3rd October 2007, 05:39 | #241 | Link |
I tried Oliver's method...12 monkeys was totally out of sync! Any ideas on how to fix this? Is there a way to check to make sure it is in sync first before encoding it and is there a way to change the audio delay somewhere?
3rd October 2007, 05:46 | #242 | Link |
Ahh, I think I figured out why. I did the wrong framecount :-\ That would be the reason huh? I did it for the counted, not calculated.
Edit: It is still REALLY out of sync!!! AHhhhhhhhhhh Last edited by morphx2; 3rd October 2007 at 06:08. |
4th October 2007, 12:07 | #243 | Link | |
I'm having the exact same problem, always 0xC00D0BB8 error when trying to encode 5.1 to WMA. I'm using WMNicEnc and the CCCP codec pack. Has anyone found a solution for this? |
11th October 2007, 11:32 | #244 | Link |
Doom9ing since 2001
Decoding to 6 mono WAV files and then to WMA Pro ought to always work. Also, WMCmd.vbs has more advanced encoding options than WMNicEnc at this point (thought I'd be happy to help Nic update his tool if he's got time).
25th October 2007, 19:30 | #245 | Link |
Video batch file issue
I have succesfully encoded evo to wmvhd a couple of times using the process described in this forum/thread.
Now im trying to convert the departed HdDVD and Im running into problems. If I graphedit video = vc1-intervideodemultiplexer-intervideo decoder- When the bat file runs it tells me its failed to retrieve duration attribute from source plugin trying alertnate method.... this way will encode the movie as for as 161,160 kbs then it ends. I have the correct frame count set but it always stops right at this point. If i graphedit the video VC1 file or the rebuilt evo file with sonic demux-sonic videodecoder 4.3- the bat. tells me I dont have the correct RGB out pin? I can watch all three versions thru graph edit just fine with a render filter at the end. Im using Xp/Dual Processor with 3 gb of ram demux-avs-grf with a bat file the settings in the bat file are -v_bframedist 1 -v_bdeltaqp 1 -v_mslevel 1 -v_codec wvc1 -v_keydist 3 -v_mode 2 -v_quality 96 -v_mmatch 0 -v_msrange 0 -v_performance 20 -v_loopfilter 1 -a_codec wmapro -a_setting 192_44_2_24 the settings in the video avs file are fps=23.976, audio=false, seekzero=false, seek=true).trim(0,227679) Ive also used framecount=xxxxxx my audio is standard and not a concern, I dont need 5.1 audio and that side of things appears to be fine. |
29th October 2007, 14:32 | #246 | Link |
http://rapidshare.com/files/66107349...h_5.1.doc.html
Hello everyone and anyone. This link will download EVO to WMV HD with 5.1 support guide. I do not pretend to be a mastermind with computers and can say I started originally with OliverDB's guide. All this guide is a more thorough guide going from start to finish so anyone even with basic computer knowledge can understand it. (something I could not understand with OliverDB as I think his guide is for people who know what they are doing) where is I at first did not. Last edited by Sephiroth0000; 29th October 2007 at 22:19. |
30th October 2007, 04:24 | #247 | Link |
Sephiroth0000 - I'm soooo happy to find your guide! i'm really new and i'm trying it now!
thanks i've already learned a lot from it just a few things questions i have already: 1. when i downloaded GraphEdit you linked me to an old version. I already downloaded a new version i think and i don't have the files you talk about moving into the system folder. should i just download the old version or new? 2. i can't find a version of Sonic CinePlayer 4.3 I found 4.2 is that going to be a problem? thanks again! |
30th October 2007, 11:42 | #248 | Link | |
30th October 2007, 19:22 | #249 | Link |
Thanks Sepiroth
Sepiroth first and foremost thank you for your guide it has been very helpful.
Do you think you can explain why a windows media encode would crash at the same place in the movie everytime? Ive tried everything. Ive changed VBR modes Ive adjusted audio levels, conversion size, what am I missing?...I just cant figure this one out . |
31st October 2007, 04:02 | #250 | Link |
Thanks for the guide Sephiroth0000!
I have one question. How do you handle audio sync problems? Some HDDVD's I own covert just fine but others like a certain Giant Robot movie are giving me fits. Any help/hints/voodoo would be welcome. Thanks |
31st October 2007, 10:21 | #251 | Link | |
31st October 2007, 10:26 | #252 | Link | |
Oh and also I have found when I do transcodes for HD DVD and make my system do other stuff like browsing or what not it causes problems and especially if your PC hibernates or anything. Problems I have suffered with are crashes during the transcode aswell as choppy video. Now I just leave the PC until it is finished. AT LEAST YOU HAVE THE GIANT ROBOT MOVIE TO PLAY WITH ! I CAN'T GET IT ANYWHERE HA, HA, HA |
31st October 2007, 12:54 | #253 | Link |
Thanks for the quick response. I'm basically using your method.
1. I rip with AnyDVDHD. 2. Use Evodemux to get the calculated frames. 3. Then use Evodemux to rebuild the evo into one big evo. 4. Demux the h624 stream and the DD+ audio stream. 5. Build a .grf for the video stream. Transformers_HDDVD.264>Sonic HD Demuxer>CyberLink H.264/AVC Decoder I had problems with strange artifacts with the Sonic Video filter. 6. Then create a .avs. DirectShowSource("C:\encodes\Video_Transformers.GRF", fps=23.976, audio=false, seekzero=false, seek=true, framecount=206368) Spline36Resize(1280,720) Crop(0,92,0,-88) ConvertToYV12() 6. Use this .bat file to convert and encode the audio stream to wma. C:\EncodingTools\eac3to\eac3to.exe %1 C:\encodes\output.wav c:\encodes\tranzcode.exe c:\encodes\output.wav c:\encodes\output c:\encodes\wavavimux -o c:\encodes\audio.avi -iwav 6 output-FL.wav output-FR.wav output-C.wav output-LFE.wav output-SL.wav output-SR.wav -mask 63 cscript.exe c:\encodes\wmcmd.vbs -input c:\encodes\audio.avi -output c:\encodes\Encoded_audio.wma -audioonly -a_codec WMAPRO -a_mode 0 -a_setting 768_48_6_24 7. Use this bat file to encode the video cmd /k cscript.exe c:\encodes\wmcmd.vbs -input %1 -output c:\encodes\"%~n1".wmv -v_codec WVC1 -videoonly -v_mode 0 -v_bitrate 8000000 -v_keydist 4 -v_buffer 600000 -v_quality 100 -v_preset better 8. Then I use the Windows Media Stream Editor to mux the wma and wmv together. 9. I usually then watch it and enjoy.. but not this time It appears to me that the audio is just behind the video. I know you are supposed to be able to determine the delay using Evodemux but I have tried using methods I found from searching posts here on doom9, but they don't seem to be working. (Looking at the Video First PTS and Audio First PTS and trying to determine it from there). Maybe I'm not calculating it correctly or maybe I don't really know what I'm doing . Thanks for your help. |
31st October 2007, 13:43 | #254 | Link | |
31st October 2007, 13:47 | #255 | Link |
I am purchasing Transformers HD DVD aswell from the States this week so I will let you know how I get along aswell if you are unable to clear up the problem. You said you had some funky things going on with Sonic. Did you change the AllowAllRenders? Oh and also how have you registered the ax files from Graphedit? What operating system are you using aswell?
31st October 2007, 16:12 | #256 | Link | |
RegSvr32 to register the dump.ax and one or two other filters who's names escape me right now. I'm still running WinXP Pro SP2 with current patches. (Haven't switched to vista - don't really want to). I did notice that Evodemux list the framerate for the H.264 video at 60fps. Thanks again for helping .... hopefully it will be an easy fix or just something I overlooked. I will take your advice and use a different audio stream. |
31st October 2007, 16:42 | #257 | Link | |
31st October 2007, 18:44 | #259 | Link |
I think the extensions may be wrong. It should be being reconised as VC1. Go under options and give video the extensions of VC1, audio the extensions of DDP and subtitles SUP (that is if you wish to enclude subtitles)
1st November 2007, 02:28 | #260 | Link |
I double checked and it says on the disc case
"Two-Disc Set (Video Resolution/Codec) 1080p/MPEG 4" usually they say 1080p/VC-1. I did solve my audio problem. I used delay cut on the big .wav that gets created by eac3to. I used -83ms delay and it seems to be ok. I have not watched all of the movie again but I did skip around and the audio seems to stay in sync trough out the movie. |
