Old 16th February 2013, 12:11   #12141  |  Link
tebasuna51
tebasuna51's Avatar
Originally Posted by Sparktank View Post
The Quesion:
Should I downmix with eac3to using -downstereo (in WAV) then use SoX to do the compand?
Or can SoX compand a 6ch WAV and then use eac3to to downmix?
If you use sox compand, with a profile like "Film standard" in AC3 Dynamic Range Compression, you can finish with max peak at -11 dB, and you need Normalize after.
I think is better use sox compand over the 6 channels and after use eac3to with -downStereo -normalize.
Also, if compand is used over each channel, you can improve the dialogs volume in Center channel. If compand is used over the downmix the dialogs can be masked with global volume.
tebasuna51 is offline
Old 16th February 2013, 14:59   #12142  |  Link
nautilus7
nautilus7's Avatar
Hi, I got this output when demuxing Cars (2006) Blu-ray Disc (us version). It's a seamless branched disc.
eac3to 1) -demux -keepdialnorm
M2TS, 1 video track, 10 audio tracks, 7 subtitle tracks, 1:56:35, 119.881p
1: Chapters, 32 chapters
2: h264/AVC, 1080p24 /1.001 (16:9)
3: TrueHD/AC3, English, 5.1 channels, 48kHz
   (embedded: AC3 EX, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB)
4: AC3 EX, English, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB
5: AC3 EX, French, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB
6: AC3 EX, Spanish, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB
7: AC3, English, 2.0 channels, 192kbps, 48kHz, dialnorm: -27dB
8: AC3, English, 2.0 channels, 192kbps, 48kHz, dialnorm: -27dB
9: AC3, French, 2.0 channels, 192kbps, 48kHz, dialnorm: -27dB
10: AC3, French, 2.0 channels, 192kbps, 48kHz, dialnorm: -27dB
11: AC3, Spanish, 2.0 channels, 192kbps, 48kHz, dialnorm: -27dB
12: AC3, Spanish, 2.0 channels, 192kbps, 48kHz, dialnorm: -27dB
13: Subtitle (PGS), English
14: Subtitle (PGS), French
15: Subtitle (PGS), Spanish
16: Subtitle (PGS), French
17: Subtitle (PGS), Spanish
18: Subtitle (PGS), English
19: Subtitle (PGS), English
Creating file "00145 - Chapters.txt"...
s15 Extracting subtitle track number 15...
a07 Extracting audio track number 7...
a05 Extracting audio track number 5...
a04 Extracting audio track number 4...
s14 Extracting subtitle track number 14...
a11 Extracting audio track number 11...
a03 Extracting audio track number 3...
v02 Extracting video track number 2...
a06 Extracting audio track number 6...
s16 Extracting subtitle track number 16...
s18 Extracting subtitle track number 18...
a09 Extracting audio track number 9...
a12 Extracting audio track number 12...
a08 Extracting audio track number 8...
s19 Extracting subtitle track number 19...
s13 Extracting subtitle track number 13...
a10 Extracting audio track number 10...
s17 Extracting subtitle track number 17...
a03 Extracting TrueHD stream...
a03 Decoding with libav/ffmpeg...
a03 Remapping channels...
a03 Encoding AC3 <640kbps> with libAften...
v02 Creating file "00145 - 2 - h264, 1080p24.h264"...
a03 Creating file "00145 - 3 - TrueHD+AC3, English, 5.1 channels, 48kHz.thd+ac3"...
a06 Creating file "00145 - 6 - AC3 EX, Spanish, 5.1 channels, 640kbps, 48kHz.ac3"...
a05 Creating file "00145 - 5 - AC3 EX, French, 5.1 channels, 640kbps, 48kHz.ac3"...
a04 Creating file "00145 - 4 - AC3 EX, English, 5.1 channels, 640kbps, 48kHz.ac3"...
s18 Creating file "00145 - 18 - Subtitle (PGS), English.sup"...
a07 Creating file "00145 - 7 - AC3, English, 2.0 channels, 192kbps, 48kHz.ac3"...
a08 Creating file "00145 - 8 - AC3, English, 2.0 channels, 192kbps, 48kHz.ac3"...
a10 Creating file "00145 - 10 - AC3, French, 2.0 channels, 192kbps, 48kHz.ac3"...
a11 Creating file "00145 - 11 - AC3, Spanish, 2.0 channels, 192kbps, 48kHz.ac3"...
a12 Creating file "00145 - 12 - AC3, Spanish, 2.0 channels, 192kbps, 48kHz.ac3"...
a09 Creating file "00145 - 9 - AC3, French, 2.0 channels, 192kbps, 48kHz.ac3"...
s19 Creating file "00145 - 19 - Subtitle (PGS), English.sup"...
a03 Skipping identical AC3 frames (seamless branching)...
a06 Skipping identical AC3 frames (seamless branching)...
a04 Skipping identical AC3 frames (seamless branching)...
a05 Skipping identical AC3 frames (seamless branching)...
a10 Skipping identical AC3 frames (seamless branching)...
a09 Skipping identical AC3 frames (seamless branching)...
a08 Skipping identical AC3 frames (seamless branching)...
a12 Skipping identical AC3 frames (seamless branching)...
a07 Skipping identical AC3 frames (seamless branching)...
a11 Skipping identical AC3 frames (seamless branching)...
s13 Creating file "00145 - 13 - Subtitle (PGS), English.sup"...
s14 Creating file "00145 - 14 - Subtitle (PGS), French.sup"...
s15 Creating file "00145 - 15 - Subtitle (PGS), Spanish.sup"...
s17 Creating file "00145 - 17 - Subtitle (PGS), Spanish.sup"...
a03 Audio overlaps for 5ms at playtime 0:19:08.
a03 Audio overlaps for 5ms at playtime 1:20:15.
a03 The audio gaps/overlaps can't be removed from the TrueHD bitstream.
a03 In order to remove them you'll have to transcode to another format.
a04 Audio has a gap of 1ms at playtime 0:01:15.
a04 Audio has a gap of 2ms at playtime 0:04:24.
a04 Audio has a gap of 11ms at playtime 1:33:56.
a04 Audio has a gap of 7ms at playtime 1:42:04.
a04 Audio has a gap of 10ms at playtime 1:42:36.
a05 Audio has a gap of 1ms at playtime 0:01:15.
a05 Audio has a gap of 2ms at playtime 0:04:24.
a05 Audio has a gap of 11ms at playtime 1:33:56.
a05 Audio has a gap of 7ms at playtime 1:42:04.
a05 Audio has a gap of 10ms at playtime 1:42:36.
a06 Audio has a gap of 1ms at playtime 0:01:15.
a06 Audio has a gap of 2ms at playtime 0:04:24.
a06 Audio has a gap of 11ms at playtime 1:33:56.
a06 Audio has a gap of 7ms at playtime 1:42:04.
a06 Audio has a gap of 10ms at playtime 1:42:36.
a07 Audio has a gap of 1ms at playtime 0:01:15.
a07 Audio has a gap of 2ms at playtime 0:04:24.
a07 Audio has a gap of 11ms at playtime 1:33:56.
a07 Audio has a gap of 7ms at playtime 1:42:04.
a07 Audio has a gap of 10ms at playtime 1:42:36.
a08 Audio has a gap of 1ms at playtime 0:01:15.
a08 Audio has a gap of 2ms at playtime 0:04:24.
a08 Audio has a gap of 11ms at playtime 1:33:56.
a08 Audio has a gap of 7ms at playtime 1:42:04.
a08 Audio has a gap of 10ms at playtime 1:42:36.
a09 Audio has a gap of 1ms at playtime 0:01:15.
a09 Audio has a gap of 2ms at playtime 0:04:24.
a09 Audio has a gap of 11ms at playtime 1:33:56.
a09 Audio has a gap of 7ms at playtime 1:42:04.
a09 Audio has a gap of 10ms at playtime 1:42:36.
a10 Audio has a gap of 1ms at playtime 0:01:15.
a10 Audio has a gap of 2ms at playtime 0:04:24.
a10 Audio has a gap of 11ms at playtime 1:33:56.
a10 Audio has a gap of 7ms at playtime 1:42:04.
a10 Audio has a gap of 10ms at playtime 1:42:36.
a11 Audio has a gap of 1ms at playtime 0:01:15.
a11 Audio has a gap of 2ms at playtime 0:04:24.
a11 Audio has a gap of 11ms at playtime 1:33:56.
a11 Audio has a gap of 7ms at playtime 1:42:04.
a11 Audio has a gap of 10ms at playtime 1:42:36.
a12 Audio has a gap of 1ms at playtime 0:01:15.
a12 Audio has a gap of 2ms at playtime 0:04:24.
a12 Audio has a gap of 11ms at playtime 1:33:56.
a12 Audio has a gap of 7ms at playtime 1:42:04.
a12 Audio has a gap of 10ms at playtime 1:42:36.
s16 Creating file "00145 - 16 - Subtitle (PGS), French.sup"...
a03 The original audio track has a constant bit depth of 24 bits.
a04 Starting 2nd pass...
a04 Realizing (E-)AC3 gaps...
a05 Starting 2nd pass...
a05 Realizing (E-)AC3 gaps...
a06 Starting 2nd pass...
a06 Realizing (E-)AC3 gaps...
a07 Starting 2nd pass...
a07 Realizing (E-)AC3 gaps...
a08 Starting 2nd pass...
a08 Realizing (E-)AC3 gaps...
a09 Starting 2nd pass...
a09 Realizing (E-)AC3 gaps...
a10 Starting 2nd pass...
a10 Realizing (E-)AC3 gaps...
a11 Starting 2nd pass...
a11 Realizing (E-)AC3 gaps...
a12 Starting 2nd pass...
a12 Realizing (E-)AC3 gaps...
Video track 2 contains 167736 frames.
Subtitle track 13 contains 1732 captions.
Subtitle track 14 contains 1525 captions.
Subtitle track 15 contains 1494 captions.
Subtitle track 16 contains 83 captions.
Subtitle track 17 contains 89 captions.
Subtitle track 18 contains 1815 captions.
Subtitle track 19 contains 1582 captions.
eac3to processing took 25 minutes, 57 seconds.
Done.
It seems to me like the 1 (identical) frame that is removed, causes these gaps later on. I say so, because if you sum the duration of the gaps for each audio tracks you have 31ms (almost equal to 1 ac3 frame).
Any ideas? I have never come across a disc that has overlaps and gaps at the same time...
nautilus7 is offline
Old 16th February 2013, 16:18   #12143  |  Link
nautilus7
nautilus7's Avatar
I noticed another thing as well.
If I demux a matroska file (.mkv) which contains a FLAC audio track, then eac3to decodes the FLAC and encodes it again as FLAC. Why does this happen?
Old 17th February 2013, 05:44   #12144  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
Thank you! I'll give this a whirl next time. I had thoughts that this might be more efficient.
Win10 (x64) build 19041
NTSC | DVD: R1 | BD: A
AMD Ryzen 5 2600 @3.4GHz (6c/12th, I'm on AVX2 now!)
Sparktank is offline
Old 17th February 2013, 15:33   #12145  |  Link
sl1pkn07
Pajas Mentales...
about:
For best AAC decoding you need:
(1) Nero 7 (Nero 8 won't work!)
(2) Nero HD DVD / Blu-Ray plugin
why no use NeroAacDec from NeroAACCodec?
sl1pkn07 is offline
Old 17th February 2013, 15:51   #12146  |  Link
06_taro
soy sauce buyer
Didn't do any further tests, but AAC is encoded in floating point precision yet NeroAacDec limits its decoded data to only 16-bit, while Nero's directshow decoder outputs 24-bit
06_taro is offline
Old 17th February 2013, 16:19   #12147  |  Link
sl1pkn07
Pajas Mentales...
ok
pity nero +7 never work on linux (through wine)
sl1pkn07 is offline
Old 20th February 2013, 09:09   #12148  |  Link
frencher
French Love
@frencher
About your question: "I wanted to know if others have had the same problem as me for demuxing 3D Bluray PGS subtitles tracks (.sup)"
Seems the answer is "Nope", at least not for me.
Please put the log file, if show any <ERROR> or <WARNING>, or more info about your problem.
The problem a little more detailed Here
Originally Posted by r0lZ View Post
I use eac3to to extract the audio and subpic streams from the MPLS, except when the MPLS is made of a single M2TS/SSIF file (because subtitle timings are sometimes damaged when there is a cut between two M2TS). In that case, the streams are extracted from the M2TS.
The video is encoded from the single or multiple M2TS/SSIF pair(s) anyway. (Look at the AVS script to see how I do it.)
2013-11-29 MVC Player Free v0.0.2.6 BD & 3D BD's Player, Demuxer v0.0.0.8b, Recoder. Tutorial
Demo for MVC Player Free: Trailer 3D
3DBD's Free - v0.0.0.0005.exe Old
Programing free for all.
frencher is offline
Old 21st February 2013, 17:13   #12149  |  Link
robertcollier4
I noticed that it is said that eac3to 5.1ch -DownDpl algorithm does not use any of the information from the LFE track??
Is it recommended to use -mixlfe with -downDpl?
From: http://forum.doom9.org/showthread.ph...95#post1600695
3/2 or 3/2.1
Stereo
FL' = FL + 0.7071 x FC + BL
FR' = FR + 0.7071 x FC + BR
Dpl
FL' = FL + 0.7071 x FC + 0.8660 x BL + 0.5000 x BR
FR' = FR + 0.7071 x FC - 0.5000 x BL - 0.8660 x BR
If exist the parameter -mixlfe add:
FL' = ... + 0.7071 x LFE
FR' = ... + 0.7071 x LFE
robertcollier4 is offline
Old 21st February 2013, 23:36   #12150  |  Link
tebasuna51
tebasuna51's Avatar
Dolby Digital recommend NOT use LFE in DPL dowmix.
But, of course, it's your choice.
Old 22nd February 2013, 08:43   #12151  |  Link
LigH
LigH's Avatar
I preferred to mix the LFE with -3 dB when I used Azid.
New German Gleitz board
LigH is offline
Old 22nd February 2013, 09:49   #12152  |  Link
robertcollier4
mkv_ac36ch-downStereo-aac2ch-remux
After many downmixes to play AC3 5.1 movies on my stereo hardware player, here are the settings I have found optimal. A batch file included if it might be useful to others.
My findings:
1) I prefer the Nero 7 AC3 decoder (if you have it installed), thus I force it over ffmpeg using the -nero switch. I have not had any problems with the "bug in disabling Nero DRC" in a few hundred encodes.
2) I prefer -downStereo over -downDpl because it gives cleaner dialogues. Although -downDpl effects might sound a little better due to the 'matrix' echo effect in left channel, I found dialogues to be cleaner in -downStereo.
3) I prefer -mixlfe as it includes bass that gets picked up by the crossover on my 2.1 speaker set.
4) I use -full to let eac3to pass qaac 64 bit-depth data since that is what is generated by the eac3to downmixer anyways. No need to do a down dithering operation since qaac will take care of that when it converts the audio data to floating point.
5) I use qaac because it has --no-delay which removes the 44ms encoder delay introduced by all AAC encoders. Thus the audio is insured to be in sync with the original video.
@echo off
set PATH_EAC3TO=D:\PortableApps\VideoProcessing\eac3to327
set PATH_MKVMERGE=D:\PortableApps\VideoProcessing\mkvtoolnix-unicode-6.0.0
set PATH_QAAC=D:\PortableApps\VideoProcessing\qaac
set PATH=%PATH%;%PATH_EAC3TO%;%PATH_MKVMERGE%;%PATH_QAAC%
for /f %%a IN ('dir /b *.mkv') do (
echo ---------------------- BATCH STARTING %%~na%%~xa
eac3to.exe "%%~na%%~xa" -log="%%~na.eac3to.log" 2: stdout.wav -full -nero -downStereo -mixlfe -normalize | qaac.exe --tvbr 127 --quality 2 --rate keep --ignorelength --no-delay - -o "%%~na.m4a" 1>"%%~na.log" 2>&1
mkvmerge.exe -o "%%~na-2chremux.mkv" --no-audio "%%~na%%~xa" "%%~na.m4a" 1>>"%%~na.log" 2>&1
pause
Old 22nd February 2013, 11:39   #12153  |  Link
tebasuna51
tebasuna51's Avatar
Is the same than:
Old 22nd February 2013, 12:20   #12154  |  Link
tebasuna51
tebasuna51's Avatar
Apply DRC is not a problem when you want downmix, normalize and want more dialogs volume.
Is only a problem when you want preserve the original quality of your source.
Of course -downStereo is preferred when you never play the audio with a 5.1 system with DPL decoder.
BTW:
- the echo effect must be in both left and right channels
- the contribution of Center channel (dialogues) is the same in -downStereo and -downDpl mix.
Maybe when you play with a 2.1 audio system, never recommended when play with TV speakers.
Add the LFE channel reduce the global volume of the rest of channels to avoid clip when normalize.
Also Dolby Digital say than mathematical add LFE to front channels can produce, sometimes, cancels or not desired effects.
OK.
BTW preserve 64 bit precission is not very important after apply DRC, downmix and normalize, 24 bit integer is enough to convert to a lossy format.
NeroAacEnc put the delay in .m4a metadata and MkvMerge apply the needed delay in the AAC stream.
Old 26th February 2013, 01:37   #12155  |  Link
Overdrive80
Anime addict
Overdrive80's Avatar
Hi, I have .tsv file than if I rename to .ts, mediainfo show this details. But eac3to launch error. The video file is playback with mpc properly, premiere import without troubles. Mkvmerge import and all fine.
The source file is TV capture.
eac3to v3.27
command line: "C:\Program Files (x86)\MeGUI\tools\eac3to\eac3to.exe" "C:\Users\Isra\Desktop\INAZUMA ELEVEN_ '¡LA PRUEBA DEL CAPITAN!'(26022013_191942).TS" -progressnumbers -log="C:\Program Files (x86)\UsEac3to\UsEac3To.log"
The format of the source file could not be detected. <ERROR>
EDIT: DGindex is able to load too without troubles.
EDIT2: I attach example file
EDIT3: I did contact with support department of device, and they said that I can handle tsv files with avidemux, and its true.
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Radeon RX580 8GB DDR5 + ADATA SX8200 Pro 1 TB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite
Overdrive80 is offline
Old 28th February 2013, 18:51   #12156  |  Link
PowerGamer
When I want to extract DTS-HD MA 7.1 audio track from BluRay disc in its "original form" (for muxing into mkv later) I specify .dtsma extension for the output file (for ex.: "eac3to.exe 00800.mpls 3:audio.dtsma") and I don't need to have ArcSoft DTS Decoder installed, right? In other words, ArcSoft DTS Decoder needs to be installed only if I want eac3to to convert DTS-HD MA 7.1 audio track into some other format?
PowerGamer is offline
Old 28th February 2013, 22:49   #12157  |  Link
tebasuna51
tebasuna51's Avatar
@PowerGamer
Yes, is correct.
You can use .dts or .dtshd extension also, instead .dtsma, the stardard dts is extracted only if you put the parameter -core.
Old 8th March 2013, 13:31   #12158  |  Link
Anakunda
HI! I have finally managed to make working ArcSoft DTS decoder with eac3to but to my surprise the result is unusable.
Firstly I don't understand why the intermediate WAV by ArcSoft is 2-3x smaller than WAV made by ffmpeg, and secondly the result otherwise retains all 7.1 channels but the actors voice is missing at all and moreover after muxing it with video track the sound is (in KMP) simply ugly. What's wrong with ArcSoft? (I used DtsDec.dll and dtsdecoderdll.dll from latest TMT for this).
eac3to v3.24
command line: D:\media\eac3to\eac3to.exe Source.dtshd stdout.wav -normalize
DTS Master Audio, 7.1 (strange setup) channels, 24 bits, 48kHz
(core: DTS-ES, 5.1 channels, 24 bits, 1509kbps, 48kHz)
CAUTION: Decoding this track with ArcSoft results in low volume. <WARNING>
Decoding with ArcSoft DTS Decoder...
Applying RAW/PCM delay...
Writing WAV...
Creating file "stdout.pass1.wav"...
Reading WAV...
Reducing depth from 64 to 24 bits...
Writing WAV...
Applying 0.92dB gain...
Creating file "stdout.wav"...
The processed audio track has a constant bit depth of 24 bits.
eac3to processing took 50 minutes, 16 seconds.
Done.
Anakunda is offline
Old 8th March 2013, 13:36   #12159  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Have you tried updating eac3to for starters? You are using an old version, the latest one is v3.27.
Boulder is offline
Old 8th March 2013, 13:38   #12160  |  Link
Anakunda
No yet, I noticed there's new version just now. I'll made a rip with new e3t and will see..
Anakunda is offline
eac3to
