Old 11th December 2016, 14:59   #5241  |  Link
Zathor
This should fix the issues:
2689 [VobSubber]            improved error handling if forced subtitles are not found (regression of 2686)
                            added a warning if VOB file sizes above the specification limit are used
2688 [x264]                 fixed incorrect command line when using a x86 OS (regression of 2681)
Zathor is offline   Reply With Quote
Old 11th December 2016, 17:11   #5242  |  Link
LeMoi
Thanks for the update. Where can I get it? Using the development server in MEGui settings, latest one is 2687, not 2689!
LeMoi is offline   Reply With Quote
Old 11th December 2016, 18:33   #5243  |  Link
Zathor
You have to wait up to 6 hours (depending on your last online update check) or you can get it here:
http://megui.org/auto/megui-core-2689-32.zip
Old 11th December 2016, 19:41   #5244  |  Link
LeMoi
Thanks for the link!
Unfortunately I still have an error with a new encode:
[Error] [11/12/2016 19:37:44] Standard error stream
-[Information] [11/12/2016 19:37:47] raw [info]: 720x304p 1:1 @ 24000/1001 fps (cfr)
-[Warning] [11/12/2016 19:37:47] x264 [warning]: VBV maxrate specified, but no bufsize, ignored
-[Information] [11/12/2016 19:37:47] x264 [info]: using SAR=1/1
-[Information] [11/12/2016 19:37:47] x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX
-[Information] [11/12/2016 19:37:47] x264 [info]: profile Main, level 3.0
-[Information] [11/12/2016 19:37:47] x264 [info]: final ratefactor: 24.01
-[Warning] [11/12/2016 19:37:47] avs [warning]: Converting input clip to YV12
-[Error] [11/12/2016 19:37:47] avs [error]: occurred while reading frame 0
And with the old one:
-[Error] [11/12/2016 19:38:34] Process exits with error: 0xC0000005 STATUS_ACCESS_VIOLATION (-1073741819)
Old 11th December 2016, 20:00   #5245  |  Link
Zathor
Please upload the full log
Old 11th December 2016, 20:15   #5246  |  Link
LeMoi
Here it is:
[Error] Log
-[Information] Versions
--[Information] [11/12/2016 20:12:17] MeGUI: 2689
--[Information] [11/12/2016 20:12:17] Operating System: Windows 10 Home x64 (10.0.0.14393)
--[Information] [11/12/2016 20:12:17] .NET Framework: 4.0 (4.0.0.0)
--[Information] [11/12/2016 20:12:17] .NET Framework: 4.6.x (4.6.01586)
--[Information] [11/12/2016 20:12:19] AviSynth: 2.5.8.5 (21-12-2008)
--[Information] [11/12/2016 20:12:19] AviSynth portable: 2.6.0.6 (21-09-2015) (active)
--[Information] [11/12/2016 20:12:19] AvisynthWrapper: (02-01-2009)
--[Information] [11/12/2016 20:12:19] Haali Media Splitter: 1.13.138.14 (14-04-2013)
--[Information] [11/12/2016 20:12:19] Haali DSS2: (14-04-2013)
--[Information] [11/12/2016 20:12:19] ICSharpCode.SharpZipLib: 0.85.5.452 (07-08-2008)
--[Information] [11/12/2016 20:12:20] MediaInfo: 0.7.91.0 (01-12-2016)
--[Information] [11/12/2016 20:12:20] MediaInfoWrapper: 0.7.61.0 (06-01-2013)
--[Information] [11/12/2016 20:12:20] MessageBoxExLib: 1.0.2218.28317 (19-12-2008)
--[Information] [11/12/2016 20:12:20] SevenZipSharp: 0.64.3890.29348 (02-01-2011)
--[Information] [11/12/2016 20:12:20] 7z: 9.20 (18-11-2010)
-[Information] Update detection
--[Information] [11/12/2016 20:12:17] Using cached update config and server: http://megui.org/auto/
--[Information] [11/12/2016 20:12:17] No package requires an update
-[Error] Log for job156 (video, MOVIE.avs -> )
--[Information] [11/12/2016 20:12:33] Started handling job
--[Information] [11/12/2016 20:12:33] Preprocessing
--[Information] [11/12/2016 20:12:33] Avisynth input script
---[NoImage] DirectShowSource("K:\BDMV\STREAM\00000.m2ts", fps=23.976, audio=false, convertfps=true).AssumeFPS(24000,1001)
---[NoImage] crop(0, 140, 0, -142)
---[NoImage] BicubicResize(720,304,0,0.5)
--[Information] [11/12/2016 20:12:38] resolution: 720x304
--[Information] [11/12/2016 20:12:38] frame rate: 24000/1001
--[Information] [11/12/2016 20:12:38] aspect ratio: 45:19 (2.368)
--[Information] [11/12/2016 20:12:38] Job command line: "C:\Program Files (x86)\MeGUI\tools\x264\avs4x26x.exe" --x26x-binary "C:\Program Files (x86)\MeGUI\tools\x264\x264.exe" --preset fast --pass 1 --bitrate 669 --stats "G:\MOVIE\0_MOVIE.stats" --keyint 240 --ref 5 --weightp 2 --qpmin 10 --qpmax 51 --vbv-maxrate 25000 --no-mbtree --rc-lookahead 40 --partitions all --sar 1:1 --output NUL "G:\MOVIE\MOVIE.avs"
--[Information] [11/12/2016 20:12:38] Process started
--[Information] [11/12/2016 20:12:38] Standard output stream
--[Warning] [11/12/2016 20:12:38] Standard error stream
---[Information] [11/12/2016 20:12:48] raw [info]: 720x304p 1:1 @ 24000/1001 fps (cfr)
---[Warning] [11/12/2016 20:12:48] x264 [warning]: VBV maxrate specified, but no bufsize, ignored
---[Information] [11/12/2016 20:12:48] x264 [info]: using SAR=1/1
---[Information] [11/12/2016 20:12:48] x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX
---[Information] [11/12/2016 20:12:48] x264 [info]: profile Main, level 3.0
---[Information] [11/12/2016 20:12:48] x264 [info]: frame I:1 Avg QP:27.00 size: 3131
---[Information] [11/12/2016 20:12:48] x264 [info]: frame P:2 Avg QP:24.00 size: 2055
---[Information] [11/12/2016 20:12:48] x264 [info]: frame B:5 Avg QP:27.00 size: 16
---[Information] [11/12/2016 20:12:48] x264 [info]: consecutive B-frames: 12.5% 0.0% 37.5% 50.0%
---[Information] [11/12/2016 20:12:48] x264 [info]: mb I I16..4: 94.7% 0.0% 5.3%
---[Information] [11/12/2016 20:12:48] x264 [info]: mb P I16..4: 27.1% 0.0% 0.0% P16..4: 11.2% 0.0% 0.0% 0.0% 0.0% skip:61.7%
---[Information] [11/12/2016 20:12:48] x264 [info]: mb B I16..4: 0.0% 0.0% 0.0% B16..8: 0.0% 0.0% 0.0% direct: 0.0% skip:100.0%
---[Information] [11/12/2016 20:12:48] x264 [info]: final ratefactor: 16.24
---[Information] [11/12/2016 20:12:48] x264 [info]: coded y,uvDC,uvAC intra: 39.2% 8.7% 7.3% inter: 2.3% 1.6% 1.2%
---[Information] [11/12/2016 20:12:48] x264 [info]: i16 v,h,dc,p: 100% 0% 0% 0%
---[Information] [11/12/2016 20:12:48] x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 75% 0% 25% 0% 0% 0% 0% 0% 0%
---[Information] [11/12/2016 20:12:48] x264 [info]: i8c dc,h,v,p: 3% 0% 97% 0%
---[Information] [11/12/2016 20:12:48] x264 [info]: Weighted P-Frames: Y:0.0% UV:0.0%
---[Information] [11/12/2016 20:12:48] x264 [info]: kb/s:175.58
---[Information] [11/12/2016 20:12:48] encoded 8 frames, 0.96 fps, 175.58 kb/s
--[Error] [11/12/2016 20:12:48] Process exits with error: 0xC0000005 STATUS_ACCESS_VIOLATION (-1073741819)
--[Information] [11/12/2016 20:12:48] Job completed
Old 11th December 2016, 20:28   #5247  |  Link
Zathor
And the exact same script with the BDMV file did work yesterday? I can encode without issues, but I do not use DirectShowSource. Could you please try another input filter like FFMS or another file?
Old 11th December 2016, 23:46   #5248  |  Link
LeMoi
I came back to latest stable release from sf.net, and the 1st pass went fine, but I got an error on 2nd pass.
I've tried 2 files but both of them were m2ts file, i'll try another source or filter to see...
EDIT: I just ran MEGui, it asked me to update to 2689 (while I already did manually 2 hours ago), I did the update and the encode finally started! I hope this time 2nd pass won't fail...
Old 11th December 2016, 23:52   #5249  |  Link
mini-moose
thanks Zathor. I'm not 100% sure when the file size becomes an issue to extract full subs, it only happened to me with full length movies really.
I can try and play around with some files and see if there is a cutoff point.
It appears to be extracting forced subs vobsubs now, whether there are or aren't any (0byte .sub files). Won't that be an issue?
i.e users adding empty subs to their files. If it also extract forced subs for all additional languages there could be a lot of those.
mini-moose is offline   Reply With Quote
Old 12th December 2016, 01:06   #5250  |  Link
LigH
LigH's Avatar
MeGUI still updates a lot faster when you hold down a mouse button in the updater window while it downloads and extracts. Doesn't matter which button, left or right. And it is very obvious for extracting, but also true for downloading. Without pressing a mouse button, the updater idles a lot.
New German Gleitz board
Old 12th December 2016, 08:08   #5251  |  Link
Zathor
Thanks, that would be great
These files are already deleted. You do have the deletion of intermediate files enabled, don't you?
Old 12th December 2016, 08:57   #5252  |  Link
mini-moose
Good news. It appears I've been using v1.0.0.6 which has that bug. Was not aware there is a 1.0.0.7 beta (the one you're using) which does not. The warning can be lifted off then. Sorry for misleading.
I do not have that enabled in settings. I assumed it deletes stuff I may like to revisit or reuse, so I never had. For example, video only mkv/mp4 files, I may want to mux them again if I wanted to add or remove something from
the initial mux.
Trying it now, I see it does a nice cleanup. However when multi streams is enabled, all the various vobsubs outputs have the same size, which is identical to single file mode with all the streams included.
I tried a dvd with lots of lang streams. Single file for all is 25mb for .sub, split into langs, each .sub is 25mb too even though it only includes one lang. I'm guessing the pointers on .idx are just for the selected lang but the .sub
maintains the entire bitmap.
I tried a DVD with a closed captions stream in it, it seems the extraction routine goes: Demuxing closed captions -- demuxing vobsubs -- demuxing forced subs.
you end up with all the next files for the CC stream:
01_VTS_01_1.cc.raw
01_VTS_01_1.cc.srt
01_VTS_01_1.cc.utf16be.srt
01_VTS_01_1.cc.utf16le.srt
01_VTS_01_1.cc.utf8.srt
01_VTS_01_1_forced.cc.raw
01_VTS_01_1_forced.cc.srt
01_VTS_01_1_forced.cc.utf16be.srt
01_VTS_01_1_forced.cc.utf16le.srt
01_VTS_01_1_forced.cc.utf8.srt
That's with deletion of intermediate files enabled. I don't know if you wished to keep those or not. They can be useful, but not all of them are needed + CC never has forced subs, also extracting them adds quite a bit of time to the
process as VSRip runs the extraction process 3 times.
Old 12th December 2016, 10:03   #5253  |  Link
Glarioo
I did an x264 encode with the preset=slow setting. That setting now uses me=hex instead of me=umh. I think that also trellis is changed (2 - Always instead of 1 - Final MB). I just wondered why, i thought me=umh gives better quality than me=hex.
Glarioo is offline   Reply With Quote
Old 12th December 2016, 10:06   #5254  |  Link
mini-moose
Originally Posted by Glarioo View Post
I did an x264 encode With the preset=slow setting. That setting now uses me=hex instead of me=umh. I think that also trellis is changed (2 - Always instead of 1 - Final MB). I just wondered why, i thought me=umh gives better quality than me=hex.
new preset slow is me=hex, trellis=2, b-adapt=1. Guess they figured it gives the same/better results. Or were "downgraded" to me=hex and b-adapt=1, cause trellis=2 slows down the encode by quite a bit.
Old 12th December 2016, 11:06   #5255  |  Link
LeMoi
Me again, still an error, 2nd pass didn't launch, here's the log:
[Error] Log
--[Information] [11/12/2016 23:45:33] MeGUI: 2689
--[Information] [11/12/2016 23:45:33] Operating System: Windows 10 Home x64 (10.0.0.14393)
--[Information] [11/12/2016 23:45:33] .NET Framework: 4.0 (4.0.0.0)
--[Information] [11/12/2016 23:45:33] .NET Framework: 4.6.x (4.6.01586)
--[Information] [11/12/2016 23:45:33] AviSynth: 2.5.8.5 (21-12-2008)
--[Information] [11/12/2016 23:45:33] AviSynth portable: 2.6.0.6 (21-09-2015) (active)
--[Information] [11/12/2016 23:45:33] AvisynthWrapper: (02-01-2009)
--[Information] [11/12/2016 23:45:33] Haali Media Splitter: 1.13.138.14 (14-04-2013)
--[Information] [11/12/2016 23:45:33] Haali DSS2: (14-04-2013)
--[Information] [11/12/2016 23:45:33] ICSharpCode.SharpZipLib: 0.85.5.452 (07-08-2008)
--[Information] [11/12/2016 23:45:33] MediaInfo: 0.7.91.0 (01-12-2016)
--[Information] [11/12/2016 23:45:33] MediaInfoWrapper: 0.7.61.0 (06-01-2013)
--[Information] [11/12/2016 23:45:33] MessageBoxExLib: 1.0.2218.28317 (19-12-2008)
--[Information] [11/12/2016 23:45:33] SevenZipSharp: 0.64.3890.29348 (02-01-2011)
--[Information] [11/12/2016 23:45:33] 7z: 9.20 (18-11-2010)
--[Information] [11/12/2016 23:45:33] Using cached update config and server: http://megui.tmebi.de/test/
--[Information] [11/12/2016 23:45:33] No package requires an update
--[Information] [11/12/2016 23:45:48] No package requires an update
-[Warning] Log for job156 (video, MOVIE.avs -> )
--[Information] [11/12/2016 23:46:30] Started handling job
--[Information] [11/12/2016 23:46:30] Preprocessing
--[Information] [11/12/2016 23:46:30] Avisynth input script
--[Information] [11/12/2016 23:46:36] resolution: 720x304
--[Information] [11/12/2016 23:46:36] frame rate: 24000/1001
--[Information] [11/12/2016 23:46:36] aspect ratio: 45:19 (2.368)
--[Information] [11/12/2016 23:46:36] Job command line: "C:\Program Files (x86)\MeGUI\tools\x264\avs4x26x.exe" --x26x-binary "C:\Program Files (x86)\MeGUI\tools\x264\x264.exe" --preset fast --pass 1 --bitrate 669 --stats "G:\MOVIE\0_MOVIE.stats" --keyint 240 --ref 5 --weightp 2 --qpmin 10 --qpmax 51 --vbv-maxrate 25000 --no-mbtree --rc-lookahead 40 --partitions all --sar 1:1 --output NUL "G:\MOVIE\MOVIE.avs"
--[Information] [11/12/2016 23:46:36] Process started
--[Information] [11/12/2016 23:46:36] Standard output stream
---[Information] [12/12/2016 00:49:03] avs [info]: AviSynth 2.58, buildec 22 2008 [08:46:51]
---[Information] [12/12/2016 00:49:03] avs [info]: Video resolution: 720x304
---[Information] [12/12/2016 00:49:03] avs [info]: Video framerate: 24000/1001
---[Information] [12/12/2016 00:49:03] avs [info]: Video framecount: 149894
---[Information] [12/12/2016 00:49:03] avs4x26x [info]: "C:\Program Files (x86)\MeGUI\tools\x264\x264.exe" - --preset fast --pass 1 --bitrate 669 --stats G:\MOVIE\0_MOVIE.stats --keyint 240 --ref 5 --weightp 2 --qpmin 10 --qpmax 51 --vbv-maxrate 25000 --no-mbtree --rc-lookahead 40 --partitions all --sar 1:1 --output NUL --frames 149894 --fps 24000/1001 --input-res 720x304 --input-csp i420
--[Warning] [11/12/2016 23:46:36] Standard error stream
---[Information] [11/12/2016 23:46:43] raw [info]: 720x304p 1:1 @ 24000/1001 fps (cfr)
---[Warning] [11/12/2016 23:46:43] x264 [warning]: VBV maxrate specified, but no bufsize, ignored
---[Information] [11/12/2016 23:46:43] x264 [info]: using SAR=1/1
---[Information] [11/12/2016 23:46:43] x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX
---[Information] [11/12/2016 23:46:43] x264 [info]: profile Main, level 3.0
---[Information] [12/12/2016 00:48:59] x264 [info]: frame I:1245 Avg QP:16.56 size: 21153
---[Information] [12/12/2016 00:48:59] x264 [info]: frame P:39086 Avg QP:17.93 size: 7047
---[Information] [12/12/2016 00:48:59] x264 [info]: frame B:109563 Avg QP:19.48 size: 2115
---[Information] [12/12/2016 00:48:59] x264 [info]: consecutive B-frames: 1.9% 1.1% 2.1% 94.9%
---[Information] [12/12/2016 00:48:59] x264 [info]: mb I I16..4: 30.8% 0.0% 69.2%
---[Information] [12/12/2016 00:48:59] x264 [info]: mb P I16..4: 21.0% 0.0% 0.0% P16..4: 61.5% 0.0% 0.0% 0.0% 0.0% skip:17.4%
---[Information] [12/12/2016 00:48:59] x264 [info]: mb B I16..4: 5.1% 0.0% 0.0% B16..8: 26.9% 0.0% 0.0% direct:13.3% skip:54.8% L0:32.8% L1:41.9% BI:25.3%
---[Information] [12/12/2016 00:48:59] x264 [info]: final ratefactor: 19.57
---[Information] [12/12/2016 00:48:59] x264 [info]: coded y,uvDC,uvAC intra: 73.6% 22.7% 4.5% inter: 17.2% 6.3% 0.0%
---[Information] [12/12/2016 00:48:59] x264 [info]: i16 v,h,dc,p: 29% 19% 38% 14%
---[Information] [12/12/2016 00:48:59] x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 25% 19% 16% 7% 6% 7% 6% 6% 6%
---[Information] [12/12/2016 00:48:59] x264 [info]: i8c dc,h,v,p: 71% 12% 15% 2%
---[Information] [12/12/2016 00:48:59] x264 [info]: Weighted P-Frames: Y:5.8% UV:0.7%
---[Information] [12/12/2016 00:48:59] x264 [info]: kb/s:682.63
---[Information] [12/12/2016 00:48:59] encoded 149894 frames, 40.12 fps, 682.63 kb/s
---[Warning] [12/12/2016 00:49:03] avs [warning]: Converting input clip to YV12
--[Information] [12/12/2016 00:49:05] Postprocessing
---[Information] [12/12/2016 00:49:06] Deleting intermediate files
--[Information] [12/12/2016 00:49:06] Job completed
-[Error] Log for job157 (video, MOVIE.avs -> 0_MOVIE.mkv)
--[Information] [12/12/2016 00:49:07] Started handling job
--[Information] [12/12/2016 00:49:07] Preprocessing
--[Information] [12/12/2016 00:49:07] Avisynth input script
--[Information] [12/12/2016 00:49:18] resolution: 720x304
--[Information] [12/12/2016 00:49:18] frame rate: 24000/1001
--[Information] [12/12/2016 00:49:18] aspect ratio: 45:19 (2.368)
--[Information] [12/12/2016 00:49:18] Job command line: "C:\Program Files (x86)\MeGUI\tools\x264\avs4x26x.exe" --x26x-binary "C:\Program Files (x86)\MeGUI\tools\x264\x264.exe" --preset fast --pass 3 --bitrate 669 --stats "G:\MOVIE\0_MOVIE.stats" --keyint 240 --ref 5 --weightp 2 --qpmin 10 --qpmax 51 --vbv-maxrate 25000 --no-mbtree --rc-lookahead 40 --partitions all --sar 1:1 --output "G:\MOVIE\0_MOVIE.mkv" "G:\MOVIE\MOVIE.avs"
--[Information] [12/12/2016 00:49:18] Process started
--[Information] [12/12/2016 00:49:18] Standard output stream
---[Information] [12/12/2016 00:49:33] avs [info]: AviSynth 2.58, buildec 22 2008 [08:46:51]
---[Information] [12/12/2016 00:49:33] avs [info]: Video resolution: 720x304
---[Information] [12/12/2016 00:49:33] avs [info]: Video framerate: 24000/1001
---[Information] [12/12/2016 00:49:33] avs [info]: Video framecount: 149894
---[Information] [12/12/2016 00:49:33] avs4x26x [info]: "C:\Program Files (x86)\MeGUI\tools\x264\x264.exe" - --preset fast --pass 3 --bitrate 669 --stats G:\MOVIE\0_MOVIE.stats --keyint 240 --ref 5 --weightp 2 --qpmin 10 --qpmax 51 --vbv-maxrate 25000 --no-mbtree --rc-lookahead 40 --partitions all --sar 1:1 --output G:\MOVIE\0_MOVIE.mkv --frames 149894 --fps 24000/1001 --input-res 720x304 --input-csp i420
--[Error] [12/12/2016 00:49:18] Standard error stream
---[Information] [12/12/2016 00:49:32] raw [info]: 720x304p 1:1 @ 24000/1001 fps (cfr)
---[Warning] [12/12/2016 00:49:32] x264 [warning]: VBV maxrate specified, but no bufsize, ignored
---[Information] [12/12/2016 00:49:32] x264 [info]: using SAR=1/1
---[Information] [12/12/2016 00:49:32] x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX
---[Information] [12/12/2016 00:49:32] x264 [info]: profile High, level 3.0
---[Warning] [12/12/2016 00:49:33] avs [warning]: Converting input clip to YV12
---[Error] [12/12/2016 00:49:33] avs [error]: }}}}}}}}}}}}}}}}}}}}}}}}}}}}}}}}}}}}}}}}}}}}}}}}~~}}}}}}}}}}}}}}}}}}}}}}}}}}}}}~~}}}~~~}}}~~~~~~~~~~~~~~~~~~~ occurred while reading frame 0
--[Information] [12/12/2016 00:49:33] Job completed
1st pass, job 156, went fine, but not 2nd pass, job 157.
The job xml if it can help :
<?xml version="1.0"?>
<TaggedJob xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<Job xsi:type="VideoJob">
<Input>G:\MOVIE\MOVIE.avs</Input>
<Output>G:\MOVIE\0_MOVIE.mkv</Output>
<FilesToDelete />
<Zones />
<DAR>
<AR>2.3684210526315789473684210526</AR>
<X>45</X>
<Y>19</Y>
</DAR>
<Settings xsi:type="x264Settings">
<VideoEncodingType>threepass2</VideoEncodingType>
<EncodingMode>migrated</EncodingMode>
<BitrateQuantizer>669</BitrateQuantizer>
<KeyframeInterval>250</KeyframeInterval>
<NbBframes>3</NbBframes>
<MinQuantizer>10</MinQuantizer>
<MaxQuantizer>51</MaxQuantizer>
<V4MV>false</V4MV>
<QPel>false</QPel>
<Trellis>false</Trellis>
<CreditsQuantizer>40</CreditsQuantizer>
<Logfile>G:\MOVIE\0_MOVIE.stats</Logfile>
<VideoName />
<CustomEncoderOptions />
<MaxNumberOfPasses>3</MaxNumberOfPasses>
<NbThreads>0</NbThreads>
<x264PresetLevel>fast</x264PresetLevel>
<x264PsyTuning>NONE</x264PsyTuning>
<QuantizerCRF>768</QuantizerCRF>
<InterlacedMode>progressive</InterlacedMode>
<TargetDeviceXML>0</TargetDeviceXML>
<BlurayCompatXML>False</BlurayCompatXML>
<NoDCTDecimate>false</NoDCTDecimate>
<PSNRCalculation>false</PSNRCalculation>
<NoFastPSkip>false</NoFastPSkip>
<NoiseReduction>0</NoiseReduction>
<NoMixedRefs>false</NoMixedRefs>
<X264Trellis>1</X264Trellis>
<NbRefFrames>5</NbRefFrames>
<AlphaDeblock>0</AlphaDeblock>
<BetaDeblock>0</BetaDeblock>
<SubPelRefinement>6</SubPelRefinement>
<MaxQuantDelta>4</MaxQuantDelta>
<TempQuantBlur>0</TempQuantBlur>
<BframePredictionMode>1</BframePredictionMode>
<VBVBufferSize>-1</VBVBufferSize>
<VBVMaxBitrate>25000</VBVMaxBitrate>
<METype>1</METype>
<MERange>16</MERange>
<MinGOPSize>25</MinGOPSize>
<IPFactor>1.4</IPFactor>
<PBFactor>1.3</PBFactor>
<ChromaQPOffset>0</ChromaQPOffset>
<VBVInitialBuffer>0.9</VBVInitialBuffer>
<BitrateVariance>1.0</BitrateVariance>
<QuantCompression>0.6</QuantCompression>
<TempComplexityBlur>20</TempComplexityBlur>
<TempQuanBlurCC>0.5</TempQuanBlurCC>
<SCDSensitivity>40</SCDSensitivity>
<BframeBias>0</BframeBias>
<PsyRDO>1.0</PsyRDO>
<PsyTrellis>0</PsyTrellis>
<Deblock>true</Deblock>
<Cabac>true</Cabac>
<UseQPFile>false</UseQPFile>
<WeightedBPrediction>true</WeightedBPrediction>
<WeightedPPrediction>2</WeightedPPrediction>
<NewAdaptiveBFrames>1</NewAdaptiveBFrames>
<x264BFramePyramid>2</x264BFramePyramid>
<x264GOPCalculation>1</x264GOPCalculation>
<ChromaME>true</ChromaME>
<MacroBlockOptions>2</MacroBlockOptions>
<P8x8mv>true</P8x8mv>
<B8x8mv>true</B8x8mv>
<I4x4mv>true</I4x4mv>
<I8x8mv>true</I8x8mv>
<P4x4mv>true</P4x4mv>
<AdaptiveDCT>true</AdaptiveDCT>
<SSIMCalculation>false</SSIMCalculation>
<StitchAble>false</StitchAble>
<QuantizerMatrix>Flat (none)</QuantizerMatrix>
<QuantizerMatrixType>0</QuantizerMatrixType>
<DeadZoneInter>21</DeadZoneInter>
<DeadZoneIntra>11</DeadZoneIntra>
<X26410Bits>false</X26410Bits>
<OpenGop>False</OpenGop>
<X264PullDown>0</X264PullDown>
<SampleAR>0</SampleAR>
<ColorMatrix>0</ColorMatrix>
<ColorPrim>0</ColorPrim>
<Transfer>0</Transfer>
<AQmode>1</AQmode>
<AQstrength>1.0</AQstrength>
<QPFile>.qp</QPFile>
<Range>auto</Range>
<x264AdvancedSettings>true</x264AdvancedSettings>
<Lookahead>40</Lookahead>
<NoMBTree>false</NoMBTree>
<ThreadInput>true</ThreadInput>
<NoPsy>false</NoPsy>
<Scenecut>true</Scenecut>
<Nalhrd>0</Nalhrd>
<X264Aud>false</X264Aud>
<X264SlowFirstpass>false</X264SlowFirstpass>
<PicStruct>false</PicStruct>
<FakeInterlaced>false</FakeInterlaced>
<NonDeterministic>false</NonDeterministic>
<SlicesNb>0</SlicesNb>
<MaxSliceSyzeBytes>0</MaxSliceSyzeBytes>
<MaxSliceSyzeMBs>0</MaxSliceSyzeMBs>
<Profile>2</Profile>
<AVCLevel>L_UNRESTRICTED</AVCLevel>
<TuneFastDecode>false</TuneFastDecode>
<TuneZeroLatency>false</TuneZeroLatency>
</Settings>
</Job>
<RequiredJobNames>
<string>job156</string>
</RequiredJobNames>
<EnabledJobNames>
<string>job161</string>
</EnabledJobNames>
<Name>job157</Name>
<Status>ERROR</Status>
<Start>2016-12-12T00:49:18.4576006+01:00</Start>
<End>2016-12-12T00:49:33.9217905+01:00</End>
</TaggedJob>
Does the problem come from new x264 encoder?
Old 12th December 2016, 11:18   #5256  |  Link
Glarioo
Found this on the Videohelp website.
http://forum.videohelp.com/threads/3...ly?mode=hybrid
There's a link to Videolan
http://git.videolan.org/?p=x264/x264...30eae3578c251d
Adjust --preset slow
* Swap --me umh for --trellis 2. They have a similar effect on performance
but the latter gives slightly better results in most cases.
* Change --b-adapt from 2 to 1. Negligible difference in quality since the
b-adapt 1 improvements, but it's significantly faster.
Also remove a redundant assignment from veryfast (--me hex is set by default).
Old 12th December 2016, 11:18   #5257  |  Link
mini-moose
I've never done 3 passes, but shouldn't there be pass 2 first?
Old 12th December 2016, 11:52   #5258  |  Link
LeMoi
Indeed, I don't know why the command line shows pass3. The xml job says "<VideoEncodingType>threepass2</VideoEncodingType>", and for the 3rd pass it says "<VideoEncodingType>threepass3</VideoEncodingType>", but I don't know how the command line should look like
Old 12th December 2016, 11:55   #5259  |  Link
mini-moose
Try to do 2-pass instead of 3 pass and see if it works.
Also:
why are you still using old AVS?
Old 12th December 2016, 13:00   #5260  |  Link
sneaker_ger
"--pass 3" does NOT mean 3rd pass.
"--pass 1" means "write a new stats file"
"--pass 2" means "read stats file, don't update stats file"
"--pass 3" means "read stats file, update stats file"
So if you were to do 5 passes you would do:
--pass 1
--pass 3
--pass 3
--pass 3
--pass 2
or:
--pass 1
--pass 3
--pass 3
--pass 3
--pass 3
"--pass 2" is not really needed except for debugging/review.
