Old 8th October 2012, 01:33   #201  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Originally Posted by jinsk8r View Post
This. x86 too.
In some movies it loads, in some others, it doesn't. MPC-HC loads properly.
(And I'm 100% sure subtitle/movies names are match)
You need to check this problem.
Need sample for test.
AMD Ryzen 7 7700 /ASRock B650M Pro RS /G.Skill RIPJAWS 32 ГБ /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Aleksoid1978 is offline   Reply With Quote
Old 8th October 2012, 04:24   #202  |  Link
jinsk8r
Happened to 8/20 of my movies.
I put em all in F:/Videos/Movies/<movie name>
All are .MKV with .SRT subtitles.
I used to watch them with MPC-HC, subtitles were loaded properly without any problem.
Subtitle was not show in the sub-menu of "SUB" button on those 8 movies. I need to load them manually.
I dont think screenshots will help.
jinsk8r is offline   Reply With Quote
Old 8th October 2012, 05:57   #203  |  Link
Aleksoid1978
I try - but can't reproduce. I make many video+srt/ass external subtitle and ALL opened ok with subtitle.
upload a video(MKV) + subtitle(SRT) that have this bug. Without a sample - can't test & detect problem.
Old 8th October 2012, 06:01   #204  |  Link
jinsk8r
I figured it out.
The external subtitles don't autoload in movies which don't have internal subtitle.
Old 8th October 2012, 06:09   #205  |  Link
ryrynz
ryrynz's Avatar
Nevermind.
Old 8th October 2012, 12:50   #206  |  Link
tinybutstrong
A simple suggestion if possible. Can you guys add 3D pixel shaders by default? The list bellow is from PotPlayer, I think it would be useful anytime:
3D OAU GreenMagenta
3D OAU RedCyan
3D OAU to 2D
3D SBS GreenMagenta
3D SBS RedCyan
3D SBS to 2D
tinybutstrong is offline   Reply With Quote
Old 8th October 2012, 23:58   #207  |  Link
mark0077
guys, is there an error in the way mpc-hc window is being set to "100%". I am using madVR and noticed when opening a 1280 x 720p movie, that madVR reports the target rectangle seems to be a few pixels too small in x and y, or maybe I'm mis understanding?
movie resolution 1280, 720
target rectangle 1, 0, 1277, 718
In players like potplayer, the target rectangle is as expected, ie
target rectangle 0, 0, 1280, 720.
Just thought it was worth mentioning if its an easy fix, for people who want to have no resizers in use when watching in windowed mode.
mark0077 is offline   Reply With Quote
Old 9th October 2012, 05:24   #208  |  Link
Aleksoid1978
i just press - Alt+2(100% Zoom)
Old 9th October 2012, 17:06   #209  |  Link
mark0077
Thanks Aleksoid but there must be something else throwing it off. Alt - 2 doesn't make a difference. "View" -> "Video Frame" is set to "Touch window from inside". When I use "Touch window from outside" I get slightly different but still a few pixels off perfect.
0, 0, 1278, 719
When I use the keys "3", "2", "1", I also notice a change.
"1" -> minimal shows 0, 0, 1280, 720
"2" -> compact shows 1, 0, 1277, 718
"3" -> normal shows 1, 0, 1277, 718
Looks like miscalculation by 1-2 pixels depending on some of these types of settings. Should it be like this?
Old 10th October 2012, 00:08   #210  |  Link
kasper93
MPC-HC Developer
I guess windows size is calculated wrong because of gui changes. It easy to fix, but it need to be done everywhere in the code to avoid other miscalculations. Well, I can't test it. Madvr shows only black screen on laptop that I currently use. Old integrated intel GMA, very old...
kasper93 is offline   Reply With Quote
Old 10th October 2012, 07:39   #211  |  Link
Dark Eiri
I got this strange issue... MKV (H264+AAC) videos stored within RAR files will not open on MPC-BE with RARFileSource. Says "no media files inside archive".
On PotPlayer and VLC, even though I'm sure they use the exact same source splitter, they open flawlessly.
Dark Eiri is offline   Reply With Quote
Old 10th October 2012, 11:49   #212  |  Link
wanezhiling
http://pan.baidu.com/share/link?shar...&uk=3558042035
The image is broken after seeking..
ffdshow video decoder seems fine.
BE 1321, default setting.
Old 10th October 2012, 13:30   #213  |  Link
Aleksoid1978
Ok. i see, if it's not ffmpeg issue try to fix.
Old 11th October 2012, 11:47   #214  |  Link
Kingu
Custom Toolbars and Improve Image with Shaders
Toolbars for MPC-BE:
http://dev.mpc-next.ru/index.php/topic,841.0.html
http://dev.mpc-next.ru/index.php/topic,848.0.html
Better images using shaders:
http://dev.mpc-next.ru/index.php/topic,851.0.html
http://dev.mpc-next.ru/index.php/topic,863.0.html
Kingu is offline   Reply With Quote
Old 12th October 2012, 09:26   #215  |  Link
sundance
sundance's Avatar
@Aleksoid1978:
Sorry if that has been asked before (although I couldn't find it...):
Since BE edition is a MPC-HC fork: Which is the version of MPC-HC where you based your development of MPC-BE?
..:: sundance ::..
sundance is offline   Reply With Quote
Old 12th October 2012, 10:29   #216  |  Link
Aleksoid1978
Originally Posted by sundance View Post
@Aleksoid1978:
Honestly - I do not remember the exact version. Why do you want to know?
Time - i think about half of year
Old 12th October 2012, 10:53   #217  |  Link
sundance
sundance's Avatar
Just curious.
I've been using MPC-HC (BE-Mod) for quite a while (v1.6.2.4360 from http://www.xvidvideo.ru), but sadly (as we all know) both the compiles and BE patches were discontinued.
So I just wanted to find out what I am missing (from the current MPC-HC project) when I go for your MPC-BE (e.g. DirectX lib integration).
..:: sundance ::..
Old 12th October 2012, 13:27   #218  |  Link
tinybutstrong
Any possibility to add support for 3D subtitles (.str) playback?
PotPlayer has this feature:
Old 14th October 2012, 06:07   #219  |  Link
wanezhiling
http://i.imgur.com/NHy9G.jpg
no sub (40s), its ok.
http://i.imgur.com/eXaV5.jpg
with sub (51s), lav splitter shows 40s too.
Old 14th October 2012, 06:33   #220  |  Link
Aleksoid1978
MediaInfo show 51s too.
Because - subtitle track has ~51sec duration.
00:00:40,720 --> 00:00:50,950
哈哈哈哈
I think - need calculate duration only at video or audio track.
