Old 8th July 2010, 00:08   #1461  |  Link
73ChargerFan
73ChargerFan's Avatar
Originally Posted by dansrfe View Post
is Haali Renderer open-source by any chance?
No it isn't.
73ChargerFan is offline   Reply With Quote
Old 8th July 2010, 00:37   #1462  |  Link
dansrfe
Dear Haali,
If you are still out there and visit doom9, can you please make your renderer open source for the benefit of videokind.
Thanks
Old 8th July 2010, 02:02   #1463  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
dansrfe
Believe it or not, it was asked so many times so now we can say that there is no hope.
Old 8th July 2010, 05:48   #1464  |  Link
Malow
In bytes we trust
Malow's Avatar
Originally Posted by laserfan View Post
Izzat right? I can find only that the last official release was 197.45, and the last 197 beta was .57.
http://downloads.guru3d.com/Forcewar...load-2554.html
found here. was the latest ive found before 2xx
Malow is offline   Reply With Quote
Old 10th July 2010, 05:23   #1465  |  Link
dansrfe
Can someone at least make a patch or bugfix for the Macrovision error when playing DVD's in Win 7? That's the only problem I have. Everything else works great for me with Haali Renderer.
Old 15th August 2010, 01:53   #1466  |  Link
leeperry
Kid for Today
new build of the HMS package available: http://haali.su/mkv/
Fixed items:
Fixed aspect ratio processing in certain Matroska files, which caused errors on open
Old 15th August 2010, 07:55   #1467  |  Link
dansrfe
Bugfix for the Macrovision error when playing DVD's in Win 7!
Old 15th August 2010, 16:53   #1468  |  Link
oddball
I've noticed when Haali is used as splitter instead of internal MPC-HC's splitter I get more dropped frames by scrolling up and down a webpage during playback. Any idea why? This is worse in combination with CoreAVC than DXVA although DXVA does it as well. Just not as badly. Not that you should be doing anything other than watching the video of course
oddball is offline   Reply With Quote
Old 16th April 2011, 18:28   #1469  |  Link
LigH
LigH's Avatar
Just noticed:
While an OpenGL application runs, the Haali Renderer silently fails and simply shows blackness. VRM9 Renderless at least reports a problem:
Error creating DX9 allocation presenter
CreateDevice failed
D3DERR_OUTOFVIDEOMEMORY
OK
New German Gleitz board
Old 16th April 2011, 19:46   #1470  |  Link
JanWillem32
JanWillem32's Avatar
MPC-HC's VMR-9 (renderless), EVR CP and EVR Sync have a few error messages built-in. I do hope a few more can be added soon, as a lot of items can still fail silently.
development folder, containing MPC-HC experimental tester builds, pixel shaders and more: http://www.mediafire.com/?xwsoo403c53hv
JanWillem32 is offline   Reply With Quote
Old 8th August 2011, 00:01   #1471  |  Link
mzso
Hi!
How is this renderer supposed to work? Because anytime I tried it all it did for scaling was magnify pixels into blocks, which is totally hideous. But why doesn't it work? All the other renderers are functioning.
Old 16th August 2011, 13:11   #1472  |  Link
mzso
Haali renderer looks like this. With huge blocks. Can anyone at least give a hint what could cause it to show such broken rendering?
Old 16th August 2011, 13:16   #1473  |  Link
Thunderbolt8
somethings cleary wrong there (dont ask me what it is though), thats not the normal image quality. maybe others can help if you post your (player) configuration
Laptop Acer Aspire V3-772g: i7-4202MQ, 8GB Ram, NVIDIA GTX 760M (+ Intel HD 4600), Windows 8.1 x64, madVR (x64), MPC-HC (x64), LAV Filter (x64), XySubfilter (x64)
Old 16th August 2011, 13:29   #1474  |  Link
mzso
So far it seems player independent. Looks like that with MPC-HC, kmplayer, potplayer. Also changing the renderers settings do nothing to help the issue
Old 16th August 2011, 13:41   #1475  |  Link
namaiki
Is Haali Renderer loading in those situations? Check the Play-> Filters menu (in MPC-HC).
namaiki is offline   Reply With Quote
Old 16th August 2011, 17:35   #1476  |  Link
mzso
Yeah. It alway loads, like this.
Old 16th August 2011, 18:31   #1477  |  Link
ForceX
Funny. Turn on Haali's OSD and post a screenshot. Also, try changing the Sharpness slider, see if that has an effect on the picture.
ForceX is offline   Reply With Quote
Old 16th August 2011, 18:48   #1478  |  Link
mzso
Here's one.
I didn't notice any change when I moved the slider.
Old 16th August 2011, 22:00   #1479  |  Link
namaiki
What else is being loaded? Any chance that there is any other filter that might be doing resizing like DirectVobSub's double resolution option? (though it is already weird if the sharpness setting in Haali Renderer isn't working)
Old 16th August 2011, 22:36   #1480  |  Link
mzso
Nothing of the sort... I'm clueless.
haali, haali renderer
