17th November 2006, 14:01 | #821 | Link | |
Huh?
Read Decomb's readmes and tutorials, the IVTC tutorial and the capture guide in order to learn about combing and how to deal with it. |
17th November 2006, 17:22 | #822 | Link | ||
@Chainmax
MPEG2Source("X:\wherever\familytape.d2v",info=3) Trim(0,1982)+Trim(2355,0) ColorMatrix(hints=true,interlaced=true) SecureBob() info() and could you post the d2v file? Also, how big is the source file? ... the easiest way to debug the problem would be to have the source, but if it's really big I'll try with just the d2v file first. @foxyshadis TDeint sets field to 0 if it detects hints because telecide matches off the bottom field. TFM can match off either, but it includes the field that it matched from in the hints that it passes... so TDeint uses the field value in the hints in that case. @Mug Funky Quote:
@canuckerfan The d2v file without the .bad extension should be free of field order changes, so the normal tdeint/tfm script should work fine. Also, mode 4 or 5 should be unnecessary if the field order doesn't change. @Livesms Reading the eedi2 and tdeint help files for descriptions of the parameters would be the easiest way to tell how the scripts you posted differ from each other. The default versions of tdeint+eedi2 are: for same rate deinterlacing: interp = separatefields().selecteven().eedi2() tdeint(edeint=interp) for bobbing: interp = separatefields().eedi2(field=-2) tdeint(mode=1,edeint=interp) Then add assumetff() or assumebff(), whichever the video is, just before the interp line. |
18th November 2006, 05:31 | #823 | Link | |
Huh?
The source is a DVD and the VOBs occupy ~3.3GB, so unless you know of a place where I can upload at least 0.99GB at a time I'd have to snail mail it to you, which is ok y me if it comes to that. Anyway, you can download the d2v file here. Let me know when you download it so I can delete it.
18th November 2006, 19:57 | #824 | Link |
I've got 720*480 29.970fps interlaced(telecined) video. Here is the sample.
I need to reencode it to play with PAL 4:3 25p It's look like 4:2 pattern - 4 interlaced frames and 2 progressive frames, but it looks like this has been processed before - because the first of 2 progressive frames has some artifacts that look like a bad deinterlacing. MeGui test analyse And suggested script is Code:
edeintted = AssumeTFF().SeparateFields().SelectEven().EEDI2(field=-1) tdeintted = TDeint(edeint=edeintted,order=1) tfm(order=1,clip2=tdeintted).tdecimate(hybrid=3) What can you suggest - is it possible to turn such video to 4:3 x 25p? |
18th November 2006, 20:50 | #825 | Link |
@Livesms - that's fieldblended crappola. The underlying "true" framerate seems to be 22 fps, perhaps 22.5 fps. (Not in the mood now to count exactly )
Pretty strange source. Qualified for cabinet of curiosities ...
18th November 2006, 21:00 | #826 | Link | |
So is it possible to correct this source and make it 25fps progressive? I tried Code:
AssumeTFF() ConvertToYUY2() Bob(height=576) BicubicResize(768,576) ConvertFPS(50) SeparateFields.SelectEvery(4,0,3) Weave() |
18th November 2006, 21:10 | #827 | Link |
Correcting myself: after having a 2nd look, it seems to have been standard 23.976fps film that has been blendconverted. (the source is so crappy, it's not trivial for the naked eye to decide what's a blend and what should be "assumed clean" )
Restore24 doesn't play too well with this source: result is jumpy. Try MOmonster's solutions, or the manual deblending approach (blow_up_fps plus SelectEvery(offset) ) that scharfis_brain did show several times. Edit: Seems like I'm telling nothing but nonsense this evening, and R24 is more reliable than my eyes. I got this result, using Code:
Restore24(numr=2500,deno=5994,useLL=false,fulltriples=false,fra=1,frr=1,edgetype=1,r24size=0.7,nr=-5,ldmp=128.0)
- We´re at the beginning of the end of mankind´s childhood - My little flickr gallery. (Yes indeed, I do have hobbies other than digital video!) Last edited by Didée; 18th November 2006 at 21:33. |
18th November 2006, 21:13 | #828 | Link | ||
18th November 2006, 22:38 | #829 | Link |
@Chainmax
Could you try these two scripts and see if either crashes: blankclip(length=287626,pixel_type="YV12",width=720,height=576,fps=50,fps_denominator=1) tdecimate(mode=2,rate=29.97,debug=true) blankclip(length=287626,pixel_type="YV12",width=720,height=576,fps=50,fps_denominator=1) tdecimate(mode=2,rate=29.97,input="stats.txt",debug=true) you'll have to generate a stats file for the second, but it should be very fast to make. The blankclip clip should be exactly the same as the clip going into tdecimate in your case except for the actual imagecontent. Both scripts work fine here. |
19th November 2006, 01:38 | #831 | Link |
There will be one in the next week sometime. I've already added the tswitch function, fixed the problem with reading tfm's hints when passing through dgdecode's hints, and added a new blend deinterlacing mode. The remaining items are outputting a map and the deinterlaced frame at the same time (should be quick to add) and having the motion detection correctly handle the top/bottom lines (did about half of this already). Atm, I am messing other things.. neural network based edi, phase plane correlation motion estimation, and trying to improve some pso variations (clpso/dms-pso) for very high dimensional optimization (that last one is for school, but I'm using dms-pso/clpso to train the nn's for my nn-edi attempt).
19th November 2006, 10:55 | #832 | Link |
HDConvertToX author
i have a little problem
this script Code:
Import("C:\holding zone c\createautodeintmovie.avs") #original script filename global unused_ = blankclip(pixel_type="yv12", length=10).TFM() file="C:\holding zone c\createautodeintmovie.avs.bautodeint_temp.data" global sep="-" function IsMoving() { global b = (diff < 1.0) ? false : true} c = last global clip = last c = WriteFile(c, file, "a", "sep", "b") c = FrameEvaluate(c, "global a = IsCombedTIVTC(clip, cthresh=9)") c = FrameEvaluate(c, "IsMoving") c = FrameEvaluate(c,"global diff = YDifferenceFromPrevious(clip)") crop(c,0,0,16,16) SelectRangeEvery(15,15,0) Code:
LoadPlugin("C:\Programmi\PureBasic4\AutoMKV\exe\filter\dgdecode.dll") LoadPlugin("C:\Programmi\PureBasic4\AutoMKV\exe\filter\decomb.dll") LoadPlugin("C:\Programmi\PureBasic4\AutoMKV\exe\filter\TIVTC.dll") movie = mpeg2source("C:\holding zone c\movie.d2v") return movie Code:
I don't know what "a" means-true I don't know what "a" means-true I don't know what "a" means-true where is the error ? thanks ! BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
20th November 2006, 06:55 | #833 | Link | |
Huh?
The second one loads fine as well . Maybe it's just some Avisynth weirdness on my end, so I guess I'll stick to either mode=0 or mode=7, could you tell me the pros and cons of either and on what kind of source they would perform better than the other?
Read Decomb's readmes and tutorials, the IVTC tutorial and the capture guide in order to learn about combing and how to deal with it. Last edited by Chainmax; 20th November 2006 at 15:50. |
20th November 2006, 22:51 | #834 | Link |
Import("C:\holding zone c\createautodeintmovie.avs") #original script filename global unused_ = blankclip(pixel_type="yv12", length=10).TFM() file="C:\holding zone c\createautodeintmovie.avs.bautodeint_temp.data" global sep="-" global diff=1.0 global a=true function IsMoving() { global b = (diff < 1.0) ? false : true} c = last global clip = last c = WriteFile(c, file, "a", "sep", "b") c = FrameEvaluate(c, "global a = IsCombedTIVTC(clip, cthresh=9)") c = FrameEvaluate(c, "IsMoving") c = FrameEvaluate(c,"global diff = YDifferenceFromPrevious(clip)") crop(c,0,0,16,16) SelectRangeEvery(15,15,0) |
20th November 2006, 23:07 | #835 | Link |
Huh?
Should I cut&paste that into a script and try to load it?
21st November 2006, 08:26 | #836 | Link |
HDConvertToX author
@Wilbert
Yes ! is working... now i will ask Berrinam to update BAutoDeint.exe thanks again BHH
21st November 2006, 11:10 | #837 | Link |
I'm sorry. Could anybody tell me what does it script for
21st November 2006, 13:25 | #838 | Link |
HDConvertToX author
http://forum.doom9.org/showthread.php?p=765485
not truly create an avs to deinterlace BUT analyze the clip, and find the "interlace pattern" watch at result and then apply something like.... Code:
interlaced: LeakKernelDeint(order=xxx) decimating: tfm(movie.d2v).tdecimate() partly film: tfm(d2v="movied2v").tdecimate(hybrid=1) film:tfm(d2v="movie.d2v").tdecimate() partly interlaced: edeintte=last.SeparateFields().SelectEven().EEDI2(field=-1) TDeint(full=false,edeint=edeintted) BHH
24th November 2006, 11:19 | #839 | Link |
hi, i'm new to tdeint and found it's not easy to tweak it for some stuff.
here's a sample i've tried lowering the mthresh and cthresh to try catch the comb, type 1 and 3 are also employeed. any parameter i missed can help improve the result? btw, tomsmocomp(1,5,1) give me far better result, at least, no comb left, but i found the result a bit smeared. Last edited by Valeron; 24th November 2006 at 11:28. |
24th November 2006, 12:45 | #840 | Link |
Could be a problem of field ordering. To test it, use tdeint with only the parameter "order". Admits three value. -1, 0, 1. Try with 0 and 1. If the result is good with parameter 0 then your video is bff. If the resutl is good with parameter 1 your video is tff. In none is good, then really tdeint is not well suited. But is the first case I've heard of. Anyway is convenient post also the script used. Good luck |
tdeint, tivtc |
