9th June 2009, 16:37 | #4302 | Link |
Probably this table http://en.wikipedia.org/wiki/H.264#Levels
12th June 2009, 20:41 | #4303 | Link |
Temet Nosce
Hi all, I have an issue with a movie and I hope someone can help me out. Please bear with me. Although I am not a video encoding noob I am not an expert either.
I have this DVD movie that I want to play in my portable device. Tech specs here. It is a 4:3 30fps movie. I loaded it into meGUI and converted it to XviD using the following options: profile: Unrestricted 2-pass Balanced size: 640x480 resize to mod 16 autocrop AVIsynth: minimal noise and spline36 filters It encodes ok but when I try to play it in the portable player it stutters all the time. I don't have this problem with other movies I encoded with meGUI. I noticed that after encoding I get a 23.970fps video framerate instead of the original 30fps. Could that be the cause? If so how do I solve this problem? Don't worry about audio or subtitles because I have these under control. My problem is the video stuttering. Thanks in advance for the help.
http://volutabro.blogspot.com |
13th June 2009, 12:17 | #4304 | Link |
Mr. Sandman
that's why you chosen the wrong preset. if you look more carefully you will find there is a "2-pass Balanced (HomeTheatre)" preset. Use that instead.
13th June 2009, 23:13 | #4305 | Link |
Hello,
I'm trying to encode an AVI but strange things seem to be happening when I am in AVIsynth script creator. From within AVIsynth script creator I select the source file and the video preview window opens up - this looks fine. The number of frames for the AVI looks about what I would expect at 60 000 area. After I save the AVIsynth script, the video preview window refreshes but now the number of frames is significantly less, only showing about 2 000 frames. This isn't just an issue with the video preview window because when I run the queued jobs, it really is only doing the 2 000 frames. I've never experienced this problem before. Somehow the majority of the frames are dropping off. Any assistance would be greatly appreciated. My thanks, MK |
14th June 2009, 02:48 | #4306 | Link |
Mr. Sandman
14th June 2009, 03:26 | #4307 | Link |
Hi sharktooth,
I don't know what to say here. It's plain jane. The only option I checked was 'clever anamorphic' and then save! After saving, the video preview window shows the reduced number of frames. It's actually no different than anything I have done for over a hundred re-encodes so no idea whats up here.... |
14th June 2009, 03:39 | #4308 | Link |
Mr. Sandman
save the .avs and play it back on a directshow media player.
if it's still shorter than the source, then there is some problems in either the source or the decoder used by avisynth. in both cases, not posting your .avs script, will not help to identify the problem.
14th June 2009, 06:19 | #4309 | Link |
I didn't know you could play avs files in the media player - I learn something new!
Yes, it is still shorter. It only appears to show the first 1 minute and 40 seconds. What I don't understand is that the source plays just fine, it's just this odd behaviour. Here is the avs script....nothing special at all. Code:
# Set DAR in encoder to 16 : 9. The following line is for automatic signalling global MeGUI_darx = 16 global MeGUI_dary = 9 AVISource("C:\My Documents\Trading\DAX\DAX_20090415.avi", audio=false) #deinterlace #crop #resize #denoise Last edited by MidKnight_1; 14th June 2009 at 07:03. |
14th June 2009, 14:11 | #4310 | Link |
Mr. Sandman
ok, it could be the decoder. AVISource uses VFW decoder instead of DirectShow. That means there could be differencies between the playback of the avi file in your player and the playback of the avisynth script.
you can try with DirectShowSource(".......") in place of AVISource and see if it fixes the problem.
14th June 2009, 16:09 | #4311 | Link |
I've had a problem lately with neverending encodes when using a DGM file created by DGMPGDecNV and otherwise treated as usual with the AVS Script Creator and other MeGUI tools. This has occurred whether using XviD or x264, and what happens is an encode will hit 99%+ completion and then run indefinitely at some encoding rate while the file never gets bigger and the time remaining never decreases. Please find below links to everything relevant:
DGM File: http://pastebin.ca/1460029 AVS Script: http://pastebin.ca/1460031 MeGUI log: http://pastebin.ca/1460033 |
14th June 2009, 21:11 | #4312 | Link | |
15th June 2009, 01:26 | #4313 | Link |
Uggg...this is the re-encode from hell.
Using the directshowsource() worked great for the video but then the audio was still stopping just after the first 2000 odd frames. I extracted the stream from within VDub mod, pulled it into meGUI as the audio source and re-muxed. Almost there now....The one catch now is that the audio gets progressively out of sync. I have read through the search function of the forum that this is from an incorrect framerate used but I don't understand how to set this right. Is this in the muxing area? Or is this within the avisynth script? My sincere thanks in advance, MK |
15th June 2009, 23:13 | #4314 | Link |
one click encoder crashes on 0.3.1.1043
It gives a .NET Framework error
Error registering DragDrop just after d2v creator pass Here is the log for the error Code:
************** Texto de la excepción ************** System.InvalidOperationException: Error al registrar DragDrop. ---> System.Threading.ThreadStateException: El subproceso actual debe establecerse en el modo de subprocesamiento controlado simple (Single Thread Apartment, STA) para poder realizar llamadas OLE. Asegúrese de que la función Main tiene marcado STAThreadAttribute. en System.Windows.Forms.Control.SetAcceptDrops(Boolean accept) --- Fin del seguimiento de la pila de la excepción interna --- en System.Windows.Forms.Control.SetAcceptDrops(Boolean accept) en System.Windows.Forms.Control.OnHandleCreated(EventArgs e) en System.Windows.Forms.TextBoxBase.OnHandleCreated(EventArgs e) en System.Windows.Forms.TextBox.OnHandleCreated(EventArgs e) en System.Windows.Forms.Control.WmCreate(Message& m) en System.Windows.Forms.Control.WndProc(Message& m) en System.Windows.Forms.TextBoxBase.WndProc(Message& m) en System.Windows.Forms.TextBox.WndProc(Message& m) en System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) en System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) en System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** Ensamblados cargados ************** mscorlib Versión del ensamblado: 2.0.0.0 Versión Win32: 2.0.50727.4016 (NetFxQFE.050727-4000) Código base: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll ---------------------------------------- MeGUI Versión del ensamblado: 0.3.1.1043 Versión Win32: 0.3.1.1043 Código base: file:///C:/Program%20Files%20(x86)/megui/MeGUI.exe ---------------------------------------- System.Windows.Forms Versión del ensamblado: 2.0.0.0 Versión Win32: 2.0.50727.4016 (NetFxQFE.050727-4000) Código base: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System Versión del ensamblado: 2.0.0.0 Versión Win32: 2.0.50727.4016 (NetFxQFE.050727-4000) Código base: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Drawing Versión del ensamblado: 2.0.0.0 Versión Win32: 2.0.50727.4016 (NetFxQFE.050727-4000) Código base: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- System.Xml Versión del ensamblado: 2.0.0.0 Versión Win32: 2.0.50727.4016 (NetFxQFE.050727-4000) Código base: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- System.Configuration Versión del ensamblado: 2.0.0.0 Versión Win32: 2.0.50727.4016 (NetFxQFE.050727-4000) Código base: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- System.XML.resources Versión del ensamblado: 2.0.0.0 Versión Win32: 2.0.50727.4016 (NetFxQFE.050727-4000) Código base: file:///C:/Windows/assembly/GAC_MSIL/System.Xml.resources/2.0.0.0_es_b77a5c561934e089/System.Xml.resources.dll ---------------------------------------- jt-eyzdv Versión del ensamblado: 0.3.1.1043 Versión Win32: 2.0.50727.4016 (NetFxQFE.050727-4000) Código base: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- ymlzm_oi Versión del ensamblado: 0.3.1.1043 Versión Win32: 2.0.50727.4016 (NetFxQFE.050727-4000) Código base: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- nc5_0ave Versión del ensamblado: 0.3.1.1043 Versión Win32: 2.0.50727.4016 (NetFxQFE.050727-4000) Código base: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- p8ohpjmq Versión del ensamblado: 0.3.1.1043 Versión Win32: 2.0.50727.4016 (NetFxQFE.050727-4000) Código base: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- uwe3mlwh Versión del ensamblado: 0.3.1.1043 Versión Win32: 2.0.50727.4016 (NetFxQFE.050727-4000) Código base: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- utm2v0mi Versión del ensamblado: 0.3.1.1043 Versión Win32: 2.0.50727.4016 (NetFxQFE.050727-4000) Código base: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- xg9s-on1 Versión del ensamblado: 0.3.1.1043 Versión Win32: 2.0.50727.4016 (NetFxQFE.050727-4000) Código base: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- b1bgkohm Versión del ensamblado: 0.3.1.1043 Versión Win32: 2.0.50727.4016 (NetFxQFE.050727-4000) Código base: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- yyv5yp9k Versión del ensamblado: 0.3.1.1043 Versión Win32: 2.0.50727.4016 (NetFxQFE.050727-4000) Código base: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- fcdg6db9 Versión del ensamblado: 0.3.1.1043 Versión Win32: 2.0.50727.4016 (NetFxQFE.050727-4000) Código base: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- m18-mloz Versión del ensamblado: 0.3.1.1043 Versión Win32: 2.0.50727.4016 (NetFxQFE.050727-4000) Código base: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- dgjivl3d Versión del ensamblado: 0.3.1.1043 Versión Win32: 2.0.50727.4016 (NetFxQFE.050727-4000) Código base: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- co7oy3df Versión del ensamblado: 0.3.1.1043 Versión Win32: 2.0.50727.4016 (NetFxQFE.050727-4000) Código base: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- 4e1ufiox Versión del ensamblado: 0.3.1.1043 Versión Win32: 2.0.50727.4016 (NetFxQFE.050727-4000) Código base: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- ejms5rop Versión del ensamblado: 2.0.0.0 Versión Win32: 2.0.50727.4016 (NetFxQFE.050727-4000) Código base: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- yihbsef5 Versión del ensamblado: 0.3.1.1043 Versión Win32: 2.0.50727.4016 (NetFxQFE.050727-4000) Código base: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- Accessibility Versión del ensamblado: 2.0.0.0 Versión Win32: 2.0.50727.4016 (NetFxQFE.050727-4000) Código base: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll ---------------------------------------- umxtjntk Versión del ensamblado: 0.3.1.1043 Versión Win32: 2.0.50727.4016 (NetFxQFE.050727-4000) Código base: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- e6oz3hqz Versión del ensamblado: 0.3.1.1043 Versión Win32: 2.0.50727.4016 (NetFxQFE.050727-4000) Código base: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Windows.Forms.resources Versión del ensamblado: 2.0.0.0 Versión Win32: 2.0.50727.4016 (NetFxQFE.050727-4000) Código base: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms.resources/2.0.0.0_es_b77a5c561934e089/System.Windows.Forms.resources.dll ---------------------------------------- System.Management Versión del ensamblado: 2.0.0.0 Versión Win32: 2.0.50727.4016 (NetFxQFE.050727-4000) Código base: file:///C:/Windows/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll ---------------------------------------- rltqbtou Versión del ensamblado: 0.3.1.1043 Versión Win32: 2.0.50727.4016 (NetFxQFE.050727-4000) Código base: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- mscorlib.resources Versión del ensamblado: 2.0.0.0 Versión Win32: 2.0.50727.4016 (NetFxQFE.050727-4000) Código base: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll ---------------------------------------- MediaInfoWrapper Versión del ensamblado: 0.7.16.0 Versión Win32: 0.7.16.0 Código base: file:///C:/Program%20Files%20(x86)/megui/MediaInfoWrapper.DLL ---------------------------------------- ************** Depuración JIT ************** Para habilitar la depuración Just In Time (JIT), el archivo de configuración de esta aplicación o equipo (machine.config) debe tener el valor jitDebugging establecido en la sección system.windows.forms. La aplicación también se debe compilar con la depuración habilitada Por ejemplo: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> Cuando esté habilitada la depuración JIT, cualquier excepción no controlada se enviará al depurador JIT registrado en el equipo en lugar de controlarlo mediante el cuadro de diálogo. here are the megui logs Code:
[Warning] Log -[Information] Versions --[NoImage] MeGUI Version : 0.3.1.1043 --[NoImage] OS : Windows Vista Business Edition x64 SP2 (6.0.131072.6002) --[NoImage] Framework used : 2.0 SP1 (2.0.50727.4016) -[Information] Hardware --[NoImage] CPU : Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz -[Information] Log for job1 (idx, VTS_02_1.VOB -> nims island.d2v) --[Information] [15/06/2009 23:55:23] Started handling job --[Information] [15/06/2009 23:55:23] Preprocessing --[NoImage] Job commandline: "C:\Program Files (x86)\megui\tools\dgindex\dgindex.exe" -SD=< -AIF=<E:\Ultimas\NIMS_ISLAND\VIDEO_TS\VTS_02_1.VOB< -OF=<E:\Ultimas\NIMS_ISLAND\VIDEO_TS\nims island< -exit -hide -OM=1 -TN=82,80 --[Information] [15/06/2009 23:55:23] Indexing started --[NoImage] Standard output stream --[NoImage] Standard error stream --[Information] [15/06/2009 23:57:30] Running auto force film ---[NoImage] Film percentage: -1 --[Information] [15/06/2009 23:57:31] Postprocessing ---[Information] OneClick postprocessor ----[NoImage] Desired size: null ----[NoImage] Split size: null ----[NoImage] Auto-detect aspect ratio now: True ----[NoImage] Aspect ratio: 1,823361 ----[NoImage] Output resolution: 720x432 ----[NoImage] AVC level: Level 3.1 ----[NoImage] Resolution adjusted for AVC Level: 720x432 ----[NoImage] Automatic deinterlacing: True ----[NoImage] Deinterlacing used: #Not doing anything because the source is progressive ----[NoImage] Generated Avisynth script -----[NoImage] global MeGUI_darx = 238 -----[NoImage] global MeGUI_dary = 97 -----[NoImage] DGDecode_mpeg2source("E:\Ultimas\NIMS_ISLAND\VIDEO_TS\nims island.d2v", info=3) -----[NoImage] ColorMatrix(hints=true, threads=0) -----[NoImage] #Not doing anything because the source is progressive -----[NoImage] Undot() # Minimal Noise ----[Information] Eliminating duplicate filenames -----[NoImage] Video output file: E:\Ultimas\NIMS_ISLAND\VIDEO_TS\nims island_Video.mkv -----[NoImage] Muxed output file: E:\Ultimas\NIMS_ISLAND\VIDEO_TS\nims island.mkv ---[Information] Deleting intermediate files --[Information] [16/06/2009 0:06:20] Job completed |
16th June 2009, 02:59 | #4316 | Link |
Mr. Sandman
Arshad07: very usefull info without a log...
16th June 2009, 09:08 | #4320 | Link |
Jeremy Duncan Fan
Here's a flash to show that even though i enqueue, its not being queued
http://www.sendspace.com/file/b86276 Open in IE or FF..... |
megui |
