Old 4th December 2019, 13:06   #1  |  Link
yellowolf
How to get the duration of a Blu-ray disk with millisecond accuracy?
I want to get the duration with millisecond accuracy and have tried BDInfo 0.7.5.5 (GUI). However, it reports the duration as hh:mm:ss without the precision of milliseconds. Any help would be deeply appreciated.
yellowolf is offline   Reply With Quote
Old 4th December 2019, 13:25   #2  |  Link
Sharc
Number of frames / framerate.
Isn't the time resolution = 1/framerate, means for a 60fps it is 16.667 ms, or for a typical blu-ray movie @23.976 fps the time resolution is 41.708ms? But never 'milliseconds accuracy'.
Old 4th December 2019, 17:50   #3  |  Link
ocean
Hi yellowolf, welcome to the forum, you can try mediainfo by selecting advanced mode:
https://www.videohelp.com/software/MediaInfo
ocean is offline   Reply With Quote
Old 5th December 2019, 10:43   #4  |  Link
yellowolf
Hi ocean, thank you for your help, I never notice this feature before. As I want to detect the duration of quite a lot of BDs, I would like to use the command line version of MediaInfo. The basic usage is "mediainfo.exe k:\BDMV\PLAYLIST\00800.mpls". However, it seems that MediaInfo always takes over 3 minutes to list all the detailed information for each BD. I have tried some options to accelerate this progress but no gains. As what I need is only the duration, is it possible to shorten this process by using appropriate options of MediaInfo?
Old 5th December 2019, 17:35   #5  |  Link
Ghitulescu
Ghitulescu's Avatar
Now, seriously, why do you need this precision? In particular with DF the duration may actually differ across various players.
PS: not even the audio is required to be aligned with video at millisecond (IIRC it's 1/3 frame that is some 10 milliseconds).
Born in the USB (not USA)
Old 5th December 2019, 19:03   #6  |  Link
ocean
Use the GUI interface to read, is immediate, example:
Old 6th December 2019, 08:48   #7  |  Link
Ghitulescu
Ghitulescu's Avatar
Why picking up 1h 32m 54s 610ms and not 1h 37m 53s 11f?
Let's say the movie has 140787 frames.
If the speed is 23.976fps, the time in seconds is almost 5872 seconds (xxx1, 99699699 etc etc).
But if it's 24/1.001, it will be already 6 millisenconds off. By true 24fs, it will play for ~5866 seconds: 6120 milliseconds less.
To further push this phylosophically discussion into the absurd, let's notice that the last frame has no proper duration (all other frames are replaced by the next image at its PTS (Presentation Time Stamp), that is its duration is given by the difference between those two PTSs. It should be also a PTS after the last frame (link-pts), but AFAIK is not mandatory used, many players giving the last frame the same duration as the preceding one/s or using pkt-duration (imprecise). The clock is also required to be within 4 millisecond tolerance.
Thus it all boils down to what the OP intends to do....
Old 6th December 2019, 12:12   #8  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
Indeed, it's a huge bug of MediaInfo!
r0lZ
Old 6th December 2019, 14:48   #9  |  Link
yellowolf
Thanks a lot. Why MediaInfo gives more than one duration, among which some ones are with the totally same format and value? Which duration should I believe?
Old 6th December 2019, 16:13   #10  |  Link
ocean
Thanks Ghitulescu for the clarification, mine was just an example where to read the time in milliseconds, it is clear if the frames are: 140787:23,976 (fps)= 5871,997:60=97,866.... the value can be 1h 37m 51s 997 ms.
Old 6th December 2019, 16:50   #11  |  Link
yellowolf
Thanks your scientific explanation. As a layman, I seem to have catch the point.
blu-ray, duration
