Old 3rd July 2012, 22:19   #141  |  Link
dr.schanker
dr.schanker's Avatar
FFVideoSource should work, i just tested a Photo-JPEG .mov with a somewhat recent version of ffms2.dll (May 2012) under WinXP.
Alternatively you could remux your Photo-JPEG .mov's to another container (e.g. .avi) with ffmpeg, use the switches '-vcodec copy' and '-acodec copy' to keep the original streams (no reencoding). This will give you an .avi which can easily be decoded by a MJPEG VfW decoder, e.g. 'ffdshow VfW'.
dr.schanker is offline   Reply With Quote
Old 4th July 2012, 10:26   #142  |  Link
stoffal
Thank you kolak and dr.schanker !
I will play around with a script to edit the 700 Quicktime files as mentioned by kolak. If this does not work, I will try out vvvideosource again. Good workarounds, thank you.
stoffal is offline   Reply With Quote
Old 7th July 2012, 06:16   #143  |  Link
tateu
Use mode=2 or mode=3. And if it is avc/h264, definitely use FFMpegSource instead.
tateu is offline   Reply With Quote
Old 15th July 2012, 21:45   #144  |  Link
stoffal
Thank you , Tateu. "mode=2" helped and opens the video in its real size. Great help !
Old 31st July 2012, 18:30   #145  |  Link
buck-tick
Hi tateu!
I noticed the QT plugin for VDub doesn't load multi track audio like the Plugin for AviSynth does. I have a 8 channel ProRes I use to test with and it loads as mono in VDub with latest QT plugin from your site.
<3 your AviSynth plugin
Man this would make my life easier in trying to see waveform at a glance without having to open up a heavy program like FCP or Premiere
buck-tick is offline   Reply With Quote
Old 31st July 2012, 22:00   #146  |  Link
tateu
Yeah, the Quicktime version has never really been updated like the AviSynth version.
I know there are probably lots of people who use VirtualDub but do not use AviSynth...I am not one of them. I also use a custom VirtualDub which automatically writes a temp AviSynth script when I open a Quicktime movie and I also use ASynther through the SendTo menu to quickly get my AviSynth scripts started...I just don't have a personal reason to keep the VirtualDub plugin updated since I don't ever use it so it's hard to get motivated to work on it.
And to be honest, they both need a complete rewrite to clean up the supreme mess they have become...Again, it's hard to get motivated to do it.
Old 1st August 2012, 00:25   #147  |  Link
buck-tick
Np.
Thanks for the plugins as they are.
Old 9th August 2012, 13:08   #148  |  Link
hanfrunz
hanfrunz's Avatar
Set up some kind of a donation or flattr button, maybe we can get you motivated
If you visit IBC in Amsterdam this year i'll get you some beers, too.
regards,
hanf "using qtinput everyday" runz
hanfrunz is offline   Reply With Quote
Old 13th November 2012, 12:59   #149  |  Link
kolak
tateu can you port QTinput to vapoursynth and add 10bit+ color spaces (v210, b64a, v216 etc)?
Old 2nd June 2013, 17:21   #150  |  Link
colinhunt
tateu, what would it take to get you motivated about developing qtinput further? Perhaps a sizable donation?
colinhunt is offline   Reply With Quote
Old 2nd June 2013, 21:30   #151  |  Link
kolak
+1
Old 14th November 2019, 10:14   #152  |  Link
astronob
Yes, please add 10bit+ color spaces to QTinput. I'd like that too.
astronob is offline   Reply With Quote
Old 15th November 2019, 10:13   #153  |  Link
LigH
LigH's Avatar
I doubt this filter will be developed any further. L-SMASH Works (LSMASHVideoSource supports the index chunk in MOV files, LwLibavVideoSource creates an own index) should have made it more or less obsolete.
New German Gleitz board
