Old 27th May 2007, 16:06   #1101  |  Link
cclapper
Thanks
Thanks for listing the mirrors, I had troubles with previous download locations.
Youswitch provides advice on switching utility bills.
broardband advice
cclapper is offline   Reply With Quote
Old 16th June 2007, 16:55   #1102  |  Link
paranoid87
thanks guys for all the new mirrors..i was frustated that many old ones werent working!
paranoid87 is offline   Reply With Quote
Old 19th July 2007, 16:32   #1103  |  Link
j10
Backuphddvd Download Mirror
http://www.backuphddvd.net
j10 is offline   Reply With Quote
Old 8th August 2007, 01:18   #1104  |  Link
gonwk
Hi folks,
@ j10 ... Thanks for the mirror site.
G!
gonwk is offline   Reply With Quote
Old 9th August 2007, 02:46   #1105  |  Link
HyperHacker
Resident DRM Hater
HyperHacker's Avatar
You should add the V3 processing key too.
Because Moogles pwn.
HyperHacker is offline   Reply With Quote
Old 20th January 2008, 23:04   #1106  |  Link
bmnot
Error
I get the following error when I start the BackupHDDVD process in Command Prompt:
"Error: no 'server' JVM at 'C:\Program Files\Java\jre1.6.0_04\bin\server\jvm.dll"
I am running Vista but I dont think this is the problem? Any ideas?
bmnot is offline   Reply With Quote
Old 20th January 2008, 23:17   #1107  |  Link
Shinigami-Sama
Solaris: burnt by the Sun
Shinigami-Sama's Avatar
do a search for 'Missing Java server"
the JRE/SDK(can't remember which) doesn't put some of the files in the right place it seems
Originally Posted by benjust View Post
interlacing and telecining should have been but a memory long ago.. unfortunately still just another bizarre weapon in the industries war on image quality.
Shinigami-Sama is offline   Reply With Quote
