Old 12th April 2011, 09:20   #41  |  Link
Didée
Originally Posted by SubJunk View Post
I have added the new parameter "GPU" ...
Please let me know if it works for you
With GPU=false it doesn not work correctly for me.
On Intel Pentium-D (WinXP): the output shows a 2x2 array of the input.
On Intel i7-860 (Win7): every few moments, there are green "flashes" all over the screen. (Didn't look close - could be the green builds a "cross" pattern, related to the grid of the 2x2 array.)
src = colorbars().converttoyv12().reduceby2().showframenumber()
dbl = src.interframe(GPU=false,FlowPath="C:\ [...] \InterFrame-1.5\Dependencies\")
stackhorizontal( interleave(src,src).subtitle("source").addborders(4,4,4,4),
 \               dbl.subtitle("InterFrame(GPU=false)").addborders(4,4,4,4))
return(last)
Colorbars is just for demonstration. Running a native 1280x720 clip shows the same issue.
Old 12th April 2011, 09:23   #42  |  Link
Gavino
Avisynth language lover
Originally Posted by -Vit- View Post
One thing that immediately stands out is the EEDI2 custom pelclip. That's from the MVTools docs; doesn't that example assume interlaced source? Because it discards half the lines, interpolates them back, then resizes.
EEDI2 doesn't discard half the lines. It resizes an image by 2x in the vertical direction by copying the existing pixels and interpolating new ones in between them. So it works for progressive sources - the MVTools doc example is assuming progressive as it doesn't call SeparateFields before EEDI2.
Old 12th April 2011, 09:48   #43  |  Link
SubJunk
return(last)
Darn, that happens for me too.
It is related to that dll (libflowsse.dll) because it even happens with a simple script like this:
svp_flow_lib = "C:\path\libflowsse.dll"
Super = MSuper()
backward = MAnalyse(Super, isb=true)
forward  = MAnalyse(Super, isb=false)
MSmoothFps(Super, backward, forward, num=48000, den=1001, algo=23)
I will contact the SVP guys, it is probable that it was an incorrect assumption of mine that libflowsse.dll would work the same as libflowgpu.dll.
SubJunk is offline   Reply With Quote
Old 12th April 2011, 09:56   #44  |  Link
-Vit-
Ah yes, I forgot; the meaning of "field" is completely different between EEDI2 and [EEDI3/NNEDI2/NNEDI3]. (...)
-Vit- is offline   Reply With Quote
Old 12th April 2011, 10:12   #45  |  Link
Gavino
Perhaps it would have been a good idea to test this before releasing it...
Old 12th April 2011, 11:59   #46  |  Link
SubJunk
I had tested it, but not thoroughly enough. I had run a preview of the script and it was perfect, because the bug only affects 1 in every 2 frames (the preview happened to be on a good/original frame)
I would usually test more thoroughly but I had several users without GPUs posting that it no longer worked so I wanted to release the fix ASAP for them
That's convenient! I've also noticed that sometimes the documentation for those plugins just says "this has the same parameters as *function in other plugin*" so you have to open the other documentation It's a fun ride, but worth it
Old 12th April 2011, 22:46   #47  |  Link
SubJunk
Version 1.5.1 is released with the GPU=false fix. Sorry to the people who encountered this bug.
Old 13th April 2011, 06:25   #48  |  Link
SubJunk
Version 1.5.2 is released which is very minor, it just changes the default value of GPU from true to false because I discovered that the GPU mode reduces quality slightly.
It's a problem with SVP and the developers are aware of it so hopefully there is a fix coming soon
Old 19th April 2011, 23:31   #49  |  Link
SubJunk
Version 1.6 is released which fixes the GPU mode bug and adds more presets for realtime users. Enjoy
Old 20th April 2011, 22:00   #50  |  Link
jemm54
jemm54's Avatar
Hello, im having problems with this plugin, this is the error:
[Image]
im not sure what that means....
BTW, thanks for the plugin....
Edited: Make the picture smaller or upload it somewhere else and give a link. I've refused the pic.
jemm54 is offline   Reply With Quote
Old 20th April 2011, 22:34   #51  |  Link
SubJunk
Hi jemm You need a slash at the end of the FlowPath, so try:
InterFrame(FlowPath="C:\Archivos de programa\AviSynth 2.5\plugins\")
Old 26th April 2011, 16:48   #52  |  Link
Gargalash
Hello Subjunk,
Thanks for this tool!
I have tried it and noticed something.
With default settings: --- EDIT: not default settings. I'm using preset "fast" and tuning="smooth" ---
- GPU= false, CPU usage is 48-50%, 42fps
- GPU= true, CPU usage is 46-48%, 46fps
The fps numbers are with vdub "video analysis pass" and my script has I have SetMTMode(2) before your filter.
If I don't use SetMTMode(2) I get about 13% CPU usage and 13fps for both true and false GPU. The AVI source I am using is on a SSD, I doubt it's creating the limitation.
Should this filter be using full cpu power? I have an i7 with multi-threading on.
Thanks for any input!
Gargalash is offline   Reply With Quote
Old 26th April 2011, 21:17   #53  |  Link
SubJunk
Hi Gargalash
Without SetMTMode the script will run in single-threaded mode, so 13% CPU probably just means it is using 100% of one CPU.
For the fastest results you should set the second number to 1.8x your thread count. So for example some quad-core CPUs have 4 cores but support 8 threads, so for that you would do 1.8*8 and round down to 14 so it would be:
SetMTMode(2,14)
Some people find they can just double the amount of threads and subtract one, but others find the 1.8x rule to provide better stability so I recommend that.
Hope that helps
Old 27th April 2011, 06:04   #54  |  Link
PelPix
Hey SubJunk, I went back to InterFrame for motion blur because of the quality, but I'm having the problem I described earlier.
In the trails, the original frames are more visible than the interpolated frames. They have more weight in the accumulation/are held for longer/repeated more times. Is this intentional or a bug, and if it's intentional, is it for perceptual reasons?
PelPix is offline   Reply With Quote
Old 27th April 2011, 06:10   #55  |  Link
SubJunk
Hi PelPix Can you post an example so I can see what you mean?
Old 27th April 2011, 06:11   #56  |  Link
SubJunk
Removed double-post
Old 27th April 2011, 06:12   #57  |  Link
PelPix
Yup! one second!
I apparently just lost that source video and can no longer duplicate the problem . I'll let you know the second it comes up!
In other news, InterFrame+an accumulative temporal filter (Like TemporalSoften) makes a mean synthetic motion blur:
Yet another use for this really amazing script.
(Sorry about the quality. I had to screencap it from a render snapshot because it was currently rendering)
Old 27th April 2011, 06:36   #58  |  Link
SubJunk
It looks great, glad it's working for ya
Old 27th April 2011, 18:08   #59  |  Link
Gargalash
Hi Gargalash
SetMTMode(2,14)
Hope that helps
Hi, thanks for your answer. I manage to get cpu usage to 93% and run the filter at 53-54 fps.
Old 27th April 2011, 21:32   #60  |  Link
SubJunk
Great, I'm glad it works for you Remember that the presets control the speed and quality so you can make that FPS higher or lower with them.
Tunings also affect it; the smooth tuning will make it run slower.
48fps, 60fps, framedoubling, interframe, smooth motion
