Old 15th June 2009, 21:39   #1  |  Link
crassislame
video codecs/ffdshow tryouts settings???
I have been trying to edit on sony vegas for several weeks now...and everytime I open a video file, I only get audio and no video.
I have used various programs to help like g spot and ffdshow-tryouts.
the vfw setting in ffdshow seems to be somewhat helpful...it is because of setting h264 to libavcodec, on the vfw component, that I am able to drag and drop the files on the video section of sony vegas...but they still show a black screen.
The files I am trying to watch are avi files.
Someone on tech support forums said that someone here may be able to help me tweak the vfw settings to help get things working. I am also open to any other suggestions.
thanks
crassislame is offline   Reply With Quote
Old 15th June 2009, 22:21   #2  |  Link
St Devious
Hardware Aspirin
please post info of the file with this software- MediaInfo http://mediainfo.sourceforge.net/en
St Devious is offline   Reply With Quote
Old 2nd July 2009, 04:18   #3  |  Link
crassislame
General
Complete name : J:\DCIM\200MOVIE\CLIP0007.AVI
Format : AVI
Format/Info : Audio Video Interleave
File size : 20.6 MiB
Duration : 1mn 29s
Overall bit rate : 1 940 Kbps
Video
Format : AVC
Format profile : Main@L3.0
Format settings, CABAC : Yes
Format settings, ReFrames : 1 frame
Codec ID : H264
Duration : 1mn 29s
Bit rate : 1 844 Kbps
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4/3
Frame rate : 30.000 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.200
Stream size : 19.6 MiB (95%)
Audio
Format : ADPCM
Codec ID : 2
Codec ID/Info : Microsoft ADPCM
Duration : 1mn 29s
Bit rate mode : Constant
Bit rate : 88.2 Kbps
Channel(s) : 1 channel
Sampling rate : 22.05 KHz
Resolution : 4 bits
Stream size : 967 KiB (5%)
Interleave, duration : 92 ms (2.77 video frames)
Old 2nd July 2009, 15:56   #4  |  Link
St Devious
Hardware Aspirin
have you checked H.264 to libavcodec under ffdshow video decoder settings ?
Old 2nd July 2009, 16:31   #5  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
crassislame
Are you sure that Vegas allows using 3rd party decoders/splitters for decoding? If no, try to remux your h264 video to mp4.
Old 2nd July 2009, 19:02   #6  |  Link
crassislame
st devious
Yea, H.264 is set to libavcodec, would it be possible that adjusting other settings besides H.264 would make a difference?
Keiyakusha
How exactly would I remux my h264 video to mp4? Isn't that just like converting files?
ffdshow tryouts, g spot, sony vegas, video codec
