Old 7th January 2008, 15:49   #801  |  Link
Chumbo
Chumbo's Avatar
Originally Posted by Deinorius View Post
AVCSource don't have any cpu argument. It's just what the error message says. Of course, it would not run. Read the instructions.
Deblock is the only argument, which is supported.
...correctly.
Yes I realize that. Did you not read my entire message? My point is that "I copied it from the Quickstart guide" so why is it in the guide if it's not an argument?
Chumbo
Chumbo is offline
Old 7th January 2008, 16:56   #802  |  Link
Deinorius
Najarenthur
Deinorius's Avatar
Perfect question for neuron2. I already asked myself too, after I read your post. oO
Deinorius is offline
Old 7th January 2008, 17:46   #803  |  Link
It was a mistake when making the guide cloned on the DGMPGDec one. I will fix it. Thank you for pointing it out.
Guest is offline
Old 7th January 2008, 19:52   #804  |  Link
Chumbo
Chumbo's Avatar
No worries, thank you. Did the avs file issues make any sense?
Chumbo
Chumbo is offline
Old 13th January 2008, 11:48   #805  |  Link
7oby
Originally Posted by ficofico
It's possible to use this amazing tool using command line input ?
Not yet. Be patient.
I'd really appreciate such a feature as well (dpmpgdec121 had also supported it). Wouldn't require full command line support, just the DGAVCIndex .dga generation.
I have some MPEG4-AVC elementary streams extracted from European Sports DVB-S2. Those are real interlaced streams (not 24p, 25p, 29,97p pull-ups) featuring 50fps. They have all sorts of features like PAFF and these two filters fail terrible:
. CoreAVC 1.5.0.0
. ffdshow beta4a rev1723
Besides - I'd really like to get rid of DirectShowSource() dependency.
Best results I get with dgavcdec100a13, but can't automate it.
regards,
7oby
7oby is offline
Old 3rd February 2008, 09:39   #806  |  Link
MoUCLAs
Encoding for people..
i have the same problem..
We Capture.. you Watch..
MoUCLAs is offline
Old 4th February 2008, 05:55   #807  |  Link
For the PAFF warning, just hit Yes to continue. It may or may not work, depending on libavcodec. If it doesn't play in ffdshow or VLC, it will probably fail in DGAVCDec as well. BTW, I've removed the PAFF warning in alpha 14, which I will post shortly.
For the other warning, hit No to disable further warnings. The streams I have with this warning decode correctly. This is a libavcodec issue.
Guest is offline
Old 4th February 2008, 07:10   #808  |  Link
Version 1.0.0 alpha 14
* Completes transport stream support for video. You can now do Save Project on transport streams and serve the video with DGAVCDecode.
* Added Save Project and Demux Video option in the File menu.
* Added Loop Playback option in the Options menu.
* Added option to control creation of the info log in the Options menu.
* Corrected some manual problems and linked them in the Help menu.
* Removed the PAFF blow-up warning.
http://neuron2.net/dgavcdec/dgavcdec.html
Next up is audio demuxing and project ranges (cutting).
Guest is offline
Old 4th February 2008, 10:16   #809  |  Link
7oby
Great work!
Given that there are already tools for demuxing (xport, tsremux, ...) and project ranges (H264TS_Cutter), ... I'd really need that command line option.
Nothing fancy. Just stupid Open + Save Project + Exit.
DGAVCIndex -AIF=[video.h264] -Video_PID 1234 -EXIT -OF=video
regards,
7oby
7oby is offline
Old 4th February 2008, 13:01   #810  |  Link
Deinorius
Najarenthur
Deinorius's Avatar
Yeah, me too. But good things need time (if this is the correct translation into english).
@neuron2
Old 4th February 2008, 18:10   #811  |  Link
OK, I'll do the CLI next.
It's going to have UNIX-style syntax, not the problematic one in DGMPGDec.
Guest is offline
Old 5th February 2008, 05:22   #812  |  Link
check
phjbdpcrjlj2sb3h
check's Avatar
Best news I've heard all week!
check is offline
Old 5th February 2008, 07:08   #813  |  Link
Adub
Fighting spam with a fish
Adub's Avatar
Now, how about the next step?
Linux support!
FAQs:Bond's AVC/H.264 FAQ
Site:Adubvideo
Adub is offline
Old 5th February 2008, 13:15   #814  |  Link
lucassp
How do you use AVISynth on Linux?
lucassp is offline
Old 5th February 2008, 13:34   #815  |  Link
nm
Currently with Wine. DGAVCDec probably works too already.
nm is offline
Old 5th February 2008, 18:48   #816  |  Link
Adub
Adub's Avatar
I meant native linux support.
Actually does anyone know what the overhead is like when running Avisynth or DGAVCDec on linux is? How does it compare when running on native windows xp?
Site:Adubvideo
Adub is offline
Old 5th February 2008, 19:20   #817  |  Link
dk75
dk75's Avatar
First - must be an AVS for Linux. Thought, AVS3 will be for Linux too, but it will be useable... somewere in the distant future ;P
I'm going down...
dk75 is offline
Old 6th February 2008, 00:35   #818  |  Link
Version 1.0.0 alpha 15 -- adds CLI
OK, here's your primitive CLI:
Guest is offline
Old 6th February 2008, 00:50   #819  |  Link
Originally Posted by Chumbo View Post
- If the avs file already exists, saving the project does not rewrite the file. This would be nice incase a change is made to the template.
It's intentional. If you have made any changes to the automatically generated file, you don't want to lose them. Yes, I know you can argue it both ways, but I think changes to the generated script are more likely than changes to the template.
- if the avs file already exists, opening the same-named.avc file again in DGAVCIndex locks the existing same-named.avs file. So if I want to delete it, I can't. I have to close DGAVCIndex, delete it, reopen DGAVCIndex, load the .avc file and reprocess it.
That's a bug. I'll fix it at some point.
Guest is offline
Old 6th February 2008, 01:32   #820  |  Link
Chumbo
Chumbo's Avatar
Thank you.
Chumbo
Chumbo is offline
