Old 11th April 2006, 15:05   #41  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
You don't need this filter for DVDs. Or at least, I've never seen a DVD without some film grain, and almost always lots of it, and it slows playback WAY down.
As for why it crashes, it's really hard to say since there's no error message.
There are four boxes to be used in defense of liberty: soap, ballot, jury, and ammo. Please use in that order. ~ Ed Howdershelt
Old 11th April 2006, 23:34   #42  |  Link
Alain2
Corrected version:
Function gradfunkmirror( clip c, int "strength" )
	strength	=	default( strength, 1.2 )
	w			=	c.width()
	h			=	c.height()
	vflip		=	c.FlipVertical()
	hflip		=	c.FlipHorizontal()
	stackhorizontal( hflip.crop( w-16, 0, 16, h ).addborders( 0, 16, 0, 16 ),
	\	stackvertical( vflip.crop( 0, h-16, w, 16 ), c, vflip.crop( 0, 0, w, 16 ) ),
	\	hflip.crop( 0, 0, 16, h ).addborders( 0, 16, 0, 16 ) )
	gradfun2db( strength )
	crop( 16, 16, -16, -16 )
	Return last
It does work realtime on my computer (xp3700+), but takes a bit more cpu (mpc+gradfun2db = ~13%, mpc+gradfunkmirror=~25%)
Alain2 is offline   Reply With Quote
Old 11th April 2006, 23:52   #43  |  Link
DeathWolf
DeathWolf's Avatar
isnt that the same though?
it does look proper on my original script iirc
from h-16 to 0 or starting from h-16 with a 16 offset is the same
at least it was in the quick test i just did
DeathWolf is offline   Reply With Quote
Old 12th April 2006, 01:55   #44  |  Link
Alain2
I think you should have put -0 if you wanted to get the same than (h-16)->+16, but i may be wrong
Old 12th April 2006, 03:04   #45  |  Link
Jeremy Duncan
Didée Fan
Jeremy Duncan's Avatar
##Standard gradfunk
function gradfunk(clip c, int strength) {
strength=default(strength,1.2)
return c.addborders(16,16,16,16).gradfun2db(strength).crop(16,16,-16,-16)
##Corners will be ignored
function gradfunkmirror(clip c, int strength) {
return stackhorizontal(hflip.crop(c.width-16,0,16,c.height).addborders(0,16,0,16),stackvertical(vflip.crop(0,c.height-16,c.width,16),c,vflip.crop(0,0,c.width,16)),hflip.crop(0,0,16,c.height).addborders(0,16,0,16)).gradfun2db(strength).crop(16,16,-16,-16)
Above the picture is what I'm using.
The picture shows the problem I'm having.
It also shows my ffdshow avisynth setting, and the file.
What am I doing wrong ?
Jeremy Duncan is offline   Reply With Quote
Old 12th April 2006, 03:11   #46  |  Link
Jeremy Duncan
Didée Fan
Are you talking about here ?
Old 12th April 2006, 16:08   #47  |  Link
Xicor
Zoboomafoo
Xicor's Avatar
Your script might be called "script.avs.txt" instead of the correct "script.avs".
Get Yer Ya Ya's Out!
Xicor is offline   Reply With Quote
Old 12th April 2006, 22:57   #48  |  Link
Alain2
The function you posted is incorporating the correction I made, but original DeathWolf's function contains:
vflip.crop(0,c.height-16,c.width,0)
It is this zero I was talking about.
Oh btw in the function you have you started with
but then in ffdshow you don't specify a strength... You should write the header as i did (Function gradfunkmirror( clip c, int "strength" )) if you want to be able to omit the strength parameter when calling the function
Old 13th April 2006, 03:27   #49  |  Link
Jeremy Duncan
Didée Fan
Same script I posted before with the other picture.
Old 13th April 2006, 03:30   #50  |  Link
Jeremy Duncan
Didée Fan
Here's my setup so you can try it.
http://www.avsforum.com/avs-vb/showt...13#post7476913
Old 13th April 2006, 04:54   #51  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
you want "strength" not strength. If it's unquoted it becomes a required argument.
Old 13th April 2006, 05:41   #52  |  Link
Jeremy Duncan
Didée Fan
"strength" creates a error.
Old 5th May 2006, 11:36   #53  |  Link
Soulhunter
Bored...
Soulhunter's Avatar
GrandFun in FFDShow
Bye
Visit my IRC channel
Soulhunter is offline   Reply With Quote
Old 4th July 2006, 02:34   #54  |  Link
hartford
hartford's Avatar
I tried this filter using defaults, ie, "gradfun2db()"
The result was a very screwed-up frame:
http://img56.imageshack.us/my.php?image=gradfun7hz.png
hartford is offline   Reply With Quote
Old 4th July 2006, 02:39   #55  |  Link
hartford
hartford's Avatar
Nevermind, _I_ screwed-up; input must be YV12.
Old 6th July 2006, 15:36   #56  |  Link
adrianmak
it is for playback ? instead of using in video encoding e.g. dvd -> xvid/divx
adrianmak is offline   Reply With Quote
Old 6th July 2006, 15:59   #57  |  Link
Daodan
unrecognized user
I think the original purpose was for encoding (?). But since basically the crappy 12 bit color after encoding the bending will appear there again (a bit less though I would say). But it acts also as a spatial denoiser a bit so it can have some uses in the encoding process, but his great strength is at playback.
zzz
Daodan is offline   Reply With Quote
Old 9th July 2006, 13:26   #58  |  Link
Leak
ffdshow/AviSynth wrangler
Leak's Avatar
What 12 bit color are you talking about? YV12 uses a whopping 8 bit per channel...
np: New Order - Hey Now What You Doing (Waiting For The Sirens' Call)
now playing: [artist] - [track] ([album])
Leak is offline   Reply With Quote
Old 9th July 2006, 17:20   #59  |  Link
Soulhunter
Bored...
Soulhunter's Avatar
Dont you mean normal [non subsampled] YUV? >.>
Bye
Old 9th July 2006, 17:54   #60  |  Link
scharfis_brain
brainless
scharfis_brain's Avatar
every YUV colourspace supported by AVS has 8 bits/channel.
but due to subsampling the average amount of data is 12 bits/pixel. But this doesn't say anything about bits/channel!
Don't forget the 'c'!
Don't PM me for technical support, please.
scharfis_brain is offline   Reply With Quote
