Old 15th March 2007, 14:12   #201  |  Link
Eretria-chan
They are indeed. 100% CPU use.
Eretria-chan is offline   Reply With Quote
Old 15th March 2007, 14:43   #202  |  Link
Sirber
retired developer
Sirber's Avatar
Cool! Maybe I could use that build in default setup...
It seems to use SSE/SSE2 too even in "cpu detection mode".
Detritus Software
Sirber is offline   Reply With Quote
Old 18th March 2007, 07:53   #203  |  Link
Weltall
Weltall's Avatar
Hi Sirber! I'm amazed with no delay conversion of Bencos, now I really trust on outputs and don't open them to see if they're delayed, thank you for that. Btw, why?? Is there something to do with new enhAacPlusEnc?
Lastly, I've noticed you added "Fix levels" to your GUI, how it works, compared with ffdshow? Is it something like Levels(16,1,240,0,255) (avisynth tv->pc)?
I get many tv levels encodings in my country, so It's my only big worrying when encoding (I've posted some screenshots in my topic about this here).
I'm very curious about many functions BENCOS has (and could come to have). Maybe it's asking too much, but I have the excuse of user feedback then it would be great if you write a readme (maybe hints too!) explaining its functions and what the filters you added do with the configs you used when adding, so we could really understand them. Yeah... very great!
"After all, Love remains, burned into our memories. We all search for love. But some of us, after we found it, wish we hadn't."
Weltall is offline   Reply With Quote
Old 18th March 2007, 13:20   #204  |  Link
Eretria-chan
Btw, my latest findings!
- Add a lot of files to the playlist in Vista and no file will get added. Works fine in XP.
- You can remove the currently encoding file from the playlist. It doesn't screw up anythng, but it's weird.
- Sometimes files fail to encode when both height and width is not multiple of 16. x264 fails if I'm not mistaken. But using resizing to fix that works.
- Sometimes it says corrupt source. I haven't investigated those files yet, though.
Old 18th March 2007, 14:36   #205  |  Link
Sirber
retired developer
Sirber's Avatar
New encoding chain. Bencos doesn't use DirectShow or VFW decoders, everything is done with mencoder and mplayer. With the help of many people now it's working relativly well
if (chkFLevel.Checked) then
      sOptTmp := sOptTmp + ' -vf pp=al:f ';
from manpages:
al/autolevels[:f/fullyrange]
automatic brightness / contrast correction
f/fullyrange: Stretch luminance to (0−255).
I'll make a readme someday, when bencos gets more stable. I'm still not finished with all the features I want / need.
Try to remove the .manifest from bencos folder. Could be UI problems.
Yes. GUI and encoding chain are separated.
Yes, but x264 should warn not fail. Look in the logs panel.
When mencoder gives me "Error decoding frame" I cancel the recoding. Too much decoding errors will produce audio / video delay.
Detritus Software
Old 18th March 2007, 15:50   #206  |  Link
Eretria-chan
It doesn't work. Maybe there's a bug somewhere
If width or height is not dividizable by 16 (only one), it spits out a warning. If both are not dividizable by 16, it fails. So I've noticed. The logs confirms this.
So I take it, when it says "Source Corrupt," it means there are undecodable frames, ie a damaged source file?
Old 18th March 2007, 15:54   #207  |  Link
Sirber
retired developer
Sirber's Avatar
http://www.detritus.qc.ca/forum/view...p?pid=253#p253
In case you wanna play with bad sources
Yes. You can try to fix or use the newer bencos build. Be sure to check your output for audio / delay or other issues.
Detritus Software
Old 20th March 2007, 17:12   #208  |  Link
Eretria-chan
I have to say wow...
Bencos gives such perfect quality to high-quality sources at even such a low bitrate I'm impressed!
Now how about that DVD input and subtitles? ^_^
Looking forward to a release with any new features. Take your time!
Old 20th March 2007, 17:28   #209  |  Link
Sirber
retired developer
Sirber's Avatar
I didn,t have news about Sharktooth in a while. Code for subtuitles is half done
Detritus Software
Old 23rd March 2007, 02:52   #210  |  Link
Eretria-chan
Question!
When encoding, does Bencos downsample 5.1 sound to stereo? If not, then 32 kbps would be far too little!
I also wondered about the profiles. Sharktooth made the non-anime profiles, right? I just wondered how they were aimed - for high bitrate or low bitrate encodes? I was testing at encoding a DVD movie, and found pretty sweet around 1000 kbps with few artifacts and no artifacts I could see at 2000. That's just initial testing, though.
enhAacPlusEnc.exe supports higher channel count from what I judged from its command line, but that would require higher bitrate. 16 knps per channel is the sweetspot, I think, since 32 kbps for stereo is good.
Old 23rd March 2007, 12:00   #211  |  Link
Sirber
retired developer
Sirber's Avatar
IIRC I downsample to 2.0 Not sure about the quality though.
you can see what I do when I extract audio, in the logs panel.
Detritus Software
Old 23rd March 2007, 14:20   #212  |  Link
Eretria-chan
I haven't looked at those logs, but it should be easy to add a feature for compressing multi-channel audio, would it not?
Old 23rd March 2007, 14:41   #213  |  Link
Sirber
retired developer
Sirber's Avatar
maybe I could look in mencoder logs for channel count and set enhaacplusenc... but it would be far in the todo list.
Proper subtitles support and DVD input would be more needed
Detritus Software
Old 23rd March 2007, 21:49   #214  |  Link
Eretria-chan
If not otherwise, we could manually set the channel count, since this is just an argument passed to the encoder, no? Maybe you could add such a small thing for now until proper support can be added?
Old 23rd March 2007, 22:27   #215  |  Link
killerhex
hey does the audio encoder downmix automaticly 5.1->2.0chs
killerhex is offline   Reply With Quote
Old 24th March 2007, 14:53   #216  |  Link
Sirber
retired developer
Sirber's Avatar
no, it doesn't
Detritus Software
Old 24th March 2007, 15:12   #217  |  Link
Eretria-chan
A manual channel count and higher bitrate for sound might be a good idea when encoding 5.1 or higher sound? For special encodes, so to speak.
It should be farily easy to add. No needing to log in logs for channel count and things like that (though that would be cool).
Old 24th March 2007, 16:06   #218  |  Link
Sirber
retired developer
Sirber's Avatar
so 2.0 source will be upgraded to 5.1? Best solution is by using source info no?
Detritus Software
Old 24th March 2007, 19:33   #219  |  Link
killerhex
has anyone ever needed to encode 7.1 to 2.0
Old 24th March 2007, 21:03   #220  |  Link
Eretria-chan
Sure it is, but as you don't have high priority on it right now, then a small workaround would be good, hm? Just an option among everything else, so my 5.1 source can be encoded properly.
...Terrific. Guess I'll have to encode the audio separately. Guess we'll see if Bencos can handle sources without audio.
aac, bencos, gui, webm, x264
