exactly happened. Pls do the following: start player, import your file using Ctrl-F. Import your file again using Ctrl-O. Open message panel (M), copy and paste here all the messages. In the message panel press Enter and copy an paste debug log here too.
Old 12th August 2018, 20:54   #189  |  Link
Anima123
Just tried drag&drop a video to YAP and it worked. However, YAP doesn't respond to neither Ctrl-F nor Ctrl-O importing under windows 10 1803 for me.
Old 13th August 2018, 08:38   #190  |  Link
Orf
YAP author
Well, at least something is working for your. I do not understand what 'doesn't respond' means. Did you see file/folder selection dialog when you press Ctrl-F or Ctrl-O ? Did you see it, when your click Import files/folders from right click menu? And if your do, what happened next?
Old 13th August 2018, 17:46   #191  |  Link
Anima123
The files/folders did show up, there's just nothing happened when I press 'import' button.
Old 13th August 2018, 20:32   #192  |  Link
Orf
YAP author
Ok, this part works too. After that, did you see at least 'Import started...' and 'Import completed. 0 item(s) were added.' messages in Message panel?
Old 13th August 2018, 20:35   #193  |  Link
Anima123
No, just 'Playlist Main Loaded' message there.
Old 13th August 2018, 20:52   #194  |  Link
Orf
YAP author
Anima123, as I ask you before, please show me debug log after import fails
Old 13th August 2018, 21:20   #195  |  Link
Anima123
It 'magically' became normal now. I guess that it's due to the restricted account that I am using.
When I logged as Administrator and re-installed LAV-Filters and returned to the regular account, everything is fine.
Old 16th August 2018, 11:01   #196  |  Link
Orf
YAP author
Anima123, just tested import under restricted account, just in case, but everything worked as expected.
I do not think LAV-Filters re-install helped you. Those two thing are not related.
Also there's no magic or myth, you probably change something else in your system setup, something you either didn't noticed or just didn't tell us.
Old 7th September 2018, 08:47   #197  |  Link
Orf
YAP author
YAP 0.9.2 is now available. This release adds support for DVB broadcast. Was only being tested with DVB-C system, but might work with DVB-T and DVB-S systems as well.
Old 7th September 2018, 22:01   #198  |  Link
Anima123
Your site seems offline? I got 502 bad gateway errors when trying to download the new version.
Old 8th September 2018, 07:47   #199  |  Link
Orf
YAP author
No, works fine for me. Did anyone else experience problems with site access?
Old 8th September 2018, 08:44   #200  |  Link
works fine for me.
