10th June 2018, 01:04 | #4101 | Link |
Here is a similar test on a 0-255, Y,U,V pattern (0-255 Y just copied to the U,V planes), and again 8x back and forth, and then to TV range
You end up with Y 16-235 , U,V 16-240 hard limits (so chroma=100 for smooth levels is probably correct value for typical usage scenarios), but the average is skewed with coloryuv , resulting in the colorization of greyscale values. Also see the line artifacts again with coloryuv (smoothlevels had dither disabled) |
10th June 2018, 06:59 | #4102 | Link |
I have noticed and commented a line in color.cpp, this is the final step in lut creation, so far calculation was done in double precision:
// Convert back to int int iValue = int(value); // hmm P.F. 20180226 no rounding? |
11th June 2018, 10:55 | #4106 | Link |
Avisynth+ r2710 test build: installer w/o C++ redistributables.
https://drive.google.com/open?id=1tM...W4v99uCUtwwemj New things since last test: Code:
- Fix: ColorYUV: round to avoid green cast on consecutive TV<>PC - Enhanced: Limiter to work with 32 bit float clips. 'show' option still not supported - Enhanced: Limiter new parameter bool 'autoscale' default false. If set, minimum/maximum luma/chroma values are treated as they were in 8 bit range (but non-integer values are allowed), limiter will autoscale it. Default: does not scale at all, parameters are used as-is. Parameters now are of float type to handle 32 bit float values. - New: function bool VarExists(String variable_name) Checks if a variable exists Returns true if variable exists, false otherwise |
11th June 2018, 15:08 | #4111 | Link |
BlankClip #Fred=Undefined # Uncomment to show True Ex=RT_VarExist("FRED") # Edit or r2710 VarExists Subtitle("VarExist for fred="+String(ex)) Will show true in Script function where Fred is an un-supplied optional arg, ie UnDefined. (exists but not defined as anything in particular)
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 11th June 2018 at 15:36. |
11th June 2018, 15:17 | #4112 | Link |
Went all the way back to v2.57 and could not get Limiter to fail as posted, sorry, I have not explanation, other than senility.
11th June 2018, 15:30 | #4113 | Link | |
@P,
Note, the builtin file existing function is named Exist(), ie no ending 's', so I used RT_VarExist() and RT_FunctionExist() both without ending 's', (I initially did RT_VarExists with ending s and changed to be compatible style with builtin Exist). EDIT: I see that you have already implemented FunctionExists() with trailing 's', maybe too late to change Code:
Function Fred() {return True} BlankClip Ex=FunctionExists("FRED") Subtitle("FunctionExists for fred="+String(ex)) Quote:
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 11th June 2018 at 15:41. |
11th June 2018, 16:45 | #4115 | Link |
Ok, VarExist name is fixed and 'show' is supported in 32bit float, here is r2713
Avisynth+ r2713 test build: installer w/o C++ redistributables. EDIT: link refreshed (I have messed up the 32/64 bit files) https://drive.google.com/open?id=1GC...wz-7LIerlDQYLn New things for today: Code:
- Fix: ColorYUV: round to avoid green cast on consecutive TV<>PC - Enhanced: Limiter to work with 32 bit float clips. - Enhanced: Limiter new parameter bool 'autoscale' default false. If set, minimum/maximum luma/chroma values are treated as they were in 8 bit range (but non-integer values are allowed), limiter will autoscale it. Default: does not scale at all, parameters are used as-is. Parameters now are of float type to handle 32 bit float values. - New: function bool VarExist(String variable_name) Checks if a variable exists Returns true if variable exists even if it holds 'Undefined', false otherwise Last edited by pinterf; 12th June 2018 at 09:19. |
11th June 2018, 17:12 | #4116 | Link |
P, so you decied to keep FunctionExists with the extra 's', no sweat either way
Sorry, but latest ver$, have included 64 bit dll's in 32 bit install. EDIT: And just to mitigate doubts about senility, EDIT: Above after total uninstall, reinstall. [WinXP32] EDIT: Not just that dll, looks like maybe all of them. EDIT: Double check on senility [better to be sure] Code:
C:\Documents and Settings\root>avsmeter -avsinfo AVSMeter 2.7.7 (x86) - Copyright (c) 2012-2018, Groucho2004 Cannot load a 64 bit DLL in 32 bit Avisynth: 'C:/Program Files/AviSynth+/plugins+/ConvertStacked.dll'.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 11th June 2018 at 17:34. |
12th June 2018, 09:47 | #4119 | Link |
Installed, everything hunky dory here thanx
12th June 2018, 15:43 | #4120 | Link |
r2713's ColorYUV(levels="TV->PC") still looks different from MPC-HC's conversion (MPC-HC's caucasian skin-tone colors become redder post-conversion than AviSynth+'s), but at least it no longer seems to have the green cast any more, and repeated conversions back and forth (in AviSynth+) work fine now. So, the difference may be that MPC-HC is doing it incorrectly, I'm not really sure and don't have the time to dig through their code right now. As far as I'm concerned, the issue is resolved for AviSynth+, unless someone can demonstrate otherwise.
Thanks! Edit: I'm starting to suspect the difference now really is related to a conversion error in MPC-HC, as other colors, like orange/yellow, appear to be oversaturated after conversion. Last edited by `Orum; 12th June 2018 at 15:49. |
