Old 30th January 2016, 00:33   #2901  |  Link
manolito
manolito's Avatar
Hi MrC and SD,
did a few more tests, and it sure has nothing to do with permissions - I am using Win XP.
The user from VideoHelp is right IMO, the issue only appears if the destination for MuxMan is on a different drive than the drive where the program resides.
In my case my system drive is E:, and this is where my program files folder is located. The only way to avoid the error is to specify a folder on E: as my output folder in AVStoDVD. Using any other drive as the destination causes MuxMan to crash.
Cheers
manolito
Old 30th January 2016, 23:00   #2902  |  Link
Sir Didymus
Ok, let's give a try to this one (BatchMux v1.4.1, hotfix, beta):
http://www93.zippyshare.com/v/8ZFyL4Lq/file.html
Once you download it, it is intended as a direct replacement for the version 1.4 of BatchMux.exe, located in the AVS2DVD programs folder.
In case issues are still present with this version, please let me know...
Sir Didymus is offline   Reply With Quote
Old 31st January 2016, 12:14   #2903  |  Link
manolito
manolito's Avatar
Thanks SD, this hotfix works here. Beautiful...
Cheers
manolito
Old 31st January 2016, 17:00   #2904  |  Link
Sir Didymus
OK! Great... Thanks, manolito, for the very rapid testing & report. Let's wait for a while for possible feedbacks from other users, incurred in other troubles related to the same bug, before considering the problem solved. OK, another thing to consider for the future is that obviously the already released BM versions 1.5 and 1.6 are from now on deprecated. Clearly, there is no urgency to provide new versions of BM 1.5 and 1.6. It would be not even wise, since maybe it is better to wait for other possible bugs & issues in the current BM 1.4.1; the relevant features of BM 1.5 and 1.6 are already known (from the other thread dedicated to BM), so whenever MrC requires, their updates will be distributed...
... Beautiful ...
Mhhh, yes!
How to disagree?
Cheers,
SD
Old 1st February 2016, 09:01   #2905  |  Link
Deach
Can confirm the issue is fixed on my end too.
Deach is offline   Reply With Quote
Old 1st February 2016, 09:59   #2906  |  Link
Sir Didymus
Oh, thank you Deach, for your report, and welcome in the doom9 community.
Old 1st February 2016, 11:13   #2907  |  Link
Deach
Cheers. I was the user MrC was talking about earlier, had to wait 5 days though obviously to be able to post!
Relevant I suppose at the minute, is there much performance benefit to having temp files assets and whatever else across difference drives?
Old 1st February 2016, 13:20   #2908  |  Link
Sir Didymus
Ah, I see! Good to know...
Yes, at least partially. The authoring engine (MuxMan) and the video encoder (HcEnc, for instance) are the most time-consuming components in AVS2DVD, I think... The encoder especially...
Both are heavily using I/O operations to read large chunks of input assets and produce equally big output files. So, reading from one drive and writing to a different (physical) one is surely beneficial. I do not have recent figures on the matter, to tell you frankly; furthermore nowadays SSD are quite diffused, so this benefit of distributing the I/O jobs on different drives is not as huge as it was some years ago...
There is also to consider that both encoding and authoring, in AVS2DVD, are single thread modules, using in a very intense way just one of the available CPU cores, so the gain you can obtain will be in any case bounded by the CPU, at a given point...
Old 1st February 2016, 13:39   #2909  |  Link
manolito
manolito's Avatar
Hi SD,
this is not true for HCenc and FFMpeg...
AVStoDVD configures both encoders so they will use all available CPU cores (at least if you have configured it this way under Preferences->System).
But for my encodes the CPU load is still only at about 30% because the real bottleneck is AviSynth and the filters I use. These are all single threaded, and switching to AviSynth MT or AviSynth+ and using only MT plugins is something I do not dare right now.
Cheers
manolito
Old 1st February 2016, 16:32   #2910  |  Link
Sir Didymus
Ah, I was not aware about that... Do you know if this is achieved by the controlling environment (e.g. AVS2DVD is splitting the overall work into multiple individual encoding jobs) or these two encoders are real multithread applications (allowing to achieve one single encoding job to be completed individually by using multiple threads)?
Old 1st February 2016, 18:51   #2911  |  Link
manolito
manolito's Avatar
It is entirely the encoders...
From the A2D manual:
If you have a multi-processor / multi-core CPU and you use this option, video encoding speed will be improved a lot.
HCenc multithread encoding is activated by "*SMP" command in HCenc.ini file
FFmpeg multithread encoding is activated by "-threads n" command line flag, where n is the number of the cores used.
Cheers
manolito
Old 1st February 2016, 21:13   #2912  |  Link
Sir Didymus
Very relevant features indeed (for both encoders...). Regarding HCenc I already clarifyed to me any doubts, via the related FAQ, explaining its multiprocessing feature. That's great!
So, forgive me the wrong statement above...
Well, back to the question about the usefulness of splitting encoding and authoring activities by keeping on different physical volumes the related input and output assets, I am still positive that there are tangible benefits by selecting different volumes for the reading and for the writing operations.
However, me too curious about some recent evaluations about this aspect, with modern HW configurations, including the usage of SSD devices...
Cheers,
SD
Old 16th February 2016, 18:16   #2913  |  Link
manolito
manolito's Avatar
It's quiet here... The software seems to be working perfectly
Well, I don't want to spoil the party, but I did find a small issue with chapter creation. It only happens for muxed MPEG2 source files. I have set an interval for automatic chapter creation and also ticked the checkbox to prefer the source chapters if present.
In this case the fixed chapters routine should take over (MPG files cannot have chapters). But it doesn't, no chapters will be created. I believe that the reason is that MediaInfo reports one empty chapter for these files. This is the source info from AVStoDVD:
GENERAL INFO
PathName: I:\test.mpg
Format: MPEG-PS
Time: 2:54:25 hours
Audio Tracks: 1
Subs Tracks: 0
VIDEO TRACK INFO
Track ID: 224
Stream Order: 0
Time: 2:54:25 hours
Compression: MPEG-2 Video
BitRate Mode: VBR
Avg BitRate: 3256 kbps
Min BitRate:
Max BitRate:
Resolution: 720x576
Display AspectRatio: 1,778
Pixel AspectRatio: 1,422
Frame AspectRatio: 1,25
FrameRate Mode:
FrameRate: 25 fps
Frame Count: 261636
Scan Type: Interlaced
Interlaced: Yes
Field Order: TFF
Color Space: YUV
Colour Coefficients:
DVD Compliance: 1
AUDIO TRACK INFO (Track 1)
Track ID: 189-128
Stream Order: 1
Time: 2:54:25 hours
Compression: AC3
BitRate Mode: CBR
Avg BitRate: 224 kbps
Channels: 2
SampleRate: 48000 Hz
Resolution:
Language:
Delay: 0 ms
CHAPTERS INFO
Chapter 1: Count
This MediaInfo output is not correct IMO, but it has been there forever (I went back to version 0.7.58). So I think that A2D should just assume that there never is any source chapter info for MPEG2 files.
BTW if I first demux the MPG file and feed the elementary streams to A2D, the chapters will be created correctly.
Otherwise the latest alpha version with the fixed BatchMux version is in frequent use here, and for me it is absolutely stable.
Cheers
manolito
Old 26th February 2016, 00:28   #2914  |  Link
Deach
Originally Posted by manolito View Post
Hi SD,
Cheers
manolito
Would there be much of a benefit from other AviSynth forks? I've tampered with both + and the MT fork briefly but I couldn't say for sure if there was any noticeable improvement based on the odd few encodes I'd run with them installed? I suppose it depends on the project settings as well.
Recent BatchMux working fine here still too, no issues to report!
Old 27th February 2016, 09:53   #2915  |  Link
Sir Didymus
Ok. Regarding BM, thanks manolito and Deach for your confirmation. Your support is great! With low priority, in the next days/weeks I will update the thread dedicated to the BM development with some related information, just for future tracing purposes [...hem, especially to remind myself about the "status quo", since three versions of BatchMux are affected: 1.4.1, 1.5.1 and 1.6.1... :-( ...].
manolito, concerning the other small glitch (chaptering based on MPG container) I totally agree with your considerations and proposed solution. It's a relatively minor issue, indeed, since the backup of unticking the checkbox to prefer the source chapters allows to live with the problem...
About speeding up the AviSynth operations, IMO things are definitely not simple to deal with. The (radically different) applicative approach "A la DVD Rebuilder", of dividing the source assets in chuncks (titles, chapters or segments), with one CPU dedicated to the operations for each individual chunk, would be probably beneficial. But it is just a matter of speculations, since in the context of AVS2DVS is would be probably almost impossible to implement (again IMHO, these conjectures here are just "free wheel thinking") and the B/C ratio would be for sure extremely low...
Maybe exploring furthermore the usage of AviSynth MT or AviSynth+, strictly with MT plugins, would give higher benefits, with a relatively minor effort, if the throughput of the job is the priority...
Old 10th March 2016, 18:23   #2916  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Guys, I'm not dead... maybe just zombified by my job... within few days I should publish a new alpha with some minor improvements (BM 1.4.1, tnx SD, more subs tools) and bugfixes (mpeg2 auto chapters issue, tnx manolito, AVS join titles chapters flags with fps conversion, tnx davexnet from VH forum).
Bye
MrC
AVStoDVD Homepage
AVStoDVD @ Doom9 Forum
MrC is offline   Reply With Quote
Old 10th March 2016, 21:07   #2917  |  Link
manolito
manolito's Avatar
This is very reassuring - I was almost ready to email you inquiring about your health...
Take care
manolito
Old 13th March 2016, 11:53   #2918  |  Link
manolito
manolito's Avatar
Problem with default FFMpeg HQ parameters
By default AVStoDVD uses the following HQ parameters when the FFMpeg HQ mode is activated:
-bf 2 -mbd rd -trellis 2 -cmp 2 -subcmp 2
These parameters are officially recommended, see here:
https://ffmpeg.org/faq.html#Which-ar...PEG_002d2_003f
But at least for current versions of FFMpeg the "trellis" parameter causes heavy artifacts with a lot of sources. It looks like the background is "pulsing", the reason is that all I-frames are bitrate-starved, i.e. their quantizer is way too high.
Here is an example source file:
http://www67.zippyshare.com/v/PpKnauBU/file.html
Even with the highest bitrate these artifacts are clearly visible. Removing the "-trellis 2" from the HQ parameters fixes the problem.
Thanks to SilverSolver from the DVDStyler forum for discovering the issue and being a great help in finding the culprit.
I recommend to everyone to remove the "trellis" parameter from the HQ FFMpeg parameter list...
Cheers
manolito
Old 15th March 2016, 13:37   #2919  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Thanks manolito for the hint
Bye
MrC
AVStoDVD Homepage
Old 19th March 2016, 22:35   #2920  |  Link
manolito
manolito's Avatar
New versions of my plugins for AVStoDVD
I just uploaded new versions of my AVStoDVD plugins, here's the link:
http://www72.zippyshare.com/v/vQjJSXBw/file.html
Changes:
Wavi_Mod now uses the latest version 0.4.9 of BS1770Gain
ffmpeg_vbr features some usability improvements.
1. The bitrate thresholds for switching between different encoding modes and the thresholds for switching between Custom Quant Matrices can now be specified independently.
2. The 1-pass VBR and 2-pass VBR modes can now be forced regardless of the video bitrates.
3. In forced 2-pass VBR mode the desired HQ mode can now be specified (Normal Quality, Regular HQ, Extreme HQ).
4. In the Extreme HQ mode the MPEG Adapted matrix and a DC precision of 10 are forced.
The plugins were tested under WinXP and Win7 (32-bit and 64-bit) and AviSynth 2.60. I used the latest FFMpeg point release 3.0.
Cheers
manolito
Last edited by manolito; 26th March 2016 at 17:10. Reason: Various small quality improvements
[IMG] code is Off
