16th August 2007, 14:56 | #621 | Link |
Just my opinion:
- DialNorm: is a tool to equalize volume from different sources. If you only listen ac3 sources is a valid option to maintain the volume control at same position. If you listen also modern CDA music, commercial TV, mp3, ... use DialNorm -31 dB (and maximize peak to 0 dB). - DRC: useful in bad listen environment (neighbors, night, bad audio equipment, ...). Recommended, if your audio equipment is bad you need them, if is good you can disable/enable at your choice. Remember, the audio is equal encoded, only attenuation/gain values are added and the decoder can use or not. |
16th August 2007, 16:07 | #622 | Link |
eac3to generates a wrong wav file
source is 16bit 48khz 7.1ch Blu-ray lpcm and tried converting to ac3. command line and output is: F:\eac3to>eac3to f:\Innocence.pcm f:\Innocence.ac3 -8 -16 -down6 RAW, 7.1 channels, 0:01:00, 16 bits, 48khz Converting the raw file to wav. Please wait... Converting the wav file to ac3. Please wait... Aften: A/52 audio encoder Version 0.07 (c) 2006-2007 Justin Ruggles, Prakash Punnoor, et al. invalid RIFF id in wav header invalid wav file: -b "aften" reported error code "1". A valid *.wav file was created sucessfully, though. this wav file eac3to created crashes mpc. mediainfo says; Codec : PCM Codec/Family : PCM Codec/Info : Microsoft PCM Bit rate : 6144 Kbps (should be 4608 Kbps?) Channel(s) : 6 channels Sampling rate : 48 KHz Resolution : 16 bits |
16th August 2007, 17:15 | #623 | Link | |
16th August 2007, 17:35 | #624 | Link | |
rev.561 of Aften does create a file which is just stereo@640k and produces only noise. |
16th August 2007, 19:21 | #626 | Link |
yes Madshi, ofcourse youre right...its reversed. DRC makes only Sense with proper Dialnorm. As written in the Guide
My Post was very vague and i dont force anybody to anything @Nikos..i know When its a full lengt Track you cant use only a small Part. However.. i dont use DRC and no DialNorm.. i encode with -31db ( -31db +31db = attenuate 0db) and no DRC Profile Last edited by ACrowley; 16th August 2007 at 19:35. |
16th August 2007, 20:04 | #627 | Link | |
One more question: If one ac3 file has Dialog Norm. and DRC, the software ac3Filter bypass them or not?
Greece PAL User... |
16th August 2007, 21:39 | #629 | Link | |
I mean if the ac3Filter can bypass the Dialog Norm. and DRC written as metadata inside the ac3 stream.
16th August 2007, 21:46 | #630 | Link | |
Posts: n/a
The DRC option in AC3Filter allows for respecting or ignoring the DRC data in the AC3 stream. If you set AC3Filter to passthrough AC3 to an external receiver of SPDIF then the receiver (or your hand at the remote control) decides whether DRC should be applied. Last edited by honai; 16th August 2007 at 21:49. |
16th August 2007, 22:12 | #631 | Link | |
This kind of function can be applied for any source, not only ac3, and is a better solution than ac3 DRC but require more resources, is not habitual in receivers or standalone players. |
16th August 2007, 22:38 | #632 | Link | |
The values of DRC are modified by DialNorm but the concept is absolutely different: DialNorm try to normalize all the sources at same level (dialogs at -31 bB), ... but is a lose battle, the others formats go 10 dBs upper. But DRC is a help for some situations. The ideal solution is, like I say in precedent post, the player make the function at player time, but waiting for this solution we can use ac3 DRC, not necessarily with DialNorm. |
16th August 2007, 23:44 | #633 | Link | |
When i have have mistaken something ,ok no Problem.
I can only read the Guide ,where you can find for "AC3 encoding" Quote:
I dont care...as i say i dont use DRC in encoding/decoding Last edited by ACrowley; 17th August 2007 at 00:03. |
17th August 2007, 08:17 | #637 | Link |
Somehow the audio I ripped isn't timed correctly... The movie itself is 01:59:55. While the extracted AC3 track is 01:49:55 in length ><. So if you have any way to fix that? Or is my BD disc just crap >_>... Otherwise I'll just use the AC3 448kbps stream from the DVD...
I used this command: eac3to bits0001.thd WoH.ac3 That should be correct right? I demuxed the thd stream with xport. With the -a option. |
17th August 2007, 14:02 | #639 | Link | |
You helped me a lot with all these previous AC3 encoding/decoding DRC/Dialnorm Thing . No i see Things clear. THX |
17th August 2007, 22:00 | #640 | Link |
It's The Wings of Honnêamise BD Rip. (I got the rip from usenet, everything was ok with it, no faulty rars and such).
If you could find a solution for such a weird error ? otherwise I'll just use the 448kbps audio from the DVD. Also the subs are troublesome , need to enter all text manually... Last edited by big-guy; 17th August 2007 at 23:54. |
eac3to |
