Old 23rd April 2017, 01:36   #5261  |  Link
pradeeprama
x265 version 2.4 has been released. This release incorporates support for the new HDR10+ standard, and revised lambda tables for main, main10, and main12 profiles that significantly improve visual quality!
Version 2.4 can now be downloaded from here (md5: ab0986aa5c4465b874de94095b0d0cae). Full documentation is available at http://x265.readthedocs.io/en/stable/.
Release Notes for Version 2.4
Release date - 22nd April, 2017.
Encoder enhancements
1. HDR10+ supported. Dynamic metadata may be either supplied as a bitstream via the userSEI field of x265_picture, or as a json file that can be parsed by x265 and inserted into the bitstream; use --dhdr10-info to specify json file name, and --dhdr10-opt to enable optimization of inserting tone-map information only at IDR frames, or when the tone map information changes.
2. Lambda tables for 8, 10, and 12-bit encoding revised, resulting in significant enhancement to subjective visual quality.
3. Enhanced HDR10 encoding with HDR-specific QP optimizations for chroma, and luma planes of WCG content enabled; use --hdr-opt to activate.
4. Ability to accept analysis information from other previous encodes (that may or may not be x265), and selectively reuse and refine analysis for encoding subsequent passes enabled with the --refine-level option.
5. Slow and veryslow presets receive a 20% speed boost at iso-quality by enabling the --limit-tu option.
6. The bitrate target for x265 can now be dynamically reconfigured via the reconfigure API.
7. Performance optimized SAO algorithm introduced via the --limit-sao option; seeing 10% speed benefits at faster presets.
API changes
1. x265_reconfigure API now also accepts rate-control parameters for dynamic reconfiguration.
2. Several additions to data fields in x265_analysis to support --refine-level: see x265.h for more details.
Bug fixes
1. Avoid negative offsets in x265 lambda2 table with SAO enabled.
2. Fix mingw32 build error.
3. Seek now enabled for pipe input, in addition to file-based input
4. Fix issue of statically linking core-utils not working in linux.
5. Fix visual artifacts with --multi-pass-opt-distortion with VBV.
6. Fix bufferFill stats reported in csv.
Happy Compressing!
x265 team.
pradeeprama is offline   Reply With Quote
Old 23rd April 2017, 02:26   #5262  |  Link
Midzuki
Unavailable
Midzuki's Avatar
x265.exe 2.4+2-5bc5e73760cd
https://forum.videohelp.com/threads/...84#post2483884
Midzuki is offline   Reply With Quote
Old 23rd April 2017, 08:37   #5263  |  Link
dipje
Originally Posted by Selur View Post
not exactly, it was merged to default branch two days ago, and since then any new build includes the new lambda tables.
Ah so that was the catch I was missing .
It looked reverse on my end , (I've read it wrong it bitbucket apparently?),
Like it was added to the default branch , but 2 days ago that default branch was merged into 'stable branch.
So it depends which branch is used in the builds , but I believe most people who are nice enough around here use the default branch.
Anyway, talking about nice people who builds, can we expect a 2.4 build from LigH, or are you still having compilation problems?
dipje is offline   Reply With Quote
Old 23rd April 2017, 08:50   #5264  |  Link
Midzuki
Unavailable
Midzuki's Avatar
Over here, no compiler warnings happened.
But I didn't enable the HDR10+ thing, I was too lazy to edit CMakeLists.txt.
LigH's next build of x265 will appear sooner or later anyway
Old 23rd April 2017, 10:14   #5265  |  Link
Selur
Selur's Avatar
quick question about the new options:
   --dhdr10-info <filename>      JSON file containing the Creative Intent Metadata to be encoded as Dynamic Tone Mapping
   --[no-]dhdr10-opt             Insert tone mapping SEI only for IDR frames and when the tone mapping information changes.Default disabled
Do I get it right that: dhdr10-info is always required for dynamic hdr10 and dhdr10-opt is an option which allows to limit how often the tone mapping SEI is inserted?
Also does it also require '--hdr' or are those separate?
Old 23rd April 2017, 11:34   #5266  |  Link
LigH
LigH's Avatar
Mateusz Brzostek proposed a patch:
[x265] [PATCH] cmake: set '-std=gnu++11' for GCC if ENABLE_DYNAMIC_HDR10 is on
but it has not yet been commited. And I have only little experience in manual working set management with TortoiseHg, I prefer using only commited updates.
_
P.S.: I tried to import this patch, but it failed with code 255. Might be because the base changeset is already outdated?
New German Gleitz board
Old 23rd April 2017, 11:41   #5267  |  Link
Selur
Selur's Avatar
multilib.sh should also be adjusted,..
for clang it's c++11 instead of gnu++1 and in encoder.h:
-    #include "dynamicHDR10\hdr10plus.h"
+    #include "dynamicHDR10/hdr10plus.h"
Old 23rd April 2017, 11:55   #5268  |  Link
LigH
LigH's Avatar
Of course, I made my own builds script by adding "-DENABLE_DYNAMIC_HDR10=ON" to 10 and 12 bit libraries.
Old 23rd April 2017, 12:42   #5269  |  Link
Barough
Barough's Avatar
x265 v2.4+2-5bc5e73760cd (MSYS/MinGW, GCC 6.3.0, 32 & 64bit 8/10/12bit multilib EXEs)
x265 [info]: HEVC encoder version 2.4+2-5bc5e73760cd
x265 [info]: build info [Windows][GCC 6.3.0][32 bit/64 bit] 8bit+10bit+12bit
x265 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX AVX2 FMA3 LZCNT BMI2
https://bitbucket.org/multicoreware/x265/commits/branch/default
HDR10 Enabled
Old 23rd April 2017, 13:01   #5270  |  Link
Ma
If you save 3 attachments "warnings.patch", "cmake-hdr10.patch" and "dhdr10.patch" to your x265 folder, you can execute (in MSYS)
patch -p1 <warnings.patch
patch -p1 <cmake-hdr10.patch
patch -p1 <dhdr10.patch
If you want clean source (remove these patches), please execute
hg update -C
Ma is offline   Reply With Quote
Old 23rd April 2017, 15:01   #5271  |  Link
stax76
stax76's Avatar
-limit-tu 4 is in slower and veryslow preset
a new issue I see is mediainfo don't show any info like depth 10, main 10, resolution 10 when using mkv
is this issue caused by mkvmerge, mediainfo or x265?
for mp4 output it's there:
Old 23rd April 2017, 15:07   #5272  |  Link
Selur
Selur's Avatar
isn't new been that way for a few month as I remember, but I never really looked into it
Old 23rd April 2017, 15:12   #5273  |  Link
stax76
stax76's Avatar
This is really new because every time when I update the x265 build I make a 8 bit and a 10 bit encode to verify it's actually a multi lib build.
Old 23rd April 2017, 15:13   #5274  |  Link
Selur
Selur's Avatar
Strange, noticed this month ago,...
Old 23rd April 2017, 15:14   #5275  |  Link
stax76
stax76's Avatar
I don't update mediainfo often, could be a mediainfo issue then, not sure when I updated it the last time.
Old 23rd April 2017, 15:24   #5276  |  Link
sneaker_ger
Mkvmerge somewhere between 10.0.0 and 11.0.0. But that doesn't necessarily mean it's a bug in mkvmerge.
Old 23rd April 2017, 15:35   #5277  |  Link
stax76
stax76's Avatar
I've posted it also to Mosu's and Zenitram's thread.
Old 24th April 2017, 13:51   #5278  |  Link
LazyNcoder
Hi guys,
I want to know what's the deal with this --limit-tu option in new v2.4. is it on by default in slow and very slow presets or should we enable it manually?
If it's not default, what's the best value for it? which level of the option would affect the quality the lower?
I usually encode with slow preset. should I need other options we've talked before like --rskip --limit-refs 3 --limit-modes and so? I care about quality the most, but it won't hurt to have a faster encoding.
Thanks
LazyNcoder is offline   Reply With Quote
Old 24th April 2017, 14:02   #5279  |  Link
stax76
stax76's Avatar
Originally Posted by LazyNcoder View Post
Hi guys,
Thanks
It's 4 with slower and veryslow, otherwise 0.
https://x265.readthedocs.io/en/default/presets.html
https://bitbucket.org/multicoreware/...#param.cpp-401
Old 24th April 2017, 14:04   #5280  |  Link
LigH
LigH's Avatar
Verbose documentation
Preset options
As you can see, the developers enabled TU limiting mode 4 for presets "slower" and "veryslow" only ("placebo" has always everything enabled, no matter how much time it wastes for how little improvement; and any faster preset is probably still fast enough without limiting).
You may agree to me that an average user may not easily understand the meaning of the four different modes, it may require in-depth understanding of the encoder. I would recommend to trust the developers using a good choice in their presets, and anyone who is certain to know it better may explain to us why...
