Old 26th November 2012, 11:07   #13141  |  Link
sneaker_ger
If no decoder accepts the connection?
Sorry, I don't know much about DirectShow.
Also see my edit.
Old 26th November 2012, 11:09   #13142  |  Link
nevcairiel
LAV only exposes a pin, it doesn't manage the graph building.
Old 26th November 2012, 11:10   #13143  |  Link
sneaker_ger
I see. So then a Splitter option would be needed.
Old 26th November 2012, 15:05   #13144  |  Link
Vasilich
i suppose LAV audio in above case will select AC3 core track if TrueHD is UNchecked in its options?
Vasilich is offline   Reply With Quote
Old 26th November 2012, 15:09   #13145  |  Link
nevcairiel
Thats not how DirectShow works. The source exposes a pin with a specific type, and DirectShow trys to find a filter that accepts this type. If the exposed type is TrueHD, then you need a decoder that can decode TrueHD, LAV Audio cannot decide to change this to AC3, because it wouldn't even get a chance for that. Usually the player or DirectShow itself control the graph building, the filters can only decide what they accept and what not.
Old 26th November 2012, 16:34   #13146  |  Link
Vasilich
it means that there is no chance to hear anything (without manual switching of audio tracks) for above case if my receiver doesn't support trueHD?
or LAV audio can decode trueHD but i then need to use audio postprocessor for encoding this to AC3 because i have only optical cable connected to my receiver?
Old 26th November 2012, 16:36   #13147  |  Link
sneaker_ger
Either that or stereo only.
Old 26th November 2012, 16:40   #13148  |  Link
clsid
How about a simple option "Prefer HD audio tracks"?
Checked: use current logic based on quality and number of channels
Unchecked: DTS > AC3 > TrueHD, and 7.1 = 5.1 > 2.0
That would be helpful for those who want to bitstream to an older receiver.
MPC-HC 2.2.1
Old 26th November 2012, 17:52   #13149  |  Link
nevcairiel
Originally Posted by Tacio View Post
http://www.mediafire.com/?bo70xnw2xl9n30d
In DXVA checker this egur's test clip plays fine using my HD3000 and MS DTV-DVD video decoder. But with LAV filters and DXVA2n video is corrupted. The same is for MPC-BE.
I think i actually finally figured it out, and fixed the problem.
Try with this version:
http://files.1f0.de/lavf/LAVFilters-0.54-4-gc509fe2.zip
I would also appreciate if anyone could test this version with DXVA2 Native or CB on older Intel GPUs, if anyone has one? Like the 4500MHD? or Atoms?
Here is a sample which broke before this version, but works on SNB/IVB now:
http://files.1f0.de/samples/Madoka-002.mkv
Any feedback would be great, please confirm if its using DXVA2 on this sample, it will fallback to software if your Hardware and/or Driver doesn't support the proper H.264 spec (only on this sample, others with fewer reference frames will still use DXVA2 on those systems).
If you still have issues, a DXVA Checker report might be useful.
Old 26th November 2012, 18:47   #13150  |  Link
Tacio
Thanks!
Now this sample works fine on my HD3000 and atom 2800 using LAV filters and dxva2n!
Tacio is offline   Reply With Quote
Old 26th November 2012, 19:10   #13151  |  Link
nevcairiel
Great, thanks for confirming.
Old 26th November 2012, 21:24   #13152  |  Link
chros
chros's Avatar
A quick question regarding video decoding on nvidia GPU and dxva2n with madvr: is there any advantage using dxva2n over cuvid ? (performance, quality, etc.)
Thanks for your hard work!
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config
Old 26th November 2012, 21:49   #13153  |  Link
DragonQ
DXVA2 Native uses less power.
Old 26th November 2012, 23:57   #13154  |  Link
dansrfe
Feature request:
Keyboard shortcut to increase/decrease audio delay by specified amount on-the-fly for the current file.
Old 27th November 2012, 07:56   #13155  |  Link
plus minus at mpc hc
Old 27th November 2012, 10:10   #13156  |  Link
owlsroost
Tried the sample on Intel HD graphics (i5-460M 'Arrandale') - always falls back to software (which I suspect is the correct thing to do) and plays OK.
Tony
owlsroost is offline   Reply With Quote
Old 27th November 2012, 10:11   #13157  |  Link
nevcairiel
Ok thanks, looks like the old Intel GPUs do not offer the same functionality as the SNB/IVB GPUs then (which was mistakenly simply ignored before )
Old 27th November 2012, 11:17   #13158  |  Link
wanezhiling
http://pan.baidu.com/share/link?shar...&uk=3558042035
VP62, lav cant work.
Old 27th November 2012, 11:24   #13159  |  Link
owlsroost
Here's the info from DXVA Checker.
Tony
Old 27th November 2012, 18:04   #13160  |  Link
nevcairiel
I figured it would only have the Intel-specific ClearVideo H.264 variants, and not the generic ones, thanks.
