Old 12th January 2015, 15:20   #1  |  Link
movmasty
x264vfw command line options
I need the exaustive(all the options supported) cli setting to use in x264vfw, and specially in Komisar build.
Mainly i need to set and enable mbtree and rc-lookahead in this way
These are the cli option that could be set through Komisar x264 gui
--crf 24.9 --ref 3 --trellis 1 --mixed-refs --deblock 1:0 --bframes 4 --direct auto --b-pyramid --b-rdo --weightb --bime --b-bias 0 --direct-8x8 -1 --me umh --subme 7 --merange 16 --mvrange -1 --mvrange-thread -1 --scenecut 50 --partitions i4x4,i8x8,p8x8,b8x8 --aq-mode 3 --aq-metric 2 --aq-strength 1.2 --psy-rd 1:0.15 --ratetol 0.5 --qcomp 0.4 --cplxblur 20 --qblur 0.5 --keyint 150 --min-keyint 5 --nr 0 --qpmin 18 --qpmax 38 --qpstep 7 --deadzone-inter 21 --deadzone-intra 10 --progress --threads 0 --thread-queue 0 --thread-input --cqmfile .\matrix.cfg --ipratio 2.4 --pbratio 1.33 --chroma-qp-offset 0 --vd-hack
TIA
movmasty is offline   Reply With Quote
Old 13th January 2015, 07:14   #2  |  Link
movmasty
komisar last update is 2013-02-27, so.....
and i figured out how to use cli, just write the options that you need to change and komisar will fill with its default, mbtree enabled
Old 13th January 2015, 11:35   #3  |  Link
komisar
komisar's Avatar
--crf 24.9 --ref 3 --trellis 1 --mixed-refs --deblock 1:0 --bframes 4 --direct auto --b-pyramid 2 --weightb --b-bias 0 --me umh --subme 7 --merange 16 --mvrange -1 --mvrange-thread -1 --scenecut 50 --partitions i4x4,i8x8,p8x8,b8x8 --aq-mode 3 --aq-strength 1.2 --psy-rd 1:0.15 --ratetol 0.5 --qcomp 0.4 --cplxblur 20 --qblur 0.5 --keyint 150 --min-keyint 5 --nr 0 --qpmin 18 --qpmax 38 --qpstep 7 --deadzone-inter 21 --deadzone-intra 10 --ipratio 2.4 --pbratio 1.33 --chroma-qp-offset 0 --vd-hack --rc-lookahead 80 --mbtree
work fine for me in x264vfw (use "Use command line:" or "Extra options:")
--b-pyramid -- need argument i.e. "--b-pyramid 2"
--b-rdo unsupported
--bime unsupported
--direct-8x8 -1 unsupported
--aq-metric 2 unsupported
--progress unsupported
--thread-queue 0 unsupported
--thread-input unsupported
p.s. --mbtree/--no-mbtree work fine
..::[I am live here]..::..[My x264 CLI/VFW builds and tools]::..
komisar is offline   Reply With Quote
Old 13th January 2015, 19:39   #4  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
FWIW, newer VfW builds can also be found here:
http://sourceforge.net/projects/x264vfw/files/x264vfw/
Old 15th January 2015, 11:29   #5  |  Link
movmasty
Thanks MyLoRd (just downloaded your LameXP)
And thanks in Anticipation Komisar, since a new update will be nice
(Glad to know that exist a --mbtree, still dont understand the --aq-mode 3 )
And now a shocking info!
Acutually im making Mp4, for the aac audio and to incude srt subs in the file....
BUT,
im encoding in avi with komisar, and then convert to mp4
with Pazera free converter suite(and i reccomend it)
Still find all the mp4 encoders, buggy, little configurable and hard to use
Old 15th January 2015, 12:08   #6  |  Link
komisar
komisar's Avatar
"--aq-mode 3" correct option for x264vfw.r2273kMod
...and try to use "-o d:\MyCoolVideo\something.mp4"
Old 15th January 2015, 14:52   #7  |  Link
movmasty
x264 core:130 r2273 b3065e6
x264 --fullhelp
--aq-mode <integer> AQ method [1]
- 0: Disabled
- 1: Variance AQ (complexity mask)
- 2: Auto-variance AQ (experimental)
Old 15th January 2015, 16:11   #8  |  Link
komisar
komisar's Avatar
x264vfw.r2273kMod
I build only kMod VFW...
BugMaster build clear VFW...
Old 15th January 2015, 18:33   #9  |  Link
movmasty
OK, then what --aq-mode 3 is???
dont tell me that
0=1
1=2
2=3
Old 15th January 2015, 20:29   #10  |  Link
komisar
komisar's Avatar
"--aq-mode 3" is "aq=3:x.yz"
- 0: Disabled
- 3: Auto-variance AQ with bias to dark scenes
Old 15th January 2015, 23:55   #11  |  Link
movmasty
OK many thanks, but this means that dark scenes get more or less bytes?
Old 16th January 2015, 00:04   #12  |  Link
poisondeathray
More
Usually filesize will be larger at a given CRF value
So if you're using --crf 25.9 expecting some rough ball park filesize, you will have to adjust it
Old 16th January 2015, 09:33   #13  |  Link
movmasty
OK, thanks to all and forgive me for all this silly questions
command line, mbtree, x264vfw
