Old 21st May 2009, 10:51   #4921  |  Link
Blackwalker
Blackwalker's Avatar
[SPAM]or HDConvertToX, it support multiple audio and multiple subs.. [/SPAM]
BHH
so you suggest this program for hd tracks????
Blackwalker is offline   Reply With Quote
Old 21st May 2009, 15:08   #4922  |  Link
prettyboy85712
Originally Posted by hbcsavage View Post
I have a bit of a noob question i have TS MPEG2 file that is 1920 x 1080i, 29.970 fps, 14 Mbps.When i encoded to avchd using ripbot,playback picture was moving too fast and audio was way out of sync.Can anyone tell me the correct settings for this type of file?Also i had a 720p mkv file that was 10gb but when i encoded it to avchd after ticking the 8150 tab output size was 12.2gb can anyone help with this also.Any info would be great.
What were the sources of both files and you need to
prettyboy85712 is offline   Reply With Quote
Old 21st May 2009, 15:49   #4923  |  Link
Hyrax
Originally Posted by cxp36 View Post
I'm trying to use v1.13.3. I have a Vista partition and an XP partition.
In XP, did all of the above, and extraction was successful, but right after extraction got to 100% Media Player Classic popped up with the error message:
"DirectShowSource: Couldn't open file c:\temp\ripbot264temp\job1\video.mkv An object or name was not found (\Job1\Getinfo.avs, line 2)"
The same thing happened with multiple discs, both when ripping directly from the disc, and also after ripping the disc to my hard drive with AnyDVD HD and pointing RB at that directory.
Anyone have any ideas why this is happening?
I've no idea what is happening, but can suggest a method I use that helps me. In your XP partition, run a CMD session, change the directory to your Job1 folder, and run the various CMD files RipBot creates. You'll see the actual output from all of the tools and that may give you a clue.
If my instructions are too brief, search this thread for my earlier posts and find where I describe it in more detail.
Hyrax is offline   Reply With Quote
Old 21st May 2009, 16:34   #4924  |  Link
hbcsavage
HDTV for 1080i file and the 720p is ripped off of bluray disc.
hbcsavage is offline   Reply With Quote
Old 22nd May 2009, 04:32   #4925  |  Link
Inbox7
Windows 7 - Worked Once; then NO CHAPTERS NO AUDIO - Stumped
Ok I'm stumped. Installed a clean version of Windows 7, AnyDVD, Acronis Backup, Total Media Theater 3, MS Office, and Ripbot + supporting files. Life was good...I was able to rip a MP4 1080p copy of my new Star Trek III bluray. Looked and sounded great.
The next day, I tried the same thing again. Only this time, nothing worked. Ripbot reported "NO CHAPTERS" and "NO AUDIO" under "Select Streams." I tried TSMuxeR thinking I could do it manually but it reported "Unsupported Format."
So I though 'just restore the computer to a point before you installed everything' and start over. I ran Acronis restore and put everything back to the first time I ran Windows 7. I restarted the computer then reinstalled Ripbot + supporting files. This time though, same problem: "NO CHAPTERS" and "NO AUDIO." Tried on other Star Trek Titles and same problem. Did several google searches but couldn't pinpoint the issue.
Adding to the confusion... when I tested some other titles like "Christmas Vacation" and "Phantom of the Opera," Ripbot still worked fine.
Ugg. Really stumped on this one and not sure what/how to troubleshoot next. How could it work one time but not the next on the same title? What could be different? Is it a codec issue? Bluray security problem?
Any advice is appreciated.
System
Windows 7 64Bit
i7 920 Intel
Gigabyte EX58 MB
6 GB Ram
Dual nVidia 9800GTX graphics
Inbox7 is offline   Reply With Quote
Old 22nd May 2009, 13:09   #4926  |  Link
Ga1j1n
Ga1j1n's Avatar
Hey Atak,
I've noticed a new strange bit of behaviour, the first time I go to transcode an h264 mp4 from VOB's ripbot will skip the video encoding step after it finishes the audio, mux into an mp4 and announce everything is complete.
However the next time I run the same project (and any others in the queue) it completes perfectly.
Is this common? I have never used it for VOBs before now
v1.13.3
Further to my earlier post I have noticed the same behaviour for Vob encodes further down the queue although here doesn't appear to be a pattern to the failure.
I've included the log file for one of the job's which has failed numerous times to complete where others do complete the second or so time around.
Odd?
Script used:
# BEGIN
import("D:\Temp\RipBot264temp\job9\job9.avs")
# END
Scanning for Audio Stream...
Found Audio Stream
Channels=2, BitsPerSample=16, SampleRate=48000Hz
Writing Header...
Writing Data...
0%
Done!
* AACPlus v2 Encoder (using Winamp 5.2 enc_aacplus.dll)
* Source timestamp Mon May 15 17:24:26 2006
* Build May 15 2006, 17:24:35
* NOTE! enc_aacplus.dll must be into executable directory
* get it from Winamp 5.2 plugins directory
* tested on Winamp 5.2 Release Feb 23 2006 Full (Not Pro) version)
Input file: -
Output file: D:\Temp\RipBot264temp\audio.aac
SampleRate: 48000
ChannelCount: 2
BitsPerSample: 16
Bitrate: 131072
ChannelMode: Stereo
Encoder: AAC-LC
Encoding...
Finalizing...
Done
D:\>"C:\Program Files (x86)\RipBot264v1.13.3\tools\avs2yuv\pipebuf.exe" "C:\Program Files (x86)\RipBot264v1.13.3\tools\avs2yuv\avs2yuv.exe" "D:\Temp\RipBot264temp\job9\job9.avs" -raw - : "C:\Program Files (x86)\RipBot264v1.13.3\tools\x264\x264_x64.exe" --crf 22 --stats "D:\Temp\RipBot264temp\job9\job9.stats" --sar 1422:1000 --level 4.0 --aud --nal-hrd --vbv-bufsize 25000 --vbv-maxrate 25000 --filter 0,0 --ref 3 --mixed-refs --bframes 3 --b-adapt 1 --weightb --direct auto --subme 7 --trellis 1 --partitions all --8x8dct --me umh --threads auto --thread-input --progress --no-psnr --no-ssim --fps 25 --frames 61550 --output "D:\Temp\RipBot264temp\video.264" - 720x576 : 4
x264 [info]: 720x576 @ 25.00 fps
x264 [info]: using SAR=711/500
x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 Cache64
x264 [info]: profile High, level 4.0
D:\Temp\RipBot264temp\job9\job9.avs: 720x576, 25 fps, 61550 frames
Output error: wrote only 614118 of 622080 bytes
encoded 6 frames, 193.55 fps, 0.00 kb/s
D:\>"C:\Program Files (x86)\RipBot264v1.13.3\tools\mp4box\mp4box.exe" -tmp "D:\Temp\RipBot264temp" -add "D:\Temp\RipBot264temp\video.264" -fps 25 -add "D:\Temp\RipBot264temp\audio.aac":lang=und -mpeg4 -chap "D:\Temp\RipBot264temp\job9\chapters.txt" -new "F:\Video\Sample.mp4"
Cannot find H264 start code
Error importing D:\Temp\RipBot264temp\video.264: BitStream Not Compliant
Elapsed Time: 00h:00m:55s
Q6600 @ 3.2Ghz -Asus P5Q-Pro
4Gb DD2, GTX260 core 216
Win 7 64bit Home Premium
Ga1j1n is offline   Reply With Quote
Old 22nd May 2009, 13:22   #4927  |  Link
dbone1026
Can anyone think of why when encoding an SD-DVD to mkv the quality is hit or miss? As an example I had ripped dodgeball to my PC (keeping the Video_TS structure in tact). I have no problems playing this movie, PQ looks great. I tried encoding it to mkv using the same profile I use for all my otehr movies inlcuidng Blu Rays (4.0 - 2-Pass - 2GB target size) and the PQ comes out a little streaky, especially when there is movement. I have had this same problem with other SD DVD rips, but not all of them. I attached a screenshot, you can see the "streaking" in the "OSQ" title. There are no other problems, but this makes the mkv unwatchable.
I have never had this problem with Blu Ray or HD DVD movies.
Cheers,
Damian
Blog - http://www.adigitalhomeblog.com
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
dbone1026 is offline   Reply With Quote
Old 22nd May 2009, 17:38   #4928  |  Link
prettyboy85712
Change to Top Field First under de-interlace.
Old 22nd May 2009, 21:51   #4929  |  Link
Nkotok
Hi guys. I am making a switch from BD Rebuilder to try Ripbot for blu-ray movie only. I am interested in keeping HD audio though. I hope RibBot will include this option soon.
As for other aplications that come with Ripbot but outdated - TSmuxer and eac3to: can I manually replace the ones with newer version and will Ripbot work? If yes, do I need to replace the whole folders of Tsmuer and eac3to in Ripbot's tools or just the main .exe files? Thanks in advance and sorry if it has been discussed before.
Nkotok is offline   Reply With Quote
Old 23rd May 2009, 05:10   #4930  |  Link
prettyboy85712
Yes to replacing the individual apps and no to replacing just the executables.
Old 24th May 2009, 22:58   #4931  |  Link
Inbox7
After a lot of trial and error, I discovered that the "No Chapters" "No Audio" issue was a result of the wrong registration for AnyDVD. Somehow I had registered the regular version and not the HD version so other programs were not able to correctly read the streams. In case others have this issue, you may want to double check.
Old 25th May 2009, 22:58   #4932  |  Link
JohnnyB.Good
Great tool, works wonderfully. It would be great if you can select your streams and also pick all of your options and set it off to start before demuxing, is that possible? Some movies take upwards to 40 minutes to demux so right now you have to wait until its done before you can click start and leave it off overnight, unless the option is there and I just don't know about it...
JohnnyB.Good is offline   Reply With Quote
Old 25th May 2009, 23:33   #4933  |  Link
jhmac
jhmac's Avatar
Is there any way to boost audio vol in the psp format?
jhmac is offline   Reply With Quote
Old 26th May 2009, 00:04   #4934  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Normalize = 200%
Old 26th May 2009, 02:09   #4935  |  Link
jhmac
jhmac's Avatar
Thanks worked great...
Old 26th May 2009, 12:16   #4936  |  Link
mackworth
I'm on vacations in Poland till 19th and I have no access to my sources. Also last week I had laser eye correction so I'm not allowed to sit in front of monitor for long time. Good news is that 1.14 is almost finished. I will release new version once I come back to Ireland.
Any news on 1.14, perhaps that changelog of whats coming?
mackworth is offline   Reply With Quote
Old 26th May 2009, 15:38   #4937  |  Link
Nkotok
I see the new log for 1.14 No option for keeping hd audio, right?
Old 26th May 2009, 16:09   #4938  |  Link
buzzqw
HDConvertToX author
great idea about visual crop! very nice
just a question: why using w64 ? because bepipe/nicaudio cannot handle hd audio stream ?
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
Old 26th May 2009, 16:34   #4939  |  Link
Atak_Snajpera
1) Lossless audio has variable bit-rate. My calculation formula for AVCHD works only with constant bit-rate. Uncompressed audio (wave64) provides always constant bitrate.
2) I don't want to use DirectShowSource (ffdshow) method for decoding audio because it can only complicate things. For example I would have to disable 'Mixer' in FFdshow and probably other filters.
PCM, TrueHD and EAC3 will be always converted to uncompressed wave64 format (.w64). If you do BD50 -> BD25 backups you can import back .w64 into AVCHD structure. Quality will be exactly the same. Also keep in mind that AVCHD officially supports only AC3,DTS and PCM (wave64 for example).
Old 26th May 2009, 16:51   #4940  |  Link
Nkotok
I still am trying to understand why there is no option to just leave hd audio untouched? Is it your personal choice not to include it?
My guess is it does not require much. TS muxer does that.
The audio is stripped off the video at the beginning and then after video reencode is done is muxed back together. So why can it not be unconverted hd audio?
