Old 13th September 2012, 08:27   #21  |  Link
VipZ
Thanks for MPC-BE and with some testing have found 2 bugs,
1. SHOUTcast doesn't work both x86 and x64 builds, either through playlist or direct to HTTP stream, MPC-HC was tested in same clean OS and was working.
2. Trying to interact with the GUI as MPC-BE is launching a video file like changing the volume with mouse wheel will crash MPC-BE.
Here is the website for the SHOUTcast streams I am using, http://www.181.fm/index.php?p=mp3links
Here is what I did for a temporary fix for SHOUTcast playback, took the ShoutcastSource.cpp from MPC-HC and correct ifdef to REGISTER_FILTER and compile, works perfectly.
Windows 11 Pro, CPU: Ryzen 9 5900X, GPU: GeForce RTX 3090 /w 512.95, Audio: HDMI to Yamaha RX-A3060 (5.1)
VipZ is offline   Reply With Quote
Old 13th September 2012, 08:49   #22  |  Link
z_mashine
z_mashine's Avatar
Originally Posted by Superb View Post
- Why doesn't the window auto-resizes to the video's resolution when you open a file? Changed defaults? How do I make it act like it did in MPC-HC?
O -> Playback -> Auto-zoom
z_mashine is offline   Reply With Quote
Old 13th September 2012, 10:14   #23  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Can you describe in more detail your actions and the problem itself
AMD Ryzen 7 7700 /ASRock B650M Pro RS /G.Skill RIPJAWS 32 ГБ /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Aleksoid1978 is online now   Reply With Quote
Old 13th September 2012, 10:33   #24  |  Link
Aleksoid1978
Thanks for test - i found bug and fix this.
Old 13th September 2012, 11:09   #25  |  Link
alexins
MPC-BE DEV
alexins's Avatar
17-18 September will be published the next version of MPC-BE and the same will be available the source code.
Win11 x64, i7 8700K 5Ghz, ASUS MAXIMUS X HERO, G.Skill (2x8GB) Trident Z F4-3600C16D-16GTZ, RX 5700,TV Philips 43PUS6703/12, Zappiti 4K HDR
Media Player Classic - BE x86/x64. Team of developers.
alexins is offline   Reply With Quote
Old 13th September 2012, 11:25   #26  |  Link
VipZ
Sorry I wasn't too clear on this and put steps in detail below,
1. Make sure "Use the preview in the search" is enabled.
2. Ensuring MPC is closed launch a video media file via file association, the bigger the file and slower the disk the better to catch this.
3. Before MPC has had a chance to load the media file and display a video frame, attempt to change the volume as quick as you can with the mouse wheel.
4. MPC window should now stall and crash.
I have confirmed this that is happens 100% of the time on multiple systems providing you catch it on time. Disabling "Use the preview in the search" will result in no crashes in the above steps.
I have also noticed other crashes if you interact with the GUI as media is loading but this one is random and cant put down steps to reproduce but I assume this would be the same bug.
Thanks, there is also a cosmetic issue that would be nice if it could be fixed.
The option replace file name with title in the title bar to use the meta-data providing by SHOUTcastsource which is is currently only viewable via properties->clip.
Also it would be a nice option if this could also be applied to the seek bar file name option.
Old 13th September 2012, 12:58   #27  |  Link
Anarchitektur
very nice, I like it a lot, thank you, I have minor request, I would like when I minimize player, movie to be a movie and not still picture in preview window in taskbar
Last edited by Anarchitektur; 13th September 2012 at 13:05. Reason: add screenshot
Anarchitektur is offline   Reply With Quote
Old 13th September 2012, 13:00   #28  |  Link
Aleksoid1978
Thank's for report & idea - all be done, wait next release;
Old 13th September 2012, 13:14   #29  |  Link
Aleksoid1978
It's a Windows limits - DWM can't do live preview when window is minimized. Make request to Microsoft
Old 13th September 2012, 13:18   #30  |  Link
Anarchitektur
but potplayer can, dont know how, but it can
Old 13th September 2012, 13:46   #31  |  Link
VipZ
I may as well make more bug reports today
There has been a long standing bug with file association ever since custom icons where introduced. If you use cmd's /regall, /regvid etc it doesn't honour the AssociatedWithIcon registry key and act's as this was set to 0.
MPC Audio Renderer doesn't output any audio when set to WASAPI in shared mode. Tested with multiple audio outputs and settings. Also in exclusive mode there is a bit of hiss until you seek which then clears it.
Old 13th September 2012, 14:26   #32  |  Link
alexins
MPC-BE DEV
alexins's Avatar
This is a problem (error) work Evr custom, at the present moment we have no solution for this problem.
Old 13th September 2012, 14:45   #33  |  Link
Anarchitektur
Old 13th September 2012, 14:49   #34  |  Link
ney2x
Originally Posted by ney2x View Post
I'm glad there's an official thread here for MPC-BE. I already switched player from MPC-HC to MPC-BE. I like the icons / GUI very much! I hope you replace the default Subtitle Filter to xy-VSFilter. Thanks!
At the current stage of development, it is not included in our top-priority tasks. Maybe later...
Thanks. Any chance for an ICL12 build? MPC-HC MSVC 2010 SP1 are not utilizing all of the threads of the latest Intel processors if using other decoders like ffdshow raw, LAV Filters, and so on. TIA.
ney2x is offline   Reply With Quote
Old 13th September 2012, 16:59   #35  |  Link
wanezhiling
Old 13th September 2012, 17:30   #36  |  Link
THX-UltraII
At the moment there are three MPC versions on this forum that are hot correct?
1. MPC-HC
2. MPC-BE
3. MPC-HC with internal renderer fixes
How do I know which version is the best/is right for me? For info: I will use MPC only for playing full Blu-Ray rips in .m2ts or BDMV structure folder formats and occasionally for playing .mov 1080p trailers from HDtrailers.net. I want to use madVR as renderer and LAV filters also but I suppose this is possible with all three versions.
THX-UltraII is offline   Reply With Quote
Old 13th September 2012, 18:05   #37  |  Link
the_weirdo
Yes, I'm weird.
the_weirdo's Avatar
If you intend to use madVR as renderer then you don't need "MPC-HC with internal renderer fixes". Main differences between MPC-HC and MPC-BE are interface, and some addon features of MPC-BE. There may be some differences about internal filters of the two, but you want to use LAV Filters so that doesn't matter. Which version is right for you? I think you have to find out yourself.
“Never argue with stupid people, they will drag you down to their level and then beat you with experience.” — Mark Twain
the_weirdo is offline   Reply With Quote
Old 13th September 2012, 18:15   #38  |  Link
Anarchitektur
Originally Posted by wanezhiling View Post
hmm... it works even with do not use d3d and with blt mode
Old 13th September 2012, 18:17   #39  |  Link
THX-UltraII
Ok, so if I use LAV filters and madVR as output renderer I m good to go with MPC-HC or MPC-BE? Can I see somewhere what kind of interface MPC-BE has? Is it much nicer than MPC-HC?
Old 13th September 2012, 19:34   #40  |  Link
dlind87
I really like this version of mpc but there is one (for me) major problem: I use middle mousebutton to play/pause the video in all my players, but unbinding left mousebutton in mpc-be removes the ability to move the window when clicking in the video area. Any chance to "fix" that?
dlind87 is offline   Reply With Quote
