26th June 2009, 14:14 | #101 | Link | |
AVCHDCoder developer
Current sizes are: DVD = 4700372992.0; (DVD+R because it is smaller then DVD-R) DVDDL = 8543666176.0; BD25 = 23283064365.0; BD50 = 46566128730.0; USB4 = 4000000000.0; |
26th June 2009, 19:27 | #102 | Link |
@twazerty
Perhaps you can enlighten me, as I must be doing something wrong. I've now used your program two different times, both times set to "Save to folder" (No menu, single movie) - and both times the program generates a "Completed" message after the two encoding passes - without performing the required muxing (Although it creates an empty folder). Please advise. |
26th June 2009, 20:07 | #103 | Link | |
Converted a mkv and a m2ts for double check. I think something is going on with a filename. What is your source filename? It took me hours to found out how to read mpls files. I am still not getting close but the following app does exactly what I need: http://forums.sagetv.com/forums/showthread.php?t=41722 It gives me the chapters from a mpls file. And I will use mediainfo to read chapters from mkv files. Last edited by twazerty; 26th June 2009 at 20:41. |
26th June 2009, 21:40 | #105 | Link | |||||
A simple fix for something on the list.
input and output can have wildcards, output extension defines if it's .sup or .sub Quote:
I'll admit outside of by far the most popular software player (PowerDVD) the players aren't very common but it's a one-size fits many more (all?) output. Quote:
I can understand the USB limit, I'm coming from a different angle thinking half a DVD5 is 2240 MB, I guess I'll have to get used to 2348 MB Quote:
26th June 2009, 21:59 | #106 | Link | |||
Just before you posted a reply I found a way to have Blu-Ray folder input. It was so obvious I couldn't find it. Just eac3to. I know eac3to is a powerful machine but this powerful: WOW. |
27th June 2009, 04:26 | #107 | Link | |
< BD-P1500 Firmware Ver 2.4 > Date: Apr.16, 2009 This Firmware update provides the following benefits: 1. Improves playback compatibility of some movie titles. Have you tried it? Samsung BD-2500 is also confirmed working with AUXDATA with < BD-P2500 Firmware Ver 2.5 > Date: Apr. 22, 2009 This Firmware update provides the following benefits: 1. Improves playback compatibility of some movie titles That leaves 2 samsung players that have 2 untested firmwares: < BD-P1600 Firmware Ver 1.03 > Date: JUNE. 23. 2009 This Firmware update provides the following benefits: 1. Improves playback compatibility of some movie titles < BD-P2500 Firmware Ver 2.5 > Date: Apr. 22, 2009 This Firmware update provides the following benefits: 1. Improves playback compatibility of some movie titles. Samsung 3600 and 4600 I haven't heard reports of but they also have recent firmwares with the same note: 1. Improves playback compatibility of some movie titles |
27th June 2009, 09:39 | #108 | Link |
I think I'm missing something here. I've tried two different MKV files and both have failed. The whole video encoding step is getting missed out each time. Any ideas? Is there a log file somewhere?
Edit: Just seen the installation guide on the website so running through those basic checks now. Last edited by rendez2k; 27th June 2009 at 09:46. |
27th June 2009, 14:57 | #109 | Link | |
Also another problem. When I have seamless branching discs can I demux it with tsMuxer so I have a 1 correct file? Edit: Some more questions: - if input fps = ~23.976 add this to avs: AssumeFPS(24000/1001) check. But what if input is 25fps? or 29.976? or 50fps? or 59.9? And if I add AssumeFPS can I change this: DirectShowsource("[sourcefile]",fps="[sourcefps]",audio=false) to DirectShowsource("[sourcefile]",audio=false) ?? Last edited by twazerty; 27th June 2009 at 17:40. |
27th June 2009, 17:34 | #110 | Link |
The problem I described to you in Post #102 here is certainly the result of folder/filename protocol in AVCHDCoder.
In the "Settings", I set the default output folder to "E:\Test. I then go through the steps of "Input", "Streams", and "Output". In "Output", I select the "Auto" radiobutton for filename - and the program generates (without the quotes) "E:\Test/" instead of "E:\Test\"... |
27th June 2009, 18:00 | #111 | Link | |
27th June 2009, 18:19 | #112 | Link | |
Glad to hear I wasn't doing anything wrong and, instead, was able to help you track down a bug ;>}
You say: Quote:
27th June 2009, 18:57 | #113 | Link | |
Edit: Now I use mediainfo for extracting info out from: wmvhd, mkv and m2ts. Is it safe to use tsMuxeR to extract stream info from mkv? or is it better to use mediainfo for that? I mean the stream information itself instead of chapters. Last edited by twazerty; 27th June 2009 at 19:05. |
27th June 2009, 19:16 | #114 | Link | |
@twazerty
See my posts #24 and #65 in this thread about chapters. For information available from "tsMuxeR" commandline see: http://forum.doom9.org/showthread.php?t=142559 Last edited by setarip_old; 27th June 2009 at 19:18. Reason: Add'l info |
27th June 2009, 23:00 | #115 | Link | ||||
Also I gave you the wrong avisynth function it should be AssumeFPS(24000,1001) Quote:
28th June 2009, 15:53 | #116 | Link |
Now languages will be read from m2ts files,
chapters will be entered in gui for mkv and m2ts files. I use both mediainfo and tsMuxer for proper detections of streams. I only use tsMuxer for languages and chapters. Now I am working on Seamless branching discs. I ran into some trouble. Eac3to doesn't allow me to demux to a folder I want. It demuxes them in the root of eac3to which is impossible since AVCHDCoder is in Program Files without admin rights. Only option is to use tsMuxer for demuxing. TsMuxer gives me more flexability and it will be much easier to implement. Also there is only 1 implementation needed. Saves me lots of time. |
28th June 2009, 17:00 | #117 | Link |
Sounds great.
That's a strange issue are you trying both individual demuxing (eac3to 1) 1:C:\chapters.txt 2:C:\video.264 3:C:\audio.ac3) and demux to mkv (eac3to 1) C:\video_audio.mkv) ? Recently there has been some reports of BD-Rebuilder having a skip in the audio on 2 seamless branching videos, might be related to tsmuxer trickery. Also some updates, additions I thought of: - change pause/resume button to pause when running, resume when paused - change start button to stop when running - group start/stop and pause/resume buttons - group delete job and delete all buttons - either change to mkv x264 output or use x264 --aud with .264 output (requires nal_hrd x264) (iirc there's some problems with seeking and lack of --aud with m2ts muxed from 264 files on certain players) - use AssumeFPS(30000,1001) with Directshowsource(fps=29.97) and 60000,1001 with fps=59.94, the fps difference is so small eac3to and dgavcindex don't detect it but large enough to mess up ivtc - show x264 FPS in progress bar - use a few shades lighter orange in progress bar so the text is more legible - x264 advanced options or override file (that reads only --b-adapt (change both passes) --deblock --subme --me --partitions --vaq --psy-rd --trellis --b-pyramid(?) --ref 1-4 only) - individual update exe and tools system (upload exe\tools to update site for example megui) - on loading input demux a little bit of the subs (10 seconds?) with tsmuxer and tag signifigantly smaller ones (forced) - add more stream languages - alphabetize stream languages but have a common section at the top like tsmuxer does (concerning USA\CA: zho is a lot more common then chi for chinese, fra is a lot more common then fre for french) - identify tff/bff interlacing with mediainfo and adjust x264 accordingly (requires x264_nal_hrd x264, rarely needed) - add ivtc video option for 29.97 fps that uses tfm().tdecimate() or telecide().decimate() and removes x264 --tff/--bff, result is 23.976 (rarely needed) - add ivtc video option for 25 fps that uses tfm().tdecimate(25) or telecide().decimate(25) and removes x264 --tff/--bff if applicable, result is 24.00 fps (rarely needed) - identify pulldown (mediainfo?) and use tsmuxer delpulldown (rarely needed) Last edited by turbojet; 28th June 2009 at 17:17. |
28th June 2009, 18:35 | #118 | Link | |
Please keep in mind AVCHDCoder points to users without much knowledge. Technical video options will be added but has no high priority. Technical improvements will be done and also GUI improvements will be done. I'll do some more research. Also opening Blu-ray folders work now.
I think I go for a version without tabs. When you click on a item the information will shop up. |
28th June 2009, 19:41 | #119 | Link | ||
28th June 2009, 20:05 | #120 | Link | |
avchd, mkv |
