10th October 2011, 17:51 | #6081 | Link | ||
But I only could play it using the MPC-HC internal splitter+ffvideo decoder (audio had a problem tho)
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread |
10th October 2011, 18:05 | #6082 | Link | |
Making LAV Audio and Video compatible with the MPC-HC RealMedia splitter doesn't look easy, it supplys completely different data..
10th October 2011, 18:35 | #6084 | Link |
rmvb is handled just fine, exactly the same as rm. I really don't care for the extension, its just realmedia files for me.
10th October 2011, 18:37 | #6085 | Link |
I've found a solution for my "blank screen" problem. I'm using the DVI out with a DVI-> VGA adapter into my computer monitor. Then the HDMI goes out to the receiver as usual. I am using the connectors on the same output instead of HDMI + output 2. Now when I turn off the TV I still have picture on my computer monitor. Also, I can confirm that 24-bit padded to 32 works great through HDMI with WASAPI and I get 6 channels. So now everything is 100% (I think). Please see a screenshot of all settings: screenshot of settings
SETUP: Win 10/MPC-HC/LAV/MadVR HARDWARE: Fractal Design Node 804 | Xeon E3-1260L v5 | Supermicro X11SSZ-TLN4F | Samsung 2x8GB DDR4 ECC | Samsung 850 EVO 1TB | MSI GTX 1650 Super | EVGA G2 750 |
10th October 2011, 19:20 | #6086 | Link | |
I guess the problem was between lavsplitter and ffdshow video not communicating correctly. It wasn't my intention to use internal splitters, it was only a sidenote. I think it would be good if you added some tray icons for lav video and audio as ffdshow, so when you hover the mouse you can see the main information.
10th October 2011, 19:55 | #6089 | Link |
I think it stands for dynamic range compression, and it does just that with Dolby tracks that support it.
Doh! I just saw that it clearly says "Dynamic Range Compression" in that section of the LAV control panel. So if you're actually asking what it is, it levels loud and quiet sounds so there's not a lot of dynamic range, useful when listening at low levels. Last edited by Andy o; 10th October 2011 at 20:02. |
10th October 2011, 20:01 | #6090 | Link |
Oh right, that's what it stands for, yea. But it's metadata about the levels that are supposed to be used or something like that, yea?
10th October 2011, 20:15 | #6091 | Link |
QB the Slayer
@ Xaurus
IIRC, you should have all the output formats of LAV Video checked and not just YV12 alone. But then again I may be wrong, so someone else please chime in if I am indeed incorrect QB
10th October 2011, 21:41 | #6093 | Link | |
Awesome, thank you very much again! Edit: sorry again but it's still not completely fixed ^^;; After checking many FLVs, I encountered problems with 2: Sample3 (green line on the side) / Sample4 (cropping issue on right side).
XP SP3 / Geforce 8500 / Zoom Player Last edited by TheShadowRunner; 10th October 2011 at 22:19. |
10th October 2011, 22:17 | #6094 | Link | |
In other news, my little "fix" didn't work after all... now the stupid setup is behaving the same way, when turning off the TV my computer monitor goes blank. WTH.
10th October 2011, 22:33 | #6095 | Link |
I was told that LAVCUVID standalone decoder is being abandoned.
I could never make it work on two separate completely unlike machines. I'm a little apprehensive of installing LAV Video filter since I never could make LAVCUVID work. Can someone please help me understand what I'm doing wrong with LAVCUVID? I asked my question in the LAVCUVID forum thread as well. I REALLY, REALLY, REALLY want LAVCUVID to work. It's really been bugging me what I'm doing wrong. I posted my question in the LAVCUVID forum thread. If I still cant get LAVCUVID to work; even with the help of people here, I am hoping someone could tell me how to completely remove every trace of LAVCUVID from my system registry (GUID references, etc). I have a perfect, brand new installation of Windows 7 64bit with all new software. Everything is a brand new installation. Thanks for anyone that can help. |
11th October 2011, 00:02 | #6096 | Link |
madVR, at least accepts YV12, NV12 and P010 for 4:2:0 content. I have not tested P016 but it wouldn't surprise me if it accepts that as well. For 4:2:2, I don't know what it accepts but I'm guessing YUY2, UYVY and P210 as well.
It also accepts RGB32 and RGB24, and finally probably AYUV and Y410.
Forget about my old .3dlut stuff, just use mpv if you want accurate color management |
11th October 2011, 00:22 | #6097 | Link | |
11th October 2011, 02:57 | #6098 | Link | |
Type CPU ? Motherboard ? What's the version of your vid-drivers ? What happens if you "try"to use LAVCUVID ? No video (black screen), crash,.. what errors are given ? Current LAV-video = former (LAV-video + LAVCUVID) with some performance improvements wrt the LAVCUVID part. Can you use DXVA with any other decoders ? (like the internal one from MPC-HC or Cyberlink , ArcSoft, Coreavc, ffdshow-dxva mode or other??...). I'm using LAV-video (with LAVCUVID built in) since a lot of versions back without any problems on my GTX-570 and I'm very pleased with the LAV-filters !! Especially the HW VA de-interlacing is kind of unique! |
11th October 2011, 05:18 | #6099 | Link | |
QB the Slayer
QB
11th October 2011, 07:54 | #6100 | Link | |
If I do that there are no problems, I can switch between the TV and the computer monitor without problems and turning off one of them doesn't turn off the other... This issue is really, really bothering me though... I have even contemplated running analogue audio out from the motherboard into the 7.1 in on the AVR and run the gfx card directly to the TV.
