26th September 2007, 11:38 | #1401 | Link |
HI there!
I've got a strange situation with FU4WM... I have an WMV file with DRM protection, I have the latest FU4WM - but nothing happened when I tried to remove the protection. Yes, I have the Licence for that file! I got the message: 1 files converted 0 errors 0 warnings But the process was just a few seconds long and the file what I found in the destination folder is just 7075 bytes long. I opened with an editor, I think that just the header of the WMV file. What is the problem? The original filesize is more than 1 Gib. I cutted the file at 500 MiB, 300 MiB but the results are same like before. My WMP is v10.00.00.3646 english version FU4WM version is 1.3 fix-2 Filesize is 1.228.566.391 bytes Created filesize is 7075 bytes My IndivBox.key version is 11.0.5497.6285 (How can I change this file to an earlier version?) Earlier I removed many DRM protection from more than a hundred files (FIFA World Cup HighLights) without any problem. If you have any hint just tell me, please! And: I am sorry for my english knowledge! Cheers! Jack Last edited by JackJeruk; 26th September 2007 at 12:33. Reason: I am forgot something what is important |
26th September 2007, 12:47 | #1402 | Link | |
26th September 2007, 15:36 | #1403 | Link |
I would like to ask you to test FreeMe2. It has reached beta stage and now works (at least should) with all kinds of packet types and udrmed files play even in WMP. It is reported to work with both WMP9 and WMP10 and to not fully work with WMP11. I am waiting for your opinions
26th September 2007, 17:54 | #1404 | Link | |
26th September 2007, 19:00 | #1405 | Link | |
http://forum.doom9.org/showthread.php?t=130055 |
26th September 2007, 19:38 | #1406 | Link | |
27th September 2007, 05:08 | #1409 | Link | |
Media Stream Ripping Pro
30th September 2007, 08:58 | #1410 | Link | |
Also FreeMe2 doesn't work unfortunately. I double click on it and it just comes up with a command prompt saying "hit enter to acknowledge error." I recently heard of AnalogWhole but that doesn't work either lol. It won't recognize a recording device, it let's me choose CD Player or Master Volume during setup, but not Stereo Mix, so it only records static noise. Sigh, any ideas? I just want to play my music from SpiralFrog on my iPod. |
30th September 2007, 21:50 | #1411 | Link |
I'm pretty sure I searched through the forum thoroughly, so I hope this doesn't seem redundant...
If I run mirakagi, this is what I get: Mirakagi starts, code version 0.9 Found 2 keys in keyring. ----------------- Processing "C:\Documents and Settings\All Users\DRM\cache\Indiv01.key" Version: 11.0.6000.7000 ... XML - Cert: 84 bytes, Key Storage: 1392 bytes. DLL 1000/a70ea @ ac01000 && a9000/1d8c1 @ aca9000 Exception c0000005 caught during file "C:\Documents and Settings\All Users\DRM\cache\Indiv01.key". It is finished. Then if I run FairUse1.3 Fix 2 I get the "different private key" message. If I try to recover keys again in FairUse, it gets to "please wait" and then freezes. One other piece of info: I was able to successfully unDRM songs from Ruckus just a week or two ago, but for some reason Ruckus updated its drm a second time within an hour. Regardless, it says it's still only drm version 11.0.5721.5145, security version 2.9.0.1. I deleted the drm folder and re-updated the drm. Same problem. Any help? |
30th September 2007, 21:58 | #1412 | Link |
grinderxxx: your Mirakagi is telling you that you have ibx key version 11.0.6000.7000, which is currently unsupported, unfortunately. You can try "rolling back" to an earlier version, but otherwise, you're SOL until another update comes along.
30th September 2007, 22:13 | #1413 | Link |
You can crack 11.0.6000.7000 using newest version of drmdbg. Thanks to it you will get the SID for any file. That SID can be used to decrypt file using FreeMe2/drm2wmv.
1st October 2007, 02:17 | #1414 | Link | |
I dont care so should you
LINK post a LINK Last edited by Ajax_Undone; 1st October 2007 at 02:21. |
1st October 2007, 07:41 | #1416 | Link |
Here's a VERY EASY solution to get fairuse working, at least for non-vista users:
(1) Roll back WMP to Version 10 (go to add/remove programs). Get through everything, and restart your computer. (2) This is the key step that makes rolling back actually work. Go to add/remove programs again and UNINSTALL WINDOWS MEDIA RUNTIME 11. This sneaky bitch is what lingers after the previous uninstall and makes your life suck. (3) Delete the DRM folder. (4) Run your media download program and have fun with FairUse again! |
1st October 2007, 22:32 | #1417 | Link |
The "Getting..." thread is here: http://forum.doom9.org/showthread.php?t=130166
I tried checking out that Japanese website that has something to do with drmdbg, but I must be a little rusty in my Japanese, as I had no idea what was being said (and Google proved quite unhelpful). |
9th October 2007, 10:16 | #1420 | Link | ||
Capture, Deinterlace
