21st May 2009, 13:50 | #4241 | Link |
I've used MeGUI to encode a Blu-ray sourced HD VC1 file to x264, using the iPhone video profile and AAC audio. I used the MeGUI MP4 muxer, but the file won't import into iTunes. When I try to play it in Quicktime, it gives the following error:
I tried muxing the files with NicMP4box (the modified version of MP4box that was hacked together specifically to enable the creation of iTunes compatible MP4 files), but again, it couldn't produce an MP4 that would play in Quicktime or import into iTunes. So, could this mean that the 23.976 frame rate is incompatible with the iPhone? I've never encoded a Blu-ray to iPhone profile h264 before, but have encoded many DVDs and have never had this problem of the file being incompatible. If the problem is with the frame rate, how would I go about converting the frame rate to one that will encode properly? Last edited by simonhowson; 21st May 2009 at 13:58. |
21st May 2009, 16:28 | #4244 | Link | ||
The other application Tagger was a dead link, and I don't have Java installed so I didn't try it. Could it have something to do with the way the file was encoded? All I did was resize the image from 1920 x 1080 to 640 x 368 anamorphic Quote:
Is there a tool that can extract the raw h264 video from the file so I can try remuxing it again from scratch? |
21st May 2009, 17:53 | #4245 | Link |
@simonhowson use mp4box or mp4creator to demux the .mp4 to raw (.264 + .acc)
use mp4box or mp4creator to remux .264 + .aac to a new .mp4 this will solve the problem... to avoid this problem in the future ALWAYS encode to .264 (NOT .mp4) and in the final step mux to .mp4... _ @Kurtnoise do you have another link for Tagger (it looks interesting)... _ |
22nd May 2009, 03:56 | #4247 | Link |
Mr. Sandman
win7 is not finished and still unsupported.
22nd May 2009, 08:29 | #4248 | Link | |
23rd May 2009, 21:16 | #4249 | Link |
NY Frame of Mind
I have a question not related to a problem, but just curiosity.
I'm somewhat new to the HD video arena but have done SD video encodes the last few years (DVD Rebuilder being one) From what I understand, an SD video has a certain max avg bitrate. In other words a smaller than dvd5 group of vob's won't encode to a higher avg bitrate than the original, just because there's more room. At least that is my understanding. By accident, the other day, I entered a higher bitrate than I intended for a input m2ts and the resulting avg bitrate in the 264 file was higher than the original and, of course, the file size was larger. (rawavc output, using X264 standalone avchd profile) I didn't think that was possible, but maybe in the world of m2ts HD it is ?...and Iwonder does that mean the picture quality is improved (sort of like getting something from nothing ?), or maybe the opposite, it's degraded? Comments from the experts much appreciated because my searches turned up nothing. Last edited by rapscallion; 23rd May 2009 at 21:23. |
25th May 2009, 12:58 | #4250 | Link |
My X264 process eat a lot of Ram (process usage vary between 500'000K and 1'500'000K )
The source is a DVD. Such a huge memory usage is normal ? Edit: here is my settings : Job commandline: "C:\Program Files\megui\tools\x264\x264.exe" --crf 21.5 --ref 4 --mixed-refs --no-fast-pskip --bframes 2 --b-pyramid --weightb --trellis 2 --partitions p8x8,b8x8,i4x4,i8x8 --8x8dct --me umh --threads auto --thread-input --sar 3185:2911 --progress --no-ssim --output "H:\Movies\taste of tea.mp4" "H:\Movies\taste of tea.avs" Last edited by karasu; 25th May 2009 at 13:24. |
25th May 2009, 13:55 | #4252 | Link |
Mr. Sandman
TESA is a PLACEBO. Use UMH... you wont see ANY difference and will get a nice speed boost.
@rapscallion: bitrate is not limited by the resolution. x264 can produce files bigger than the original as well as xvid or any other encoders. also, that doesnt mean it can "improve" the source... it cant be done. every time you re-encode you WILL loose some quality (unless you're re-encoding with a lossless method).
25th May 2009, 14:29 | #4254 | Link | |
NY Frame of Mind
25th May 2009, 15:39 | #4255 | Link | |
I dont know what happens if you set a bitrate higher than the raw source. |
25th May 2009, 22:29 | #4256 | Link |
I finally solve my problem with the update.
I delete these keys : And I delete the file "C:\Users\Pierre\Desktop\Streamy\proxy.pac". I don't know how this file was a part of the registry. It was just unzipped from an archive, no installer. Last edited by pihug12; 26th May 2009 at 20:23. |
26th May 2009, 19:29 | #4258 | Link |
Mr. Sandman
bah! i really need to replace the keyboard.
however it's extracted as x264..exe ....
27th May 2009, 04:16 | #4259 | Link |
Recently I noticed that the Cyberlink H.264 decoder does not properly report 1080 lines for AVC encoded video so I've been trying different decoders. CoreAVC works very well but it seems to cause MeGUI's interface to stop responding if you click anywhere on the encoding monitor window. x264.exe still continues to run but you can no longer tell the statistics of the conversion. Any ideas?
megui |
