22nd March 2016, 20:14 | #37021 | Link | |
However, I found out what was causing the madVR problem for me: MSI Afterburner, or to be more precise: a certain setting of it. I disabled low level driver access, since I thought it would help to prevent compatibility issues. But the opposite is true: After enabling low level driver access with user-mode driver, the queue issue disappeared. They get nicely filled now. The R9 390 definitely offers a lot of performance for NNEDI3, it seems to be easily competing with a GTX 980 OC. It seems my 390 is stable with -100mV undervoltage, which keeps it very quiet, combined with a custom fan curve. Seems like a good deal if much NNEDI3 and SuperRes bang is needed for few bucks. Edit: Got a MSI R9 390 Gaming. Last edited by aufkrawall; 22nd March 2016 at 20:20. |
22nd March 2016, 21:27 | #37022 | Link |
super-xbr100 + AR with SuperRes doesn't ring a whole lot. I used to use a setting of 150, but the extra detail seemed less important than the added ringing. super-xbr is already very sharp at 100.
22nd March 2016, 22:15 | #37024 | Link | |
A whole boat load of features.. |
22nd March 2016, 22:33 | #37025 | Link |
@madshi
Hello. According to this thread, madVR seems to be generally used for rendering modern high-bitrate HD video, including 4k & 3D. Instead, I'm watching a lot of old MPEG-2 & H.263 encoded video. Such video often suffers from blocking, ringing/mosquito noise, aliasing or improper deinterlace. madVR already contain some filters to improve such video (SuperRes, sharpen filters), but it would be great to see even more video processing and enhancing options in madVR (EDIT: including AVS/VS plugins support, as alternative). Since improving old videos isn't main madVR goal, could you please tell, are adding deblocking/de-mosquitoing/anti-aliasing filters etc. possible/planned at all? Thanks for your work! |
23rd March 2016, 00:06 | #37028 | Link | |
There's one thing that I'd like to cite, although technologies has been advanced to HD-video, 3D, H265 etc., a lot of my favored contents are still SD, with a lot of such artefacts as mentioned by cork_OS. It really would be very zealous features for us, if madshi can considering adding, at least some of these, post-processing features to madVR, in an appropriate time. |
23rd March 2016, 00:24 | #37029 | Link | |
TV Setup: LG OLED55B7V; Onkyo TX-NR515; ODroid N2+; CoreElec 9.2.7 |
23rd March 2016, 05:12 | #37031 | Link |
AFAIA they're all stable as long as you're not deinterlacing. I've seen most recommend 13.12 still, It takes a few minutes to test so why not just update to the latest crimson
and if there's any issues then just post about them? Can't have people asking about what works every time a new driver is released. Last edited by ryrynz; 23rd March 2016 at 05:34. |
23rd March 2016, 06:14 | #37032 | Link | |
Characterizing Perceptual Artifacts in Compressed Video Streams
23rd March 2016, 11:25 | #37035 | Link | ||
Which standard? Broadcasting has a different standard than UHD Blu-Ray. UHD Blu-Ray allows using a BT.2020 container, and the studios can then use metadata to signal which exact subset of the container is used. This is very often DCI-P3. But the studio can use up to BT.2020, if they want to. |
23rd March 2016, 11:41 | #37036 | Link |
madVR v0.90.16 released
http://madshi.net/madVR.zip Code:
* added adjustable anti-bloating filter for sharpening * added adjustable anti-bloating filter for SSIM downscaling * added adjustable anti-bloating filter for SuperRes * added anti-ringing filter for SuperRes * added Hyllian's super-xbr anti-ringing (for image doubling) * reworked super-xbr chroma upscaling anti-ringing algorithms * improved sharpen anti-ringing filter * sharpen anti-ringing filter now also includes AdaptiveSharpen * changed SSIM anti-ringing method * added "relaxed" vs "strict (soft)" option for downscale anti-ringing * "crispen edges" now tries to avoid amplifying grain & noise * reduced some "crispen edges" aliasing problems * added separate image doubling supersampling option * added trade quality option "scale chroma separately if it saves performance" * increased AdaptiveSharpen max value from 1.5 to 3.0 * increased "thin edges" max value from 4.0 to 8.0 * previously optional DX11 "alternative glitch handling mode" is now always on * multiple profile groups can now share the same keyboard shortcut * double clicking tray icon now opens "best" settings instead of always local * fixed: Jinc/SSIM 2D downscaling was sometimes activated when not needed * fixed: 4-taps Spline was broken * fixed: some problems with 3D side-by-side and line/column alternative * fixed: 10bit content could make DXVA scaling fail * fixed: bitmap subtitles were not always moved up when cropping black bars * fixed: when downscaling, some chroma algos were used although they shouldn't * fixed: sometimes media player froze during DVD playback * fixed: source black/white adjustments + gamma processing: wrong order * fixed: rare shutdown crash when using native DXVA decoding * fixed: OSD bug when playing BT.709 HDR content 1) Many of the new features/options are considered experimental. I want/need your feedback, and your feedback will decide which options will stay, which will be always forced on, and which will be removed again (soon). So please do provide feedback, YOU decide what stays and what goes. For a list of important feedback areas see the bottom of this post. 2) The new anti-bloating tries to concentrate sharpening on higher frequencies and to remove lower frequencies. I like the look that produces, but your mileage may vary. The anti-bloating filter is only active for "sharpen edges", Luma Sharpen and Adaptive Sharpen (and SSIM and SuperRes), but it's not active for "crispen edges" and "thin edges", because those don't bloat by design. 3) super-xbr chroma upscaling previously had stronger anti-ringing with the "anti-ringing" option unchecked than with it checked. That was kinda confusing. So I've changed that now. You'll get some amount of anti-ringing with the option checked and unchecked, but the AR effect is now bigger with the option checked, which makes more sense, I suppose. The anti-ringing effect was also improved a bit. 4) If you didn't like "crispen edges" (formerly called "FineSharp") until now, please give it another try now. It doesn't amplify noise and grain as much as it did before. My personal opinion is still that it's the sharpener which produces the most natural and high-def look. Although the new anti-bloating filter might bring LumaSharpen and AdaptiveSharpen nearer to "crispen edges" now, in terms of naturalness and high-def look. 5) For downscaling, the anti-ringing filter now has 2 methods. The "relaxed" one allows a little bit of ringing to remain, which produces sharper results. The "strict (soft)" option removes all ringing, but the final result is quite soft (of course SSIM helps a lot there). One anti-ringing sub-option will stay, one will go. You decide. ------- Here are the most important areas of FEEDBACK I need: a) Do you consider the "anti-bloating" filter useful for sharpening (LumaSharpen + AdaptiveSharpen)? If so, which strength settings do you like? b) Do you consider the anti-bloating and anti-ringing options useful for SuperRes? I think anti-bloating might not be beneficial here, but I'd like to hear your opinion. Do you see any benefit in the anti-ringing option? SuperRes already didn't ring that much, so I wonder if the separate anti-ringing post processing option is worthwhile in your opinion or not? c) Do you consider the "anti-bloating" filter useful for SSIM downscaling? If so, which strength settings do you like? d) Which of the two anti-ringing options do you prefer for downscaling? (Edit: FYI, these options do *not* affect SSIM downscaling) Again: Your feedback is very important. Thank you! Last edited by madshi; 23rd March 2016 at 11:53. |
23rd March 2016, 11:48 | #37037 | Link | |
23rd March 2016, 11:55 | #37039 | Link |
Quite the change log.
I've found that changing the anti-ringing filter type for super-xbr doesn't prompt me to Apply after I've already changed it once, switching between them Apply is still greyed out. Also it's not remembering strict once I Apply and judging from my screenshots it's not using Strict either when it does apply. Last edited by ryrynz; 23rd March 2016 at 12:04. |
23rd March 2016, 11:58 | #37040 | Link |
Wow, that's a lot of new stuff. I'll start off by reporting a bug (sorry): I can't set the anti-ringing filter to "strict (soft)" for chroma upscaling or image upscaling. If I do, the Apply button doesn't light up, and even if I force it to light up by changing something else (like toggling superres), the change to anti-ringing doesn't stick.
Test patterns: Grayscale yuv444p16le perceptually spaced gradient v2.1 (8-bit version), Multicolor yuv444p16le perceptually spaced gradient v2.1 (8-bit version) |
