Old 17th September 2009, 08:27   #121  |  Link
leon1789
leon1789's Avatar
Originally Posted by thewebchat View Post
http://img136.imageshack.us/img136/1469/dongs.png
leon1789's method seems to produce the same results as the traditional GFMirror.
Hello,
I see two frames, with a problem in the top right corner of the second picture.
Can you explain a little bit more, please : where is the source? Which image is the result of which filter?
leon1789 is offline   Reply With Quote
Old 4th October 2009, 07:53   #122  |  Link
LaTo
LaTo INV.
LaTo's Avatar
Originally Posted by leon1789 View Post
Hello,
for the same job, I propose this simpler code
Function GradFun2dbMod(clip c, float "strength")
strength = default( strength, 1.2 )
w = c.width+32
h = c.height+32
c = c.PointResize(w,h,-16,-16,w,h)
c = c.GradFun2db(strength)
return c.Crop(16,16,-16,-16)
What do you think about it ? (specially in the corners of the picture)
Please, change the name of your function because this name is already used here:
http://forum.doom9.org/showthread.php?t=144537
Thanks
edit: On top of that, this pointresize method is already in my GF2mod...
If you want the same output as your mod:
GradFun2DBmod(str=0,mask=false)
str=0, disable adaptative grain
mask=false, disable selective debanding
LaTo is offline   Reply With Quote
Old 4th October 2009, 12:18   #123  |  Link
leon1789
leon1789's Avatar
Lato, you're absolutely right (for name and output).
So, my proposition is obsolete...
Old 6th September 2012, 17:06   #124  |  Link
benwaggoner
I tried to download today, and the link in the first post was bad. In fact, the whole http://kosmos.kawaii-shoujo.net/ subdomain appears to be down.
Anyone have an alternate location to download the .dll from?
Ben Waggoner
Principal Video Specialist, Amazon Instant Video
My Compression Book
Amazon Instant Video is hiring! PM me if you're interested.
Old 6th September 2012, 17:34   #125  |  Link
ChaosKing
Here you go: http://chaosking.de/wp-content/uploa...2006-05-05).7z
x64 version : http://chaosking.de/avisynth-filter?q=gradfun
Search and denoise
Old 6th September 2012, 18:05   #126  |  Link
sneaker_ger
You might also want to take a look at these:
flash3kyuu_deband
GradFun3
Old 6th September 2012, 21:19   #127  |  Link
benwaggoner
flash3kyuu_deband
GradFun3
I'm trying to deal with relatively subtle banding that shows up in dark live-action underwater shots (frames of just blacks and dark blues). I've had reasonable success with GradFun2DBmod.v1.5 (which needed this plugin to work.
Are there other filters that are recommended these days? I can certainly imagine something faster; It's taking 8x real time on my 12-core monster box (using very few cores).
Ben Waggoner
My Compression Book
Old 6th September 2012, 21:38   #128  |  Link
sneaker_ger
Flash3kyuu is pretty fast, should be faster than real-time. For specific tips for your source you should ask in the respective threads, as I cannot provide those.
Old 7th September 2012, 00:17   #129  |  Link
kolak
Flash3kyuu is very good. I use it for dithering 10 to 8bit (with use of tweaked for 10bit support ffms2: http://forum.doom9.org/showthread.ph...72#post1585372)- it should be way faster than RT on 12 core machine. Very powerful combination
Old 15th January 2013, 15:24   #130  |  Link
sirt
x264 fan
sirt's Avatar
I have a question : should I denoise after using gradfun or before ? Also, is it suitable to denoise a frame that had been debanged ?
sirt is offline   Reply With Quote
Old 15th January 2013, 16:49   #131  |  Link
poisondeathray
Originally Posted by sirt View Post
Usually debanding / dithering filters go last.
Debanding /dithering filters essentially add "noise"
If you apply denoise afterwards, it impairs the debanding effect
Old 15th January 2013, 16:57   #132  |  Link
Are_
Denoising introduces banding or is very prone to, I think that answers it all.
Are_ is offline   Reply With Quote
Old 15th January 2013, 17:28   #133  |  Link
sirt
x264 fan
sirt's Avatar
Thanks for those answers. Another thing, could you clarify the difference between debanding and dithering ?
Old 15th January 2013, 17:40   #134  |  Link
poisondeathray
In this context (gradfun2dbmod) they mean the same thing
In the more general sense, "debanding" can denote several different approaches to removing "banding" (and there are different type of "banding"), one method of "debanding" is dithering
http://en.wikipedia.org/wiki/Dither#Digital_photography_and_image_processing
There are different types of dithering, different algorithms. Basically they all add noise that "covers up" banding. Noise impairs compression - it requires more bitrate to encode. Ordered dithering techniques have less fluctuations, thus require less bitrate. And example in avisynth of ordered dithering is gradfun3
Old 15th January 2013, 19:13   #135  |  Link
Are_
Debanding is smoothing the gradients to make them uniform, like a blur filter does.
Dithering is downgrading de color palette (from 16 to 8 bit for example) while using patterns to make for the dinamic range loss without too much percieved quality loss, like gif does.
Then in the dithering process sometimes noise is added to give a more natural look.
Old 15th January 2013, 19:25   #136  |  Link
sirt
x264 fan
sirt's Avatar
Thanks for those detailed answers. Then, I've given a try to GradFun2DB and its variants but they are intended to debang as from I've read from the AVS External Filters page. But, in thise case, what would be a filter to dither assuming it is slightly something different according to your previous explanations ?
Old 15th January 2013, 19:39   #137  |  Link
sneaker_ger
Around here we usually we only speak of dithering in the sense of a method of reducing the bit-depth - which is more in line with what Are_ said than with poisondeathray's post.
Filters like gradfun2db, gradfun3 and flask3kyuudeband do debanding in high bit-depth (i.e. try to create smooth gradients in an already banded source with e.g. 16 bit output) and as a last step do dithering to a lower bit-depth (e.g. 8 or 10 bit). Dithering is to be seen as opposed to simple rounding, which would re-introduce a lot of banding. Poisondeathray's wiki link explains it. Image 1 of the cat is the original high bit-depth image and image 2 would be how the lower bit-depth image would look if we simply rounded down. Image 3 is how the bit-depth reduction looks with dithering.
As poisondeathray said, we have an additional obstacle to overcome, as random noise is extremely hard to compress. If you use Floyd-Steinberg dithering the AviSynth preview might look very good, but after encoding to low bitrate 8 bit h.264 the banding will have re-appeared or originally not existing banding will have been introduced. Methods to limit this effect are:
- switch to 10 bit H.264
- use ordered dithering (gradfun3 or the appropriate parameter if f3kdb)
- increase bitrate (a lot)
