Old 21st November 2024, 20:56   #10861  |  Link
LigH
LigH's Avatar
Then my bet goes to the drivers. Please try to report the exact graphic chipset model and driver version, maybe that helps finding similar issues.
New German Gleitz board
Old 25th November 2024, 19:42   #10862  |  Link
v0lt
Does anyone here use a 32-bit player?
Starting around November 16, the "windows-2022" components were updated on GitHub. After that, new 32-bit builds do not work correctly on some machines.
However, your local 32-bit builds compiled in Visual Studio 2022 (MSVC 19.42.34433) may work correctly.
The issue affects builds from https://github.com/qwerttvv/Player/releases
PS: There are also problems in other projects after the "windows-2022" update.
v0lt is offline   Reply With Quote
Old 25th November 2024, 23:01   #10863  |  Link
s0meone_new
Few people use the 32-bit edition of Windows anymore.
It may have already been discussed here:
Perhaps an equalizer would be useful in the program if there was one?
s0meone_new is offline   Reply With Quote
Old 26th November 2024, 04:30   #10864  |  Link
v0lt
Almost all sound card drivers (external and built-in) have an equalizer.
Use it.
Old 26th November 2024, 07:15   #10865  |  Link
s0meone_new
I use it.
Old 26th November 2024, 08:16   #10866  |  Link
Anima123
I do, especially when I playback some old files with kind of special audio encoding which only have 32-bit codec available.
Anima123 is offline   Reply With Quote
Old 26th November 2024, 10:50   #10867  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Out of interest... Like what codec?
Old 26th November 2024, 14:59   #10868  |  Link
v0lt
Builds from qwerttvv are now built using "windows-2019" components.
There are no more errors in 32-bit versions. Checked on MPC-BE 1.8.1.36.
Old 26th November 2024, 18:59   #10869  |  Link
Sunspark
The MadVR testpatternsource ytp files are an example. The .ax dll for it is 32-bit only.
Old 26th November 2024, 19:10   #10870  |  Link
LigH
LigH's Avatar
Originally Posted by LigH View Post
I found a few videos with a strange phenomenon: When I start them out of the "Far manager" to let MPC-BE play them, the player opens, seems to try to load for a few seconds, then vanishes.
Same happens when I launch them via start in a CMD (which calls the same EXE which is assigned to the file type as the Windows Explorer would do on a double-click).
I found about a dozen videos now which don't work; other videos with pretty much the same format, some even from a series from the same author, do launch correctly. Most are AVC+AAC in MP4, one is Xvid+MP3 in AVI.
Old 26th November 2024, 20:05   #10871  |  Link
Klaus1189
Can you provide a sample for devs now?
What GPU and what driver?
Are you using hardware decoder? If so, what happens when using software decoder?
Any external filters like madVR or LAV Filters?
Old 26th November 2024, 20:16   #10872  |  Link
LigH
LigH's Avatar
No public samples. I will test if I can crop them to a minimum where it still happens...
Nvidia GeForce 1660 Super; driver version 560.94; in case of the AVC-MP4: D3D11 Native, H.264, no FGT; MPC-VR, MPC-AR
Please note, again, that playback works flawlessly if I launch the exact same file from the Windows Explorer. It is not a playback issue, rather a player-loading issue.
Do you have a debug build which logs every step from starting the player executable to starting the playback (e.g. enumerating filters)?
Old 26th November 2024, 20:40   #10873  |  Link
SeeMoreDigital
Just so somebody knows...
As of a couple of days ago Youtube links no longer work using: v1.8.1 git 2024-11-07 - b42c254e5
Cheers
Old 27th November 2024, 00:14   #10874  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Cheers
Already fixed.
AMD Ryzen 7 7700 /ASRock B650M Pro RS /G.Skill RIPJAWS 32 ГБ /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Aleksoid1978 is offline   Reply With Quote
Old 27th November 2024, 07:53   #10875  |  Link
Anima123
VO3+ is one example.
Old 27th November 2024, 09:22   #10876  |  Link
LigH
LigH's Avatar
Took me a while to discover it is an ancient "Vorbis ACM" codec (before the format got finalized)... quite probably famous in the Anime fansub scene, decades ago.
Old 5th December 2024, 08:07   #10877  |  Link
v0lt
MPC Video Renderer 0.8.9.2318
Changes:
Added support for YUV420P10, YUV422P10, YUV444P10, GBRP10 and Y10 formats using MEDIASUBTYPE_LAV_RAWVIDEO.
Added clarification when the "Convert to SDR" setting will work.
"Super Resolution" will only be enabled for 8-bit video due to driver limitations.
Added the ability to work with incorrect YUV frames (4:2:0/4:2:2 with odd dimensions).
Recommended MPC-BE 1.8.1.43 or newer.
PS: MPC Video Renderer 0.8.9 is included in the MPC-BE 1.8.1.59 installer.
Old 6th December 2024, 15:43   #10878  |  Link
yukipon
Hello! I have a request.
Is it possible to make it so that only the name of the video is displayed in the title bar?
Currently, the app name and version name are displayed after the video name.
It's easier to see without it.
Thank you!
yukipon is offline   Reply With Quote
Old 6th December 2024, 15:49   #10879  |  Link
LigH
LigH's Avatar
Maybe like a title bar syntax template with tokens editable in the Options dialog...
Old 6th December 2024, 16:31   #10880  |  Link
Klaus1189
https://drive.google.com/file/d/1Mp5...ew?usp=sharing
