13th September 2012, 21:21 | #42 | Link | |
13th September 2012, 21:45 | #45 | Link | |
SuperVirus
By default, the menu bar should be turned ON always |
13th September 2012, 21:54 | #46 | Link | |
契約者
Who says that? That orange button on screenshot replaces menu. Why you need 2 menu at once? In case of this option is implemented, you'll go in options and turn old menu on if you need it. It also should be available by pressing alt of course. Last edited by Keiyakusha; 13th September 2012 at 21:58. |
13th September 2012, 22:59 | #48 | Link | |
AMD Ryzen 7 7700 /ASRock B650M Pro RS /G.Skill RIPJAWS 32 ГБ /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 |
14th September 2012, 02:02 | #52 | Link | |
14th September 2012, 09:53 | #53 | Link | |
The above was made with a clean system with this being the 1st run/setup of MPC-BE. The 1st run I missed the timing but the 2nd was good, where when changing the volume while MPC-BE's status bar was saying opening. Hope this helps.
Windows 11 Pro, CPU: Ryzen 9 5900X, GPU: GeForce RTX 3090 /w 512.95, Audio: HDMI to Yamaha RX-A3060 (5.1) |
14th September 2012, 10:49 | #54 | Link | |
MPC-BE DEV
VipZ, if not difficult for you, then perform the test on all types of renderer in mpc-be. I have the following results: EVR Cust - bug EVR - bug VMR7 R - bug VMR9 R - bug VMR7 W - good VMR9 W - good
Win11 x64, i7 8700K 5Ghz, ASUS MAXIMUS X HERO, G.Skill (2x8GB) Trident Z F4-3600C16D-16GTZ, RX 5700,TV Philips 43PUS6703/12, Zappiti 4K HDR Media Player Classic - BE x86/x64. Team of developers. Last edited by alexins; 14th September 2012 at 12:30. |
14th September 2012, 13:51 | #55 | Link | |
madVR - easy to produce EVR Cust - easy to produce EVR - easy to produce VMR7 R - bit hard to produce, but its very doable VMR9 R - easy to produce VMR7 W - harder to produce by dropping files quickly onto window and changing volume, possibly something totally different VMR9 W - harder to produce by dropping files quickly onto window and changing volume, possibly something totally different EVR Custom is by far the easiest of the lot to produce the bug.
15th September 2012, 11:07 | #56 | Link |
Try this build - http://rghost.ru/40373713
I disable hot key while do loading meida.
15th September 2012, 12:19 | #57 | Link | |
Also thanks, SHOUTcast is working nicely and the title's are a nice touch If playing say an MP3 or FLAC audio file, it would be nice to say ARTIST - TRACK vs the current TRACK (YEAR) or even make this configurable?
Windows 11 Pro, CPU: Ryzen 9 5900X, GPU: GeForce RTX 3090 /w 512.95, Audio: HDMI to Yamaha RX-A3060 (5.1) Last edited by VipZ; 15th September 2012 at 12:37. Reason: Added an idea |
15th September 2012, 14:53 | #59 | Link |
契約者
The point of this is visual upgrade not functional. If there is normal menu, probably someone needs it. So this button is a cool replacement. And it is not hard to implement, especially if you have projects you can copypaste it from. Personally I don't even use any MPC player
