11th May 2023, 07:44 | #10001 | Link |
Big Bit Savings Now !
Many thanks, v0lt !
11th May 2023, 15:39 | #10002 | Link |
Update Simplified Chinese:)
https://anonfiles.com/l5MbBeqcz0/mplayerc_sc_rc_7z https://files.catbox.moe/hchwra.7z |
12th May 2023, 04:31 | #10003 | Link |
Thank you. Translations have been updated.
MPC-BE 1.8.2 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource |
16th May 2023, 22:19 | #10004 | Link |
Hungarian translation updated:
https://easyupload.io/3xtzuq |
17th May 2023, 03:59 | #10005 | Link |
Updated german translation
18th May 2023, 09:22 | #10006 | Link |
Updated german translation - some cosmetics
18th May 2023, 09:57 | #10007 | Link |
https://files.catbox.moe/8vopar.7z
https://anonfiles.com/069cb3s4z3/mplayerc_sc_rc_7z Update Simplified Chinese:) |
19th May 2023, 14:14 | #10008 | Link |
Updated german translation - some cosmetics for last update needed
20th May 2023, 07:35 | #10009 | Link |
Hy to all. On this site "https://www.hiresaudio.online/max-radio-society/" is adress streams radio station . MPC-BE not play these radio streams. On webplayer work streams - "https://www.maxradio.ca/StreamsHiFi/MaxRadioPlayer/index.html.".Is UHD radio streams. Thanks.
20th May 2023, 17:18 | #10011 | Link |
Now last update for german translation
21st May 2023, 07:35 | #10012 | Link |
I am having a particular problem with a MKV edited with MKVToolnix. I tried both MPC-BE and MPC-HC and they failed. MPC-BE even failed with LAV instead of MPC Decoder. If I am not mistaken, madVR was selected, too.
Here's the thing: all tracks (audio and subtitles), except for 1 of them, had a positive delay of 8 minutes, 41 seconds and 934ms, or 521934 ms if we write in the "delay" field. This was needed because these new added tracks do not include the extra 8 minutes from it, so they need to start after 8m41s934ms, meaning if we use them, there will be silence, except for 1 track. But doing so will create an issue with the MKV - it will freeze when you open the file, from the beginning. If you skip to any other moment of the file, you'll continue watching. However, it's paused for good while I try to open, and if I hit "continue playing", it's still at 0:00:00. I tried skipping to another moment like 1 hour, then I moved back to 1 second. Now the file is OK and from the start. The funny thing is that: - If you try to open with proprietary software, like PlayerFab, or VLC (which is free), everything will be fine and no sign of a bug anywhere! No freezing, too. So what should I do? MEDIAINFO: https://pastebin.com/iVmW3sh9 Last edited by Perenista; 21st May 2023 at 07:41. |
21st May 2023, 08:58 | #10013 | Link | |
For good, it’s not so necessary to make delays - they insert silence at the beginning, but this should already be done in the editor.
AMD Ryzen 7 7700 /ASRock B650M Pro RS /G.Skill RIPJAWS 32 ГБ /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 |
21st May 2023, 21:39 | #10014 | Link | |
Every setting? So if a single track has such delay, it will cause this issue? Or it's the number that seems to be the problem? I heard VLC/PlayerFab use their own built-in decoders... Last edited by Perenista; 21st May 2023 at 23:15. |
25th May 2023, 04:40 | #10016 | Link |
2nd June 2023, 18:42 | #10018 | Link | |
3rd June 2023, 04:05 | #10019 | Link | |
Maybe I should look for or wait for the intel 14gen ncu |
3rd June 2023, 06:59 | #10020 | Link |
Support for Super Resolution appeared after the implementation in Chromium. The file swap_chain_presenter.cc contains the functions ToggleIntelVpSuperResolution and ToggleNvidiaVpSuperResolution. There is no solution for AMD.
