Old 16th March 2006, 01:43   #21  |  Link
Soulhunter
Bored...
Soulhunter's Avatar
@ dbzgundam
Thanks! But Im not the author, I just posts for him...
@ Didée
Already wrote a requested to milan...
Bye
Visit my IRC channel
Soulhunter is offline   Reply With Quote
Old 16th March 2006, 07:27   #22  |  Link
DeathWolf
DeathWolf's Avatar
for those that need an alternate url for the 1.0(since sendspace is inneficient):
gradfun2db-v1.0.zip
DeathWolf is offline   Reply With Quote
Old 18th March 2006, 16:41   #23  |  Link
Scarfac3
Thanks DeathWolf ^^
Scarfac3 is offline   Reply With Quote
Old 19th March 2006, 02:50   #24  |  Link
Inc
Squeeze it!
Inc's Avatar
I also know this banding fiasko from Photoshop.
Exactly on those smooth gradients where Image contrast/saturation manipulations where done on 8bit/channel RGB images instead on 16bit/channel.
So if you want to also use it as preprocessor, after the postprocessing do apply a "minimal" touch of noise spray on such areas. Thats why in Photoshop in the gradient tool the option "dither" exists.
Inc is offline   Reply With Quote
Old 28th March 2006, 01:53   #25  |  Link
mla0
is there a documentation for this? or at least something that would tell the required things for this filter to work?
mla0 is offline   Reply With Quote
Old 28th March 2006, 02:34   #26  |  Link
DeathWolf
DeathWolf's Avatar
It's made to be used in the avisynth section of ffdshow.
Go in there and just write grad2funb() after placing the filter in the avisynth plugins directory and it should auto-apply.
Technically you could use it normally in avisynth too but the effects get cancelled by any typical compressions. It's made to be used when viewing(and is optimized for speed in that optic)
Old 28th March 2006, 10:52   #27  |  Link
Alain2
Is this for sure? (Meaning is the effect completely canceled when encoding in yv12 in x264 for instance?)
Foxyshadis said in his thread we could replace the last addgrain of his deband script with this GradFun2db...
Alain2 is offline   Reply With Quote
Old 28th March 2006, 11:12   #28  |  Link
Soulhunter
Bored...
Soulhunter's Avatar
Yes, quantization (destroys the fine +/-1 differences) + in-loop filtering (smoothing) = banding!
Bye
Old 28th March 2006, 11:46   #29  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
It's only for high bitrate matrices, where such fine details would be kept, not for normal compression where it gets eaten for lunch. It makes some noticeable difference at mid-high bitrates but it's not really good until exorborantly high. Or at playback, of course. (At the time I thought it was more of a dither+grain filter, but it's dither-only.) Since I'm not working on that show now, I haven't had the incentive to improve the last step of the filter (which I think is quite suboptimal).
Really, YV16/YV24 is the only way to truly remove visible banding in encodes. (If lavc could decode to YV24 and convert straight to RGB that would be awesome.)
There are four boxes to be used in defense of liberty: soap, ballot, jury, and ammo. Please use in that order. ~ Ed Howdershelt
Old 29th March 2006, 01:41   #30  |  Link
CruNcher
CruNcher's Avatar
Something is strange it looks like the filter misses regions of the right and left side btw overused you get a really nice (Dream Effect)
It is about Time
Old 29th March 2006, 08:10   #31  |  Link
Didée
True. Try gradfun2db(str=255) to "see" how&where it processes, and where not.
Old 29th March 2006, 08:46   #32  |  Link
Soulhunter
Bored...
Soulhunter's Avatar
Yeah, it leaves a 16pix border on each side... :\
Bye
Old 29th March 2006, 09:28   #33  |  Link
Mug Funky
interlace this!
Mug Funky's Avatar
quick and hacky workaround (hope you like black edges)
function gradfunk (clip c, float "strength")
	strength=default(strength,1.2)
	c.addborders(16,16,16,16)
	gradfun2db(strength)
	crop(16,16,-16,-16)
btw, this is a very fast filter. perhaps it could form the basis of a rewrite of spatialsoften, which is very very slow in comparison.
[edit]
strength is a float, not an int. d'oh
Old 29th March 2006, 23:11   #34  |  Link
mimage
mimage's Avatar
Thanks a bunch for this filter! It is so awesome and is very helpful for me.
I hope it's ok to ask here.. is there any filter like this for Vdub?
mimage is offline   Reply With Quote
Old 30th March 2006, 04:37   #35  |  Link
Jeremy Duncan
Didée Fan
Jeremy Duncan's Avatar
I tried it a few days ago, and my Celeron M 1.4 Ghz Notebook could not play it without stutter. And I saw a bit of banding still. If only it could be optimized to play on my Notebook.
Jeremy Duncan is offline   Reply With Quote
Old 30th March 2006, 04:39   #36  |  Link
Jeremy Duncan
Didée Fan
crop(16,16,-16,-16)
}[/code]
Is this added to the .dll, or in the avisynth section of ffdshow ?
Old 30th March 2006, 05:21   #37  |  Link
Mug Funky
interlace this!
Mug Funky's Avatar
it goes in your avs script, then you call "gradfunk" instead of "gradfun2b".
actually, it just occured to me that that workaround will not do anything unless you have a very dark frame.
reason - the black on the edges gets blurred exactly 16 pixels, making the first 16 pixels very likely to be over the threshold, and not used. you can confirm this by using it on some grainy footage with a high threshold.
i think edge mirror-ing will make it a lot better, but that might just slow it down such that it's not as useful.
Old 11th April 2006, 11:43   #38  |  Link
Jeremy Duncan
Didée Fan
Can somebody Please post the notepad script with the changes Mug Funky made.
I want to copy and paste it into a notepad file called gradfunk.avs
Old 11th April 2006, 13:23   #39  |  Link
DeathWolf
DeathWolf's Avatar
http://kosmos.kawaii-shoujo.net/gradfunk.avsi
there you go
the function to use with mirroring is: gradfunkmirror
Old 11th April 2006, 14:25   #40  |  Link
Jeremy Duncan
Didée Fan
there you go
This is what I'm doing. I'm putting this in FFDShow:
Import("G:\Program Files\AviSynth 2.5\plugins\gradfunkmirror.avs")
And opening Media Player Classic to play X-men 2.
As soon as I open Media player Classic and open the dvd, it closes.
And I doing it right ?
